ebinmaine
Scale model building
wallfish
20 hours ago, ebinmaine said:
I've been mulling how to create a rounded look at the rear and haven't come up with a method that's within my current skill set. So, flat backed it is.
Just spit balling again
Is the rest of that tank sealed except the front? As in, heat that flat piece you made and blow pressure into the tank. Maybe a damp rag /paper towel wrapped on the tank edge near it to keep that from heating and expanding too
ebinmaine
Decent idea but no... the tank is far from sealed. It is, in fact, not at all joined well.
To some extent that's the fault of the kit(s) but also, I'm doing a combo that the manufacturer wouldn't have planned.
wallfish
How a bout, Make a thin metal cylinder just a bit larger than what the final cut out shape is, glue a piece to it and do the heat air pressure thing. Then cut out the smaller correct size out of that?
Thin aluminum flashing is pretty easy to shape.
ebinmaine
This may be combined with carving from wood/clay or bondo.
wallfish
What about just making a small metal ring the shape and size it needs to be, thickness would depend how deep you want the concave to be. Lay the plastic material over it and heat the center. Push down if necessary.
Or heat the material, lay it right on the actual piece and push to concave it. Once cool and hard flip it over and cut out the shape
I don't know how soft that material will get
Edited by wallfish
Achto
One idea that may be adaptable on a smaller scale.
ebinmaine
30 minutes ago, wallfish said:
making a
It's the crafting of the mold that's exactly the challenge for me.
The tank end is wider than tall.
The middle of the crown needs to be maybe a 1/4" out?
I don't have the artistic skills or tools to make a concave or bowl with the two different angles - much less literal dozens of angles from top to side.
That's why I like the idea of using clay or bondo.
Perhaps cut out another flat oval. Lay/glue a 1/4" stub in the center. Use that to line up to the edges by molding a softer material.
Sand/shape from there.
ebinmaine
34 minutes ago, Achto said:
idea
Very cool!
ebinmaine
The rear third didn't set just right yesterday so I did some readjusting to the seam. A little more grinding on the plastic at the top.
Stuck it back together and let it rest for a while. When it felt strong enough I started laying down/in/on/out some filler.
  • Excellent 2
8ntruck
I'm guessing that you don't need very much dome contour in your tank end.
You might be able to use some #8 or #10 solid copper wire formed to the desired oval outline of the tank end, then using a heat gun to heat your plastic sheet sitting on top of the formed wire until soft enough to sag into a shallow dome shape.  Thin sheet .010" or .020" thick should work for this.  Some encouragement may be necessary, though.
ebinmaine
Experimenting with the styrene forming this morning. I found a kitchen spoon with very good contours.
To get this to work I'd have to make two molds of the end and join them.
Sounds good on paper but... That was a fail. The styrene sheet curls every way you don't want it to.
  • Sad 1
Handy Don
So maybe the sheet needs the form mold on one side and a conformal pressure on the other side to keep it tight to the mold?
My friend the kayak maker had a bunch of cloth sacks filled with lead shot that he’d put onto the curved decks as he edge-glued the strips. With the curved surfaces, clamps just didn’t work.
  • Like 4
ebinmaine
I believe this to be true.
It seems that the sheet would need equal pressure on & from each side.
  • Like 4
ebinmaine
Did some sanding on the filler.
Also trimmed the back panel and got some measurements.
Hoping @Wheel Horse 3D can help me out.
ebinmaine
Priming has begun.
  • Excellent 3
ebinmaine
On this trailer model there was a bent/broken spare tire holder.
I separated the pieces, made a "shop repair" and glued them together.
After gray paint I think it'll look good.
ebinmaine
Got the spare tire holders painted.
I left them a little rough because I'll be adding a "mud" colored layer. This model will be slightly weathered.
Also did some wet sanding on the tank surface.
Gotta say... very impressive!
In this pic you can see the gray areas where the uneven surfaces were/are.
While I don't need this to be glass smooth  - I'm having fun experimenting with the primer and its capabilities.
It'll get another several thin coats when the wind calms.  Then in a day or three another sanding.
ebinmaine
Because I'm adding two rear sections of the tank together there was a gap at the very back bottom of the trailer.
I used sheet styrene to fill the area. Two small pieces for the sides and a larger section in the middle.
  • Like 4
  • Excellent 2
Beap52
Got a little more work done on model railroad building.  Painted each and every brick.  The colors are a bit bright for a abandoned building but will darken when I do some weathering.   I think I spent about 8 hours painting bricks. Still a long way before completion.
  • Like 4
  • Excellent 4
ebinmaine
5 minutes ago, Beap52 said:
weathering
You use a darkening agent?
Beap52
Yes.  Sometimes I use rubbing alcohol  and a few drops of black India ink with a drop or two of liquid dish soap to help break surface tension.   I have used thinned black paint from the small bottles Walmart sells.  Often times, the guys who know what they are doing, use chalk to streak below windows and represent rust down sides of buildings--and I may try something like that this time.  I think they spray it with clear matt sealer to keep the chalk from getting disturbed.  The ink and paint fill in the depressions helping give contrast.
Below is a train tunnel.  The brick are the same foam board the building is made from.  I used a wash over the brick and the mountain the tone down the brighter colors.  The white that represents sunlight is white paint dry brushed to give it highlights.
Grass is greening up and I've spot mowed this week after I did my annual check up of the mowers.  I'll likely spend less and less time on the building as warmer weather arrives.  It will likely be next winter before I complete itl
  • Like 4
  • Excellent 2
ebinmaine
I've set up my scale model building desk right in the living room very much on purpose.
Too cold/hot/dark/raining etc... I can work on whatever builds is/are happening...  year round.
:handgestures-thumbupright:
  • Like 4
ebinmaine
Picked up this "Conversion Kit" on fleabay. Not super common so I was happy to see it.
On the tanker I needed to come up with a hose transport tray/shelf.
After staring at countless pics of 1:1 scale trucks an idea started to form.
These are pieces of styrene L from a box store used for edges of tables or other furniture.
I ordered a couple different sizes and experimented with the right visual.
The part being attached to the trailer side is 7/16" by 5/16". The outer piece that's glued to that is 1/4".
I'll cap the open ends with a tiny piece of scrap.
The rest of the pics are basically a visual mockup for my own aesthetics just to see how things will be lining up later.
The truck being used is a parts rig from ebay.
Glad I did this simply for the reason of lining up the landing gear alone. The kit directions have it a hair too far forward.
There will be a minimum of 3 outlets on this tank. Front, center bottom, and rear. Possibly more at the bottom.
That isn't the norm on a modern fuel tank but this is not a representation of a modern tank or a fuel tank.
  • Excellent 2
Oldskool
Putting the extra time in sure is going to make the difference. Everything looks like it's coming along nicely.
  • Heart 1
ebinmaine
