CD Long Jr
Well, let me tell ya!
CD Long Jr
416H had no lights. Fuse block was full of grass. Cleaned it with air, looked at fuses, they looked ok. put some WD-40 on em and installed em. No lights. Got my handy, dandy colored wiring diagram, (thanks for the heads up about it). Tested fuses with 12V test light. The headlight fuse was bad. Replaced it, no lights. Looked over the wiring, no issues. Started tracing the wires, on/ off switch is bad. Ordered a new one. Went to change out the front tires on the 312-8. Got a small tire changer from Harbor Freight. Broke the tire loose but wouldn't spin it of the wheel. After 45 minutes of fighting with 3 screwdrivers & very little progress, it was time for the grinder w/ cut off wheel. It came off then. Wheels are rusted pretty bad. Gonna try to wire brush & repaint them, (maybe spray with flex seal?), but also looking for new wheels. Back in the day, you could buy rubber flaps that installed on the wheel to protect the tubes. Haven't found anything like that but still looking. Did I mention new wheels are $200 & up. OUCH!
Edited by CD Long Jr
Goldnboy
I had rust holes on the inside of my front rims when I removed the tubes/tires when changing to V61's..  JB weld did a great job filling the holes and I spread to other areas that looked suspicious from putting rust. Make sure you clean  all the rust and let JB weld fully cure before remounting tires..might be good to paint it too if you have time.
  • Like 4
peter lena
@CD Long Jr  your  involvement  really impresses me ! thoroughness to detail  is evident and you are still  learning this unit !  ever get a penetrating oil  soak down going on that paint ? just let it sit and soak / feed  that  , DO NOT  REMOVE ANY OF IT  , WITH  a  scruffy pad  , let the lubrication feed the foundation of it , for days weeks , then a  mineral oil  clean cloth rub down, you will trap  era patina , in both red / black  areas , have used a 6 " electric  buffer pad  , at that stage , my paints just  popped right thru , maybe  LIGHT CLEANER WAX , that paint is all  oil based recovery , only thing I put on them is , clean cloth mineral oil , your doing  very good , clean paint helps inspire  ideas , pete
Treepep
Any way to put all of these posts together?  Beyond my understanding.  All of the queries are about the same mo chine right?  shouldn't they stay together?
Retired Wrencher
CD It is like I always say by the school of hard knocks . Take your time with this it will pay you back in the end,
mrc
CD,
on scamazon you can get 2 brand new 16x6.50x8 tires.   2 new 8 inch rims.   and here is the best part.  the tires are already mounted on the rims.  under $100 for everything.
peter lena
@CD Long Jr    another tweak for ya , often relate to  spindle  deck issues , due to lubrication failure , in addition to doing that  on my 3 decks , also added this flat idler  pulley , also grease enhanced , at the worst  bounce point  ? watched  it in action , then just  went to the related WORST UNSUPPORTED SPOT  , drilled a hole in deck  , added a spacer  under  pulley, so it was even with  flat belt contact  , ENHANCING   its belt play  restriction , none of my deck belts , bounce , smooth  solid  , quiet function , every related bearing spindle has LUCAS  hd / green grease  , mule drive / pto set up , effortless  engagement  / operation , another experiment  pete
peter lena
@CD Long Jr  very  typical ,  REPEDITIVE  ISSUE  FOR ME , LOVE THOSE , THEY SHOW YOU THE WAY  , TAKE ADVANTAGE OF IT ,  zeroed in on the  widest belt bounce area  ?  already had the flat  back of belt pulley , to gently push back on long UNSUPPORTED  problem ?  staring right at you , drilled hole in deck  used a 3/8  short thread  bolt , most of it was smooth  for pulley slide function , washers , elastic lock nut , lets you  dial it in , when added to  my  lucas cleaned out  regreased spindle bearings , as well as entire PTO / MULE DRIVE SET UP  , how easily  do you think it  spins up ?  did that  on my 3 decks , easily spin .  often refer  to  how easily  my  mule  drive belt  moves the deck  BY HAND , thats ROTATIONAL  MOVEMENT EASE ,  no screaming belt  or violent engagement . never had any related bearing  fail  or whine , isn't that what you want ?   pete
CD Long Jr
We'll see how this works out.
