WHX??
Oiling Pre Filters
RED-Z06
I use PJ1 foam filter oil, its sticky so no drip off like motor oil, I can get 100+ hours of mowing out of a paper element and have barely any dirt on it..Just the finest of fines...but the foam sleeve will be packed every 8-10 hours.  Its worth doing, the less dirt that hits the paper, the better
Edited by RED-Z06
clueless
On 2/4/2026 at 11:52 AM, Achto said:
I usually spritz it with light coat of K&N filter oil. I've had the same can for about 6yrs.
https://www.oreillyauto.com/detail/c/k-n-engineering/k-n-engineering-12-25-ounce-air-filter-oil/kan0/990516
I check it over at oil change time. If it looks dirty then I grab the K&N cleaner, spray it down, scrub, rinse, and re-oil. Again, this stuff goes a long way, think my cleaner bottle is about the same age as the oil.
https://www.oreillyauto.com/detail/c/k-n-engineering/k-n-engineering-1-quart-oiled-cotton-air-filter-cleaner/kan0/990621
That, what been using for years, just about out of my first can. I quit using it for my truck when I had two mechanics that I respect tell me the stuff put a bit of a coating on my MAP which probably negates the higher volume of air the air filter delivers.
lynnmor
Perhaps the mechanics were telling you to not use the useless K&N filters.  Yes, oil on the MAP might be a problem for cars and trucks but using a "filter" that has been proven to admit considerable amounts of dust is something to avoid.  The foam pre-filters are a good thing used over paper filters and the type of oil you choose shouldn't matter on our tractor engines.
Lagersolut
You sold me on this - interesting thread - never applied anything to my pre filters - checked every 10 hours or so used the compressor to blow it out ( off the air filter ) washed it out with mild soapy water - reused
  • Similar Content
    • Bill Sherman
      By Bill Sherman
      My 1986 417-8 is equipped with the anti-icing system air cleaner and I am having trouble finding the correct element for it.  I have yet to even find out what is the correct part number.  It is 6 inches OD and 1 7/8 high.  Any help would be greatly appreciated.
