WHX?? 58,124 #26 Posted February 6 2 hours ago, kpinnc said: don't show those welds anymore. I'll go the other way on that KP ... gives me something to aspire to. 1 Share this post Link to post Share on other sites
Lee1977 7,772 #27 Posted February 6 On 2/4/2026 at 9:31 AM, ACman said: @Racinbob Bob did you leave a small detent at the neutral position ? Is this for motion control lever up by the steering wheel on the council or lover mounted on the side panel? I don’t know the 300 400 and 500 series very well as my 520 lever is up by the steering wheel. Ive never driven my tractors personally, but watching others it just seems like a pain in the butt having to push the lever down to go into reverse. Next question for everybody is there only one pedal kit for 3 , 4 and 500 series ? I’d love to add one of Matt‘s kits to my tractor and is a factory option pedal kit pretty much the same as Matt’s and Matt just improved on it ? Is the slot above the pivot hole just to adjust the tension on the plate ? My next question would be could you make the slots longer on the reverse side or even the side to increase speed or does the lever and the pump itself hit something else so you can’t make it go faster in reverse ? Does the HD just have a different Cam Hydro speed control plate or do they run a different gear ? Would be nice to get a little more speed for cruising. If your asking about the difference in speed between the 520-H and the 520-HC it's the gears HC 22 teeth to 44 teeth, H 20 teeth to 46 teeth. 1 Share this post Link to post Share on other sites
JoeM 10,267 #28 Posted February 6 20 hours ago, Pullstart said: it’s always refreshing to see clean beads! Yep, but when I saw my BIL's work, my stuff looks like a beginner. He build up welds on steam turbine blades at Elliot Group. 1 Share this post Link to post Share on other sites
