Wayne0 1,666 #1 Posted February 15 (edited) The Workhorse needed front wheel bearings so I found some on fleabay for cheap. I figured how bad could they be. Gave them the "Greasy Pete" treatment and installed them. Swapped them out 6 months later and this is all 4 of them! I have never seen such destruction. I think I found 5 balls left in the mess. Don't buy cheap bearings, people! Edited February 15 by Wayne0 5 1 3 Share this post Link to post Share on other sites
oldlineman 1,821 #3 Posted February 15 China strikes again! You get what you pay for. Bob 3 Share this post Link to post Share on other sites
CCW 1,522 #4 Posted February 15 It was always hard for me to buy tools because I would not buy cheap. 4 Share this post Link to post Share on other sites
AlexR 3,139 #5 Posted February 15 I was going to go that route too, even bought the bearings on the bay. Ended up not installing them because the OD of the bearing was too small for my rims. And honestly the original bearings seemed just as tight if not more as the new ones. 3 Share this post Link to post Share on other sites
Bill D 3,213 #6 Posted February 15 I try to buy USA bearings if possible. Japanese bearings are next followed by Taiwan. 2 Share this post Link to post Share on other sites
peter lena 10,125 #7 Posted February 15 @Wayne0 been using XIKe bearings , with snug shim washers , thats a critical area , for side play , shucking / side slamming , no issues , regularly look them over , same as day , built , use HILLMAN MACHINE BUSHINGS , LOCAL h/w store , also like a soft vinyl stretchy cap for grease retention , pete 1 Share this post Link to post Share on other sites
Lee1977 7,813 #8 Posted February 16 (edited) I've used the XIKe bearings for 15 years haven't had any problems with them. It's not likely the bearings are the problem that they are loose in the wheels. The wheels get worn and won't hold the bearing tight . I have had a few wheels to get badly worn, all were on a tractor used for mowing. Edited February 16 by Lee1977 2 Share this post Link to post Share on other sites
squonk 48,427 #9 Posted February 16 Center punch the wheel. Bearings stay put. 3 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #10 Posted February 16 Is there baring suppliers near you? I have a few. They match up and get you quality bearings. Usually made in USA. 2 Share this post Link to post Share on other sites
Bill D 3,213 #11 Posted February 16 What is the actual bearing number fir the front wheel bearings? Looking for both the standard wheel bearing and the oversized heavy duty one found on some 520's. I don't need the bearings for the swept forward 520 front end. Thanks. Share this post Link to post Share on other sites
Lee1977 7,813 #12 Posted February 16 57 minutes ago, Bill D said: What is the actual bearing number fir the front wheel bearings? Looking for both the standard wheel bearing and the oversized heavy duty one found on some 520's. I don't need the bearings for the swept forward 520 front end. Thanks. I've never seen an actual bearing no. for them . Just 3/4" ID x 1 3/8" OD x 12" wide. The older 88 and 89 520's use the same bearing. Don't know about " Heavy Duty Spindles". Share this post Link to post Share on other sites
