bo dawg 640 #1 Posted February 2 Got to play today in the garage and work on this weak corner of this 48" deck. Wasnt sure how to go about making the patch with all the angles and round overs but it worked out. I cant weld worth a crap to be pretty, but it holds and solid. I just got a 220 Harbor Freight flux core mig welder. But Im learning. I plan on get some 75/25 gas to see if I can do better maybe. Plus thin gauge metal aint my thing, I can do better with the thicker stuff. Lol 10 Share this post Link to post Share on other sites
Easton Rich 1,260 #2 Posted February 2 Better than it was! We all have our strengths and weaknesses 3 Share this post Link to post Share on other sites
kpinnc 18,960 #3 Posted February 2 1 hour ago, bo dawg said: But Im learning I've been welding for years, and I'm still not as good as I should be. I can make two pieces of mild steel stay together, and that is about it. Anything more is what grinders with flap discs are for... 5 Share this post Link to post Share on other sites
JoeM 10,267 #4 Posted February 2 5 hours ago, bo dawg said: Plus thin gauge metal aint my thing, I can do better with the thicker stuff tough spot to fix with all the curves. I use 16ga you can favor it and run over on the thinner deck metal. came out real good 2 Share this post Link to post Share on other sites
ri702bill 13,060 #5 Posted February 2 The use of the proper mix shield gas makes a huge difference. Patience is the key with thin gage materials. 2 Share this post Link to post Share on other sites
Bill D 3,156 #6 Posted February 2 Looks great. Nice job. 1 1 Share this post Link to post Share on other sites
squonk 48,123 #7 Posted February 2 Did you clean and check the area under that height adjuster bracket? All of the decks I've had that needed repairing had damage under that bracket. High stress area. 2 1 Share this post Link to post Share on other sites
peter lena 10,065 #8 Posted February 2 @bo dawg been doing this for years , zero , rust / rot , you have to BREAK THE GRUNGE CYCLE , with cleaning , lubrication and hot sun prop up , very easy to use wood blocks under the propped up deck , lift carriage ,block wheels , so you can hold the deck angle to the sun , leave it for hours , getting hot and drawing in the lubrication rot killer . that how all my decks look , also cut at highest setting , for better discharge, my decks are stained black , regularly look them over for ANYTHING , also have them held up against my shed inner wall , with a heavy spring and large S shaped hook , that easily attaches to the lift frame . repetitive problems , show you the way . pete 2 Share this post Link to post Share on other sites
bo dawg 640 #9 Posted February 2 4 hours ago, squonk said: Did you clean and check the area under that height adjuster bracket? All of the decks I've had that needed repairing had damage under that bracket. High stress area. No I didnt see anything but I did have to weld in some cracks in the deck at the rear where the carriage mounts are. One was thin enough that i kept blowing holes so I welded a patch on it. Thats usually where I see that kind of stress. Share this post Link to post Share on other sites
bo dawg 640 #10 Posted February 2 1 hour ago, peter lena said: @bo dawg been doing this for years , zero , rust / rot , you have to BREAK THE GRUNGE CYCLE , with cleaning , lubrication and hot sun prop up , very easy to use wood blocks under the propped up deck , lift carriage ,block wheels , so you can hold the deck angle to the sun , leave it for hours , getting hot and drawing in the lubrication rot killer . that how all my decks look , also cut at highest setting , for better discharge, my decks are stained black , regularly look them over for ANYTHING , also have them held up against my shed inner wall , with a heavy spring and large S shaped hook , that easily attaches to the lift frame . repetitive problems , show you the way . pete How clean does it need to be before the oil? What method used? Share this post Link to post Share on other sites
8ntruck 9,296 #11 Posted February 2 (edited) Looks good. I've got a similar situation that I need to get to this year. Won't be until May or June, though. What gage flux core wire did you use? Edited February 2 by 8ntruck Share this post Link to post Share on other sites
peter lena 10,065 #12 Posted February 2 @bo dawg , another view , of sun placement , when you do a thorough cleaning , oil treatment , and let that deck get hot from the sun for hours , it transforms the metal , mine are all stained black , and have lasted that way for years , with regular maintenance all of my decks have also had every related spindle bearing , cleaned out and re lubricated with hi temp / stress lucas green hd chassis grease , that also includes each mule drive bearing , the quiet / easy spin up says it all , this original set up was a repetitive problem , no issues at all for years . pete 1 Share this post Link to post Share on other sites
ineedanother 2,864 #13 Posted February 3 Good save. Truth be told in my experience is if you can make a decent repair and keep the deck clean and taken care of moving forward you'll head off more degradation. Pay attention to how you'll keep crap from building up on the underside of the repair. Maybe epoxy and cloth or chopped strand ground smooth now that you've put the strength back in that corner of the deck. 1 Share this post Link to post Share on other sites
bo dawg 640 #14 Posted February 3 13 hours ago, 8ntruck said: Looks good. I've got a similar situation that I need to get to this year. Won't be until May or June, though. What gage flux core wire did you use? All I had was .030 1 Share this post Link to post Share on other sites
