702854boy 478 #1 Posted 1 hour ago The k301 on my grandpas 122 is having a hard time cranking over. It keeps getting caught on the compression stroke. It has always done this but usually it would start, but after replacing the head gasket and replacing the bearings and brushes in the s/g it cranks to the compression and then gets stuck. And it also has all new wiring. 1 Share this post Link to post Share on other sites
pfrederi 19,824 #2 Posted 1 hour ago What model tractor is it. (122 ??) Load test the battery. Check all ground connections. Did the rewire use heavy enough cables for battery to switch (or Solenoid) and from there to the A terminal on the S/G (at least 6ga) 2 Share this post Link to post Share on other sites
702854boy 478 #3 Posted 1 hour ago 36 minutes ago, pfrederi said: What model tractor is it. (122 ??) It is a 1967 Cub Cadet 122 but it still has the same Kohler that our Wheel horses use 36 minutes ago, pfrederi said: Did the rewire use heavy enough cables for battery to switch (or Solenoid) and from there to the A terminal on the S/G (at least 6ga) Yes, I used six gauge wire to rewire it and I haven't load tested the battery but it is and 530 cca car battery because the engine is from the era where they used the big batteries Share this post Link to post Share on other sites
953 nut 64,024 #4 Posted 1 hour ago How about your S/G belt, is it a cogged rubber edge belt? NAPA 25-7345 is what you need. Share this post Link to post Share on other sites
Achto 30,924 #5 Posted 44 minutes ago (edited) Check your points gap. If they are opening too far this means you timing is too far advanced and the plug if firing before the piston reaches TDC. Example: if they are set at .020 try setting them at .018. One other thing that may cause it to stop at compression stroke is the ACR not working. Depending on the spark plug location in the head, (some heads position the spark plug directly over the exhaust valve) you can watch the exhaust valve as you turn the engine over by hand. The exhaust valve should lift up slightly shortly before the piston reaches TDC. Edited 44 minutes ago by Achto Share this post Link to post Share on other sites
WHX?? 54,732 #6 Posted 33 minutes ago Whats the spec number? We can look it up and see if it's even got a ACR cam. 29 minutes ago, 702854boy said: but it still has the same Kohler that our Wheel horses use Not necessarily. Base motor might be the same but built to a Cub spec. Might have a bad spot (weak) SG. 7 minutes ago, Achto said: Check your points gap. If they are opening too far this means you timing is too far advanced and the plug if firing before the piston reaches TDC. Example: if they are set at .020 try setting them at .018. If it's firing too soon (too far advanced) it's usually going to puff and try to reverse rotation. Share this post Link to post Share on other sites
pfrederi 19,824 #7 Posted 17 minutes ago Big Battery may not equal good battery. Poor mans load test...hook up multimeter to battery. Should read 12.6v.. Then try cranking her. If voltage drops to 9 or below weak battery Share this post Link to post Share on other sites
