fourwheelhorseman 361 #1 Posted Tuesday at 02:45 PM (edited) So I got a deal on snowblower a while back, along with a snowcab. I installed both and noticed that when I’m using that setup that to turn the auger I have to reach through the hole in my cab to acsess the handle. I’m wondering if it’s the correct snowblower for my C-160. Shouldn’t that hand stick through the cab for easier use? Edited Tuesday at 02:48 PM by fourwheelhorseman Share this post Link to post Share on other sites
rjg854 12,833 #2 Posted Tuesday at 02:48 PM When I had a snow cab on 16 Auto the handle was long enough to come through that slot. I suppose then it would depend on the blower you're using. Share this post Link to post Share on other sites
fourwheelhorseman 361 #3 Posted Tuesday at 02:59 PM 10 minutes ago, rjg854 said: When I had a snow cab on 16 Auto the handle was long enough to come through that slot. I suppose then it would depend on the blower you're using. That’s what I thought, I’m thinking it’s the wrong blower Share this post Link to post Share on other sites
pfrederi 19,794 #4 Posted Tuesday at 03:09 PM I am a NO Cab guy so I can't comment on that but the crank handle on your short chute looks about right to me. 1 Share this post Link to post Share on other sites
ebinmaine 77,079 #5 Posted Tuesday at 03:24 PM 35 minutes ago, rjg854 said: When I had a snow cab on 16 Auto the handle was long enough to come through that slot. I suppose then it would depend on the blower you're using. With a short chute single stage blower? Share this post Link to post Share on other sites
fourwheelhorseman 361 #6 Posted Tuesday at 04:18 PM (edited) I’ll try and take better pictures this evening. The handle is actually at a weird angle as well. And I have to slide up to the edge of the seat to reach it when it’s cranked to the right or to the left.. it’s awkward to say the least and I’m sure it has somthing to do with the blower model. However it’s a great blower with very little use.. so I might just live with it.. or try and modify it. Edited Tuesday at 04:19 PM by fourwheelhorseman Share this post Link to post Share on other sites
lynnmor 8,557 #7 Posted Tuesday at 04:49 PM There should be a slot in the cab fabric for the handle. You need to add an extension so that it extends inside. Please explain this since there should be no change in position: "I have to slide up to the edge of the seat to reach it when it’s cranked to the right or to the left" Share this post Link to post Share on other sites
Ed Kennell 44,667 #8 Posted Tuesday at 06:00 PM When I had that blower on my 520H. I added an extension to bring the crank into the cab thru the cab slot. It's been a while, but I think I cut the 1/2" dia crank rod and used a length of 3/8" pipe as an extension. I drilled the 3/8" pipe open to accept the 1/2" crank ends and then drilled and pinned the parts together. I also added a crank support inside the cab 4 1 Share this post Link to post Share on other sites
fourwheelhorseman 361 #9 Posted Tuesday at 06:21 PM 1 hour ago, lynnmor said: There should be a slot in the cab fabric for the handle. You need to add an extension so that it extends inside. Please explain this since there should be no change in position: "I have to slide up to the edge of the seat to reach it when it’s cranked to the right or to the left" I’m going to add better pics this evening that hopefully will explain it a little better Share this post Link to post Share on other sites
rjg854 12,833 #10 Posted Tuesday at 10:09 PM 6 hours ago, ebinmaine said: With a short chute single stage blower? No mine was a tall chute, he didn't have a photo up when I replied. 1 Share this post Link to post Share on other sites
squonk 45,378 #11 Posted Wednesday at 10:32 AM Cut your chute rod. Obtain a length of new rod needed and connect the ends with these: 1 4 Share this post Link to post Share on other sites
wallfish 19,068 #12 Posted Wednesday at 10:50 AM 12v electric gear motor and locate the switch inside the cab 1 1 Share this post Link to post Share on other sites
fourwheelhorseman 361 #13 Posted Wednesday at 01:01 PM 2 hours ago, squonk said: Cut your chute rod. Obtain a length of new rod needed and connect the ends with these: I had a freebie snowblower at one time that was in bad shape. I knew I shoulda kept it for parts! I’ll do some measuring and get the stuff I need. I actually though about welding a piece on to extend the rod. Share this post Link to post Share on other sites
fourwheelhorseman 361 #14 Posted Wednesday at 01:02 PM 2 hours ago, wallfish said: 12v electric gear motor and locate the switch inside the cab That would just be one more thing to go wrong on an already problematic implement… 2 1 Share this post Link to post Share on other sites
JCM 10,639 #15 Posted Wednesday at 02:06 PM I know this is a 2 stage on a 520 - H but shows bracket for rod and entry on left side attached to Cab upright. Hope this clarifies a little for you. Share this post Link to post Share on other sites
lynnmor 8,557 #16 Posted Wednesday at 02:18 PM 1 hour ago, fourwheelhorseman said: I had a freebie snowblower at one time that was in bad shape. I knew I shoulda kept it for parts! I’ll do some measuring and get the stuff I need. I actually though about welding a piece on to extend the rod. I made a sleeve as above but used a hairpin clip instead of one of the set screws, that way I can remove the handle without a tool. Share this post Link to post Share on other sites
fourwheelhorseman 361 #17 Posted Wednesday at 06:17 PM 3 hours ago, lynnmor said: I made a sleeve as above but used a hairpin clip instead of one of the set screws, that way I can remove the handle without a tool. Nice! Share this post Link to post Share on other sites
Ed Kennell 44,667 #18 Posted Wednesday at 07:51 PM Here is a picture of the chute crank support panel I made when I had the short chute blower on the 520. The crank was inserted thru the hole and the slit in the canvas and connected to the extension sleeve. The panel also served to mount the switches for the cab lights which I still use. Share this post Link to post Share on other sites
peter lena 9,712 #19 Posted yesterday at 01:53 PM @ four wheel horseman , also easy to use a threading die nut , on the end of that rod for a screw on ball , done that to any related round rod , makes work with gloves / mittens seamless , pete Share this post Link to post Share on other sites
wallfish 19,068 #20 Posted 2 hours ago On 2/11/2026 at 8:02 AM, fourwheelhorseman said: That would just be one more thing to go wrong on an already problematic implement… I found the crank handle to be the ploblematic issue when it's inside of a cab because it became kind of clumsy in that tight space. It wasn't the end of the world but I definitely prefer the ease and speed of using a motor. Reliability of electronics could certainly be a problem when it's not done correctly. If you're adding a support bracket for the handle to extend it into the cab, you could also use a universal joint shaft coupler to change the "weird angle" and position it where it works best for you. Is the "already problematic implement" issue more than just the crank handle length? Share this post Link to post Share on other sites
