Alrashid2 451 #1 Posted yesterday at 03:01 AM Hey guys. Will try to keep it short and sweet. Today, while trying to move the 312-8 around in the slush and snow on some brand new Carlisle All Trail tires I just installed, I started to spin out in the snow and mud. I looked down at my rear wheel, and I noticed it looked wobbly. I tried to take a video below. When slipping the other wheel, it looked fine and symmetrical. I just had these tires installed by a shop that, for other reasons, I won't be returning to. The owner commented one tire was easy to install and the other gave him trouble. I'm now wondering if he bent one of the rims a bit, resulting in this wobble. Maybe I'm not familiar enough with installing tires, but I'd think any damage when installing tires would be directly to the bead area of the rim, not a slight bend/warp in the entire rim? Or am I wrong? Any other ideas here? This weekend I am planning on jacking her up, and letting her run in first gear in the air and looking at both tires. If I have time I'll swap wheels too and confirm it's the wheel and not the axle. Ultimately, if he did bend my rim, is it really concerning? Or am I fine to just let it go? 9 times out of 10 I'm running this on uneven woodland terrain, so I doubt I'd feel any imbalance, but these are brand new tires and I don't want to wreck the tread if it's a problem. Appreciate the advice guys! PXL_20260218_223421032_TS.mp4 Share this post Link to post Share on other sites
Ed Kennell 44,763 #2 Posted yesterday at 03:31 AM Is the wheel seated on the hub properly? 1 Share this post Link to post Share on other sites
Alrashid2 451 #3 Posted yesterday at 03:33 AM @Ed Kennell I thought I reinstalled the wheels correctly, though I will admit that I did this in my tight little shed. Hoping enough snow melts so that Fri I can bring this horse up to the garage and get a better look under bright light. Can report back then, but my hunch here is the wheel is bent and was curious how common this was and if it was a concern if that is the case 2 Share this post Link to post Share on other sites
RED-Z06 2,713 #4 Posted 23 hours ago In general...gt wheels are very difficult to bend, its not something you would ever do accidentally or with any hand tool. Id guess not seated on the hub or bent axle 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,528 #5 Posted 18 hours ago Check the bead where the tire meets the rim... is it seated uniformly all the way around? 4 Share this post Link to post Share on other sites
WHX?? 54,715 #6 Posted 15 hours ago 8 hours ago, RED-Z06 said: gt wheels are very difficult to bend, I doubt that would be it. Check the hub & key. 3 Share this post Link to post Share on other sites
Bar Nuthin 2,169 #7 Posted 14 hours ago (edited) I suppose you could bend a rim by over-tightening the wheel weights - but I'd be more inclined to think the hub and/or keyway is the issue. Based on the video, I don't think it is a bent axle or bearing issue (though it could be). First check I would do is get it off the ground and see if you can wobble the wheel. Or remove the wheel and see if the hub is rotating true. Use something stationary on the floor touching the hub - as the motion could be minimal at the hub, but become exaggerated when watching the entire wheel. Edited 14 hours ago by Bar Nuthin 2 Share this post Link to post Share on other sites
WHX?? 54,715 #8 Posted 14 hours ago 2 minutes ago, Bar Nuthin said: could be minimal at the hub, but become exaggerated when watching the entire wheel. True ... I have a front on a tractor like that. Share this post Link to post Share on other sites
Alrashid2 451 #9 Posted 14 hours ago All awesome tips, appreciate you guys! Tomorrow I'm off work and my plan is to do all of these checks in the garage. The main issue is, we still have a nasty couple inches of snow/slush and I can't get my damn horse up the 30 yard hill to the garage! Praying tomorrow I have better luck with all of this rain melting stuff. Fingers crossed! 1 Share this post Link to post Share on other sites
Ed Kennell 44,763 #10 Posted 13 hours ago 1 hour ago, Alrashid2 said: couple inches of snow/slush and I can't get my damn horse up the 30 yard Time to strap a set of 2 link Vee Bar chains and some weight on that helpless horse. 3 2 Share this post Link to post Share on other sites
Alrashid2 451 #11 Posted 11 hours ago @Ed Kennell yup the old gal finally met her match! I wanted to try rubber chains first. Already have 100 lbs of wheel weights back there, not sure how much more I can do! The con is, when summer comes my property is nearly a swamp. So I don't want to fill the rears with fluid - I already sink bad enough with the wheel weights! Share this post Link to post Share on other sites
ineedanother 1,838 #12 Posted 5 hours ago The weight is wobbling in the vid so it's more than the tire not being seated on the rim. Curious to see what you find when you get to it. Share this post Link to post Share on other sites
Bar Nuthin 2,169 #13 Posted 1 hour ago (edited) 12 hours ago, Alrashid2 said: I can't get my damn horse up the 30 yard hill to the garage! You already have the weights. You're just missing the chains. I see them all the time on FB marketplace. Or you will need to step up and get a set from Tractor Supply. If you were closer, I'd hook you up with a set. Edited 1 hour ago by Bar Nuthin Share this post Link to post Share on other sites
Alrashid2 451 #14 Posted 1 hour ago 5 minutes ago, Bar Nuthin said: You already have the weights. You're just missing the chains. I see them all the time on FB marketplace. Or you will need to step up and get a set from Tractor Supply. If you were closer, I'd hook you up with a set. Thanks for offering brother! I decided $150 was worth it and I bought a pair of Rubber Tire chains from SoftClaw. Should be here next week! 1 Share this post Link to post Share on other sites
