Rob R
GT14 (1970)
Rob R
2 hours ago, 8ntruck said:
:text-yeahthat:  that is pretty much poor man's shot peening.  If you have a needle descaler, keep running it over the weld after the scale is gone to produce kind of a stippled finish on the weld.  Hammer strikes and needle strikes introduce compressive residual stressen into the surface of the metal.  These compressive stresses make it harder for cracks to start.
Thanks I do intend on welding the broken one for a spare and will keep this in mind will probably butt weld an additional support on the shaft also.
Edited by Rob R
nylyon
I’ll let @Rob R fill you in on the details, but the arm that Kevin @Pullstart sent worked perfectly.  Helped Rob install the new arm, and it all went together nicely with little colorful language.  Also a thanks again for Mrs. @Rob R for the delicious lunch (and I did eat one of the brownies on the way home), it was a much needed day out for me!
  • Excellent 1
Rob R
Hi Gentlemen, yesterday with the mild weather Karl Lyon and I removed and replaced the broken lift arm assembly on my beast GT14. We had to totally remove the left side plate to accomplish this as there is just not enough space to get the unit out between the bottom or top frame rails. This was quite the job and it took time to make sure we didn't mess anything up or break anything biggest issue was the removal of the transmission ball activator and of course the putting this back in...... but we prevailed!
Massive shout-out to Karl Lyon and Kevin (pull start) who supplied the replacement unit. Thank you both as well as all the great response from fellow Wheelers.  THANK YOU ALL!
  • Like 3
  • Excellent 4
19richie66
Help others when you can. That’s what it’s all about! :handgestures-thumbupright:
  • Thanks 1
  • Heart 2
  • Similar Content
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • tractorboy79
      By tractorboy79
    • wh315-8
      By wh315-8
      I have a question about the 69’ model. I took my tank out to work on carb easier. A couple weeks later as I put it back together & after cleaning everything; I replaced the white weatherstripping that was at bottom of tank and on the corners of the strap. Seems to be all that holds it in place. Because the strap around the tank will not go around the metal bracket on bottom and fit the tank. And even if it did the strap would only line up with the bracket mounting bolts which would be in the way. What did I miss? Didn’t pay close enough attention when I took it apart and can’t see in the parts diagram where the strap does go around the bracket. The weather stripping is tacky enough that the tank stays in place and it is a made to fit perfectly in position. Just seems that the metal strap is pointless.
    • tractorboy79
      By tractorboy79
      I have a old gt14 and the plastic plates or control panels are way past their prime, and I saw someone was remarking them with a 3d printer a little while back and I was looking to se if I could find the file but no luck. If anybody has info that would be amazing. Thanks for your time and anything helps.
    • Rob R
      By Rob R
      I am currently doing a ring, piston, hone rebuild on a K 321 off a Ford LGT 145 Tractor  on this machine they actually welded the rails to the bottom pan (see pics). My intention here is to put this puppy in a red machine (312-8 or GT14). I definitely have the small pan with the expanded bottom for the long dipper.
      Here's my questions:
      > Can I carefully remove the rails from the pan, cutoff the old front axle mounting bracket(s) and then drill holes in  the flanges to mount  to the Wheel Horse rails.
      > Since the engine is side mounted will the expanded bottom fit between the standard Wheel Horse rails?
      > If not possible to make this old pan work what flat pan would work and do I need to get the expanded bottom one (big dipper}
      > any recommendations here would be appreciated don't want to go down to many blind holes here...….
      Thanks much!
