"Manic-Mechanic" 1,483 #1 Posted Monday at 05:48 PM (edited) I had a factory set on a 1277 so these are from memory, “might be a bit different!” (Standard 12v tractor lights) Used a knuckle, that’s what I call it, on the end of a 30” x 5/8” steel rod, drilled tapped 3/8-16 utilizing a stud and cap nut. Two wire assembly to assure a solid ground Crimp on connection for hassle free hood removal There’s two 3/8-16 bolted to a threaded rectangular plate between the frame, mimicking factory Closer look at the stainless hardware, that is a metric thread in the knuckle, (euro part) The soft bend sweeps buy the cradle front tightly, has to be just so, plumb to clear I preferred the standard 12v light assembly with options to twist in all directions, do not care for the little bug eye looking factory assemblies! The 5/8 hot rolled steel can be formed quite easily by hand just make identical measurements on both sides. Basic & simple See the hood is very close and the button I put in from a very unstable method used by who-ever owned this hood, bought at big show over a decade ago! Don’t find these as often anymore but I perused eBay, they were actually IH Red! Edited Monday at 05:58 PM by "Manic-Mechanic" 5 10 Share this post Link to post Share on other sites
19richie66 17,777 #2 Posted Monday at 07:27 PM Nice! 1 Share this post Link to post Share on other sites
peter lena 9,678 #3 Posted Monday at 11:18 PM @Manicmacanic your detailing is showing ! very obvious trials , good job on that , pete 1 Share this post Link to post Share on other sites
Retired Wrencher 6,362 #4 Posted 13 hours ago Job well done. Are they L -E -D lights? 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,483 #5 Posted 8 hours ago 4 hours ago, Retired Wrencher said: Job well done. Are they L -E -D lights? No, old school Share this post Link to post Share on other sites
rjg854 12,786 #6 Posted 2 hours ago You can always put LED bulbs in the sockets, it will make a world of difference. 1 Share this post Link to post Share on other sites
"Manic-Mechanic" 1,483 #7 Posted 15 minutes ago 2 hours ago, rjg854 said: You can always put LED bulbs in the sockets, it will make a world of difference. I have used them in other applications but not for this, not really planning to run at night a whole lot. Share this post Link to post Share on other sites
