markseven 93 #1 Posted January 25 Im just starting to look for a good used deck for my electro 12 . Not sure how to phrase it when I Make a post on market place. Looking for a 42 inch are they all the same ? Share this post Link to post Share on other sites
8ntruck 9,214 #2 Posted January 25 Check the attachment interchange chart post - the first sticky post in the impleme is section of the forum. In general, if you are using a mid Tach Matic and a mule drive on your tractor decks from around 1970 and newer will fit. 42" decks come in side discharge and rear discharge. I have one of each. I think that the rear discharge gives a bit better cut, but when cutting heavy grass tends to leave a slight windrow. The side discharge does not leave windows - but tends to throw sticks and rocks farther. 2 1 Share this post Link to post Share on other sites
ri702bill 12,799 #3 Posted January 25 17 minutes ago, 8ntruck said: Check the attachment interchange chart post Share this post Link to post Share on other sites
peter lena 10,013 #4 Posted January 25 @markseven another thing you should consider , is the collective lack of maintenance on a for sale deck , they did not stop using it because they did not use it , seen a lot of decks that were literally frozen with rusty bearings , collective rot . done over a number of them , went on to be solidly quiet / reliable , the disassembly of a deck , lets you build in total opposite of what was there. often refer to mule drive belt turning over deck spindle assembly , by hand . EVERY RELATED BEARING , was cleaned out and re greased with hi stress , temp , lubrication , never had a related failure . also found that to be relatively easy , in that rebuild phase . none of my belts , are frayed , from belt bounce / hang up , caused by lubrication failure , incrementally stopping rotation , the more belt bounce you have , the more related bearings have failed . also deck start up is smooth / quiet / easy . combine that with a lubrication / sun soak , and your decks will live on . pete 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,450 #5 Posted January 25 Here is a list of the 42" side discharge decks in the order they were produced. Best to chose a deck that uses blades with a 3/4" center hole as these blades are readily available. Mower DNA 42" side discharge 1966-1967 model RL-426 (Have operator manual) replaced by 1968 model 5-1421 (Have operator manual) 1969 model 5-1422 (Have operator manual) 1970 model 5-1423 (Have operator manual) 1971 model 5-1000 (Have operator manual) 1971-1972 model 5-1001 (Have operator manual) 1973-1974 model 5-1010 (Have operator manual) 1975 model 5-1011 (Have operator manual) 1975 model 5-1012 (Have operator manual) 1976 model 65-42MS01 (Have operator manual) - Online Toro parts illustration is the 48" SD deck 1976 model 65-42MS02 (Do not have operator manual) - Online Toro parts illustration is the 48" SD deck 1977 model 75-42MS01 - (Do not have operator manual) These 42" side discharge decks all use blades with 5/8" x 3/4" double-D center hole unless the spindles have been upgraded. -------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- These decks all use blades with a 3/4" center hole. 1977 model 75-42MS02 replaced by (Do not have operator manual) 1978 model 85-42MS01 (Do not have operator manual) 1979 model 95-42MS00 (Do not have operator manual) 1979 model 95-42MS01 (Do not have operator manual) 1980 model 05-42MS01 (Have operator manual) 1981-1983 model 05-42MS02 (Have operator manual) 1984 model 05-42MS03 (Have operator manual) - Last year for bearings with 3/4" ID 1985 model 05-42MS04 (Do not have operator manual) - First year for bearings with 17mm ID unless older spindles were updated. 1986-1988 model 05-42MS05 (Have operator manual) 1989 model 15-42SC01 (Do not have operator manual) 1990 model 15-42SC02 (Have operator manual) 1990-1992 model 15-42SC03 (Have operator manual) 1993-2007 and 2009-2012 model 78345 (Have operator manuals) These decks all use blades with a 3/4" center hole. Note - 17mm is .669" 1 1 Share this post Link to post Share on other sites
ri702bill 12,799 #6 Posted January 25 19 minutes ago, gwest_ca said: Best to chose a deck that uses blades with a 3/4" center hole as these blades are readily available. Excellent long term advise... 1 Share this post Link to post Share on other sites
pfrederi 21,043 #7 Posted January 25 Depends on the age of your tractor. Early Chargers did not have a mule drive they used an arch bar side mount system... (Not one of WH best designs). post a picture of yo tractor so we can give better guidance. 1 Share this post Link to post Share on other sites
