Racinbob
I thunked it's dead
Racinbob
Yes, that's a 12 volt battery. Obviously not a tractor. The generator was due for a walk and yesterday I figured it was as good a day as any to do that. I turned the key and listened to silence. I don't think we're going to gut much of that storm that's fixin to hammer areas south of here but I'm glad I found out under better conditions.
  • Like 5
  • Sad 2
Terry M
Lucky you didn’t need it at that moment…
ebinmaine
How old is the battery vs its expected life?
Racinbob
It's just over a year old. Usually the life of these are similar to what we use in our tractors.
Racinbob
I had a couple other options to start it so it wouldn't have been a disaster.:)
JoeM
I know my better maintainers have a AGM setting.
That might help?
Racinbob
This battery isn't AGM. I'm inclined to think something went haywire inside the battery. Just to get me by for now I ordered another cheap sealed non-AGM battery. I'm just using a NAPA 1.5 amp charger/maintainer that will operate when the generator is running or, of course, if I plug it in to house power. I'd like to go with a AGM battery but it would mean a different charger. I decided to go the 'just get by for now' route. :)
squonk
We recycle dozens of these batteries every year at the hospital and they are still good. Emergency lights and UPS's. The e lites are mandated to be changed every 2 years just like the Generators.  I have one in the UPS under my desk at home now that's over 2 years old. I need an odd ball one for the back up on my garage door opener. Luckily we have one bldg that has an E lite with the correct size!  The battery I took out of my garage door this fall had .6 of a volt! :)
Edited by squonk
Racinbob
That's what this one is Mike. I bought it for a UPS only to find that the UPS was actually bad. I never put a battery on the penny but instead installed an Anderson pigtail on it and cut a cheap set of jumper cables in half and installed Andersons on those. A quick plug in and hook to a tractor and I'm cranking away. I also have the yank cord thingy but the shoulder really fights that idea these days.
wh500special
Is that just one of those little 7 A-hr sealed lead acids being used to crank a generator engine?
I had no idea they could push that much current.
Any specs on that little guy?
I did a quick Google search and found a
few that show they might be capable of 70A.   Those terminals don’t look sized for prolonged cranking.
steve
