Bob Bauer 27 #1 Posted February 23 Hi can you tell me if the C series hydraulic pump is the same as on the D series and do you know if you rebuild one are there parts still available somewhere? Thanks Share this post Link to post Share on other sites
953 nut 68,513 #2 Posted February 23 @daveoman1966 should have the answers you need. 1 Share this post Link to post Share on other sites
pfrederi 21,051 #3 Posted February 23 Later C series with piston to piston Sunstrands are similar but not directly swappable, but share most all parts. Some parts are still available contact LJ Fluid Power Delton MI 260-623-4150 Early C series may have hydro gear Hydros. D series used piston to piston...There are significant internal differences in the pump. 1 Share this post Link to post Share on other sites
Bob Bauer 27 #4 Posted February 23 23 minutes ago, pfrederi said: Later C series with piston to piston Sunstrands are similar but not directly swappable, but share most all parts. Some parts are still available contact LJ Fluid Power Delton MI 260-623-4150 Early C series may have hydro gear Hydros. D series used piston to piston...There are significant internal differences in the pump. Ok thanks Share this post Link to post Share on other sites
