Bdja54 1 #1 Posted February 22 Hello all , I have a c160 hydro with an issue with hydraulic lift not working. Tried another lift valve, lift cylinder, new hoses from valve to lift cylinder. Still doesn’t lift plow without helping it . Drives in forward and reverse with plenty of power. Anyone ever have this issue? Any thoughts? Can the implement side of transmission pump be bad , but tractor still drives with plenty of power? Share this post Link to post Share on other sites
ri702bill 13,067 #2 Posted February 22 (edited) Welcome! Mine are all gear units, curious to see the replies... you are only 2 towns south of me. Possible internal leakage on the lift cylinder?? Bill Edited February 22 by ri702bill Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,488 #3 Posted February 22 Do not have the answer but a link to some info. Should be model 90-1140 Share this post Link to post Share on other sites
pfrederi 21,150 #4 Posted February 22 (edited) One of the relief valves has failed or is jammed open Can't build up pressure beyond the 50-150 psi that feeds the charge pump. You get enough pressure for the charge pump to feed slippers and piston block, they drive the tractor but that pressure is not enough to run the lift it needs 550-750 I would guess it is one of the springs for the implement valve has broken... Edited February 22 by pfrederi 4 2 1 Share this post Link to post Share on other sites
Bdja54 1 #5 Posted February 22 2 hours ago, ri702bill said: Welcome! Mine are all gear units, curious to see the replies... you are only 2 towns south of me. Possible internal leakage on the lift cylinder?? Bill Hey bill , I replaced lift cylinder with known good one . Same results 1 Share this post Link to post Share on other sites
pfrederi 21,150 #6 Posted February 22 Do you have access to a pressure gauge? 2 Share this post Link to post Share on other sites
ineedanother 2,865 #7 Posted February 22 1 hour ago, pfrederi said: One of the relief valves has failed or is jammed open Can't build up pressure beyond the 50-150 psi that feeds the charge pump. You get enough pressure for the charge pump to feed slippers and piston block, they drive the tractor but that pressure is not enough to run the lift it needs 550-750 I would guess it is one of the springs for the implement valve has broken... Or they have been swapped from front to rear. One spring is significantly stronger than the other and won't provide enough pressure if not reinstalled correctly. 2 Share this post Link to post Share on other sites
pfrederi 21,150 #8 Posted February 22 1 hour ago, ineedanother said: Or they have been swapped from front to rear. One spring is significantly stronger than the other and won't provide enough pressure if not reinstalled correctly. Good Point Also if you add hydro lift you have to swap the Charge and implement valves. Did this thing ever work??? 1 Share this post Link to post Share on other sites
Bdja54 1 #9 Posted February 24 On 2/22/2026 at 2:07 PM, pfrederi said: Good Point Also if you add hydro lift you have to swap the Charge and implement valves. Did this thing ever work??? Not sure last time it worked. I bought tractor few months back. Share this post Link to post Share on other sites
Bdja54 1 #10 Posted February 24 Anyone in Rhode Island area that knows how to repair these? Share this post Link to post Share on other sites
pfrederi 21,150 #11 Posted February 24 Replacement of the valve springs is not a super difficult job. Please post a couple pictures of the hydro unit. We can talk you through it. But it is not a driveway project this time of year Share this post Link to post Share on other sites
Bdja54 1 #12 Posted March 2 (edited) On 2/22/2026 at 9:08 AM, ri702bill said: Welcome! Mine are all gear units, curious to see the replies... you are only 2 towns south of me. Possible internal leakage on the lift cylinder?? Bill Hey Bill , how are you? I just realized this was you . This is Jay , I bought a few tractors from you. Edited March 2 by Bdja54 Share this post Link to post Share on other sites
ineedanother 2,865 #13 Posted March 3 On 2/23/2026 at 11:21 PM, Bdja54 said: Anyone in Rhode Island area that knows how to repair these? I don't think you're necessarily facing a "repair" issue. Your pump and motor seem to be working so my advice would be to download the manual in post #3 above and make sure the pieces and parts for the relief valves are present and installed correctly. 1 Share this post Link to post Share on other sites
