tallen4392 71 #1 Posted January 27 anyone ever use those mighty max gel battery’s they sell on amazon looking for the right size battery for my my charger 12 i went to napa and 4 other parts stores near me no one has it also went to tsc no good there either the tray is 9 long x 5.5 wide i think 9 inches tall.. Thanks Share this post Link to post Share on other sites
ebinmaine 80,711 #2 Posted January 27 What type of cable ends do you have? A good strong standard issue U1 battery will work fine. 4 Share this post Link to post Share on other sites
lynnmor 9,040 #3 Posted January 28 Maybe this one from Home Depot will fit, they call it a U1: https://www.homedepot.com/p/MIGHTY-MAX-BATTERY-ML35-12-12-Volt-35AH-U1-Deep-Cycle-AGM-Solar-Battery-Replaces-33Ah-34Ah-36Ah-ML35-1274/321507826?MERCH=REC-_-brand_based_collection-_-308970494-_-1-_-n/a-_-n/a-_-n/a-_-n/a-_-n/a 1 Share this post Link to post Share on other sites
kpinnc 18,966 #4 Posted January 28 (edited) 5 hours ago, tallen4392 said: anyone ever use those mighty max gel battery’s they sell on amazon Yes. I have two of them. Model YTZ14S. One on a K181 and another on a Vanguard 14. Used one on the Bronco with a K321 for a while too. I think they have as good or better cranking power than typical L&G batteries. Can't speak for longevity because I've only had them for 2 years but so far so good. Very nice when space is tight, but if using a standard WH battery box you'll need a block behind it. I prefer that anyway so that it doesn't get close to the drive belt. Edited January 28 by kpinnc 1 Share this post Link to post Share on other sites
pfrederi 21,151 #5 Posted January 28 Most chargers came with a full sized battery and clamp type connectors. This is a 22NF battery in Charger battery pan. 1 Share this post Link to post Share on other sites
markseven 93 #6 Posted January 28 Try this it will turn over every time For years. 1 Share this post Link to post Share on other sites
tallen4392 71 #7 Posted January 28 thanks for the pic of the 22nf that’s what i need should be able to find those Share this post Link to post Share on other sites
ebinmaine 80,711 #8 Posted January 28 40 minutes ago, tallen4392 said: thanks for the pic of the 22nf that’s what i need should be able to find those @tallen4392 if those aren't readily available you can also use a group 35. They have 35R as well so double check your own terminal setup. 35/35R will need a small spacer block set in the battery tray. Share this post Link to post Share on other sites
tallen4392 71 #9 Posted January 28 the 22nf i see online at napa say 9 3/4 inch long which would be to long it would hit the brake lever rod i will have to go there and measure and see if it is 9 inch long which would than fit Share this post Link to post Share on other sites
tallen4392 71 #10 Posted January 28 group 35 battery’s all say 61/2 wide that won’t fit i will go look tomorrow and bring a tape measure. Thanks Share this post Link to post Share on other sites
pfrederi 21,151 #11 Posted January 29 I think over time Wh switched Chargers to the smaller battery box What is the model number of your tractor. Share this post Link to post Share on other sites
pfrederi 21,151 #12 Posted January 29 When it warms up tomorrow I will measure battery boxes there are two sizes... Share this post Link to post Share on other sites
tallen4392 71 #13 Posted January 29 i would have to look for model number i think it is a early model box is roughly 9 x 5 1/2 Share this post Link to post Share on other sites
