AHS 1,698 #1 Posted February 20 New to me! Oil change/ hydro oil filter/air filter. Fuel line/ petcock and filter change… and it’s running! (It’s running in the picture). Ive taken off the carb bowl and cleaned it out. Cleaned / Sprayed out the high and low speed screws. (Kohler spec) Set them to 2 1/2 turns out and it runs BUT…. It takes a long time to fire up. Let’s. Say you flip the throttle quickly.. it’ll die. But, wont if you gradually increase the throttle. What is the culprit that’s making it die when you throw it suddenly? Share this post Link to post Share on other sites
squonk 47,728 #2 Posted February 20 Try adjusting the carb a bit richer. 3 1 Share this post Link to post Share on other sites
kpinnc 18,851 #3 Posted February 20 My old Magnum would do that until it warmed up. Speaking of which- let it run a few minutes and set the carb needle valves then. You'll likely see a big difference. 5 Share this post Link to post Share on other sites
wallfish 20,380 #4 Posted February 20 Initial carb settings are just that, initial to get it running. ALL engines should be adjusted (if adjustments are available to do so). Each engine has different hours, different wear, different compression etc etc etc. Adjustments to that particular engine's conditions should help It's also a good idea to clean out those little holes in the long high speed needle. Braided copper wire and untwist the braid to a single strand. then spray it out too. 5 1 Share this post Link to post Share on other sites
ineedanother 2,769 #5 Posted February 20 Long fuel line is most likely the culprit IMO. If you consider an electronic fuel pump wired to the "I" tab on the ignition you will be able to fill the bowl on the carb before you crank it and will likely see a great improvement. A fuel bulb is a cheaper and easier solution. 2 2 Share this post Link to post Share on other sites
kpinnc 18,851 #6 Posted February 20 13 minutes ago, ineedanother said: If you consider an electronic fuel pump wired to the "I" tab on the ignition you will be able to fill the bowl on the carb before you crank it and will likely see a great improvement. A fuel bulb is a cheaper and easier solution. On every machine with the fuel tank under the seat, this makes a huge difference. Heck, I think it improves with high mount tanks under the steering wheel. 4 Share this post Link to post Share on other sites
ri702bill 12,693 #7 Posted February 20 7 hours ago, wallfish said: Initial carb settings are just that, initial to get it running. ALL engines should be adjusted (if adjustments are available to do so). Each engine has different hours, different wear, different compression etc etc etc. Adjustments to that particular engine's conditions should help It's also a good idea to clean out those little holes in the long high speed needle. Braided copper wire and untwist the braid to a single strand. then spray it out too. Those tiny holes in the needle must be clean - the needle is hollow and is the air bleed for the mix. Don't overlook the hole near the bottom! 4 Share this post Link to post Share on other sites
AHS 1,698 #8 Posted February 20 As you can see in the background, we have snow! It’s been creeping up close to 40 everyday. I am icthin’ in hands but my brain is telling my body to wait another month!! Another culprit, the fuel line is on the left (by the hydro filter); the fuel line makes a quick jump in the shifting linkage and then goes down slowly under the motor. Pictures would help! Ill get pictures this week coming! It’s that quick jump that concerns me! Share this post Link to post Share on other sites
AHS 1,698 #9 Posted February 20 Ive opened up my slow speed screw by 1/2 a turn. This is the hose routing i was talking about, it’s all in the clips, so it’s factory? The problem the fuel line goes way up near the gas tank. I would rather have the fuel go down slowly. How does your fuel line routed? I spotted that its got a aftermarket plastic fuel pump, but it works…. Share this post Link to post Share on other sites
sqrlgtr 3,583 #10 Posted February 20 Might be weak/bad/wrong setting, governor spring, going wide open when ya throw the fuel to her. just spit balling. 1 Share this post Link to post Share on other sites
AHS 1,698 #11 Posted February 21 Ah hah!! At 12 degrees this morning, i pulled up the hydro tranny clutch. It spun over faster and started like normal!! Wow!! Huge improvement!!! Yesterday, and all the other times i had let the motor spin the transmission. 1 Share this post Link to post Share on other sites
