ML3
Mystery nut...
ML3
Found this in driveway yesterday now that snow is starting to melt. Its definitely Wheel Horse red just not sure if its off the 654 or 702? Leaning towards 702 cause the 654 has incorrect color respray. Guess this weekend I'll be looking over both tractors however nothing appears to be loose, falling off, or not functioning on either tractor......
Any guesses???
Edited by ML3
1968Commando
Looks like a flywheel bolt
Easton Rich
Looks too small
JCM
It's actually a Castle Nut used with a cotter pin to secure.  What , that is the question.
gwest_ca
Looks like 1/2"
Lagersolut
I'm gonna take a guess - did some of the older blades use a castle nut for number 12
702854boy
Yes, our plow from '62 has a bolt that goes through with a castle nut originally, I swapped it our with a pin of the same size so blade could be removed easier.
kpinnc
Do you have a 520?
Looks like the castle nuts on the steering tie rods.
squonk
Edited by squonk
ML3
I know its a castle nut. Gotta figure out where it came from. Gonna look over both my snow removal tractors later today
Edited by ML3
ML3
I'll be looking there for sure
ML3
7 hours ago, kpinnc said:
Do you have a 520?
Wish I had a 520 but I dont.
Just do snow removal w/654 plow & 702 snowblower.  All the other tractors are in back storage building for winter
JCM
You called it a bolt, that is all.
ML3
Stupid auto correct. Lol
  • Haha 1
JCM
I just went out to the shop and on my 48'' dozer blade # 0648BC03 it has a 3/4 -16 X 3 3/4 Hex bolt with a 3/4-16 Hex nut. This a later model blade set up. Directions say to leave the bolt loose enough to allow the sector and channel to operate freely. No Castle nut and cotter.  :thumbs:  @ML3