CD Long Jr
So today, I got out my homemade vise and wire brushed the wheels, wiped em down with mineral spirits, let em dry and applied 4 coats of filling gray primer. " on scamazon you can get 2 brand new 16x6.50x8 tires.   2 new 8 inch rims.   and here is the best part.  the tires are already mounted on the rims.  under $100 for everything". Money is at a premium now & I like DYI.  Next, I installed the head.  Never-seize was applied to the head bolts. Torqued 10 ft lbs, then 20 ft lbs then 30 ft lbs and finally 40 ft lbs. I have rechecked the torque 3 times as suggested. No change. Now I'm gettin' quality time (?) on the keyboard searchin' for the sizes of  hardware I need. Got a great hardware store nearby. If they don't have it, you don't need it. ;)
  • Like 4
peter lena
 @CD Long Jr  going the right way , like to take advantage of a  related zone , if nothing else , get some marker tags  or  stick on writeable tape , to  relate  issue  / idea  , as you  transition to that  mind set ,    rite it down , brain farts  as also part  this . look at what you have already done , you are kickin it  , pete
CD Long Jr
You guys were right!  The 312-8 sat in 55-degree weather with the sun on the engine all afternoon after I installed the head. At 5PM, I was cleaning up, putting tools away and decided for S&Gs, I'd check the head bolt torque one more time. The bolts were loose. Only by a couple foot pounds, but loose. Think I'm getting my neighbor hooked. Purchased a hitch extender to weld the mini tire changer on so I can mount it in the truck hitch  for more leverage. Steve does my welding. He was asking all sorts of questions about both tractors. He's gettin' the fever. Sent me a text last night about a Bolen's with deck, dozer blade & snow blower. I gave him the number for the guy I got the 416H from. He has some more Wheel Horses.
  • Like 4
lynnmor
You are to use a bit of light oil on the head bolts, that is not the place for Never-Seez.
  • Like 4
Handy Don
Well done!
CD Long Jr
Live and learn I quess. I worked the oil patch and industrial services all my life. Never bolted anything together without never-seize.
CD Long Jr
Yes, same two tractors.
peter lena
@CD Long Jr  agree with the  with the  lubrication  base  idea ,  been doing that forever , would much rather have an oil film than rust any day ,  LOVE KROIL  , HATE THE PRICING ,any rust at all is not an issue for me ,  been  regularly  rubbing down my paint  , mineral oil / penetrating oil  , for years now , this is paint  that  was RECOVERED  with lubrication , just effortlessly   stays clean / shinny  /  zero  related rust / grunge . more that worth a TRIAL AREA , ya doin  good , pete
CD Long Jr
Not a good day. Needed room in the shed, (there's a Harley trike in the future), so I moved the Cub Cadet XT1 & Toro Power Max 824 OE snowblower out & put them alongside the 312-8 & put their covers on. Went to start the 416H, no workie. No spark? I placed the dozer blade on a wheeled 2-ton jack, used a 5-ton jack to lift the rear and shoved her where I wanted her, across the front of the others. I have ordered a new ignition switch. Will it never end? :angry-cussingblack: On a good note, I have ordered all the parts I feel I need for the 416H & to get the 312-8 operational.
AHS
The only thing with Bolens is that they are shaft drive with lots of u-joints…. Compared to WH is belt drive. You can find the original # of the belt and the length…. You’ll have an have a new belt in an hour vs. a u-joint!
CD Long Jr
Finally warmed up some. This morning, the 416H got new seat springs & bushings, (I doubled the springs), shock to hold the seat up, ignition & headlight switches. The headlights work & she started but only ran 20 minutes & died. No restart. I have a cheat sheet from many posts on this forum & I'll start giving her the once over after I get the Grandkids from school. What is the black mystery hose? A vent for the hydro? It comes out the top of the frame behind the engine and just hangs there.
Handy Don
Not positive, but could it be the drain hose that normally attaches to the bottom of the plastic battery tray?
The Eaton 1100 vents via the dipstick (the 700 vents via an oil reservoir atop the hydro). The “crook” end is hollow which I periodically ream out with a pipe cleaner, though I’ve never seen it clogged.
Edited by Handy Don
pfrederi
Follow the hose probably battery tray
CD Long Jr
Too much gunk under her to follow the hose. Hose goes into the top of the frame.
CD Long Jr
Tracing some wiring & found the coil was loose in the bracket, tightened it. Found another Oh crapper. What's the proper name of the piece that holds the linkage on the bracket? I guessed at the hole it was supposed to go in, but it must be right. She wouldn't idle before, now she will.
lynnmor
Page 24 in the parts list.
That governor rod should not touch anything, it appears that it is rubbing wires and other things.
