702854boy 1,072 #1 Posted January 13 Yesterday we brought home my grandpa's 1967 Cub Cadet 122 so I could tear into and replace a headgasket, reseal the motor, fix the clutch, fix some fatigue welds, go through the mower deck, get it all degreased, flush and refill tranny, and probably some other stuff that I cant think if off the top of my head. Anyways, I have been taking photos as I go along. And when we were taking it off the trailer the left front spindle broke so I'm in need of one of those. 5 5 1 Share this post Link to post Share on other sites
ri702bill 12,693 #2 Posted January 13 That broken LF spindle looks awfully busy. It is the Master side, the RF is moved by it thru the tierod. Is the LF a 3-piece assembly - lower, shaft and upper or are the lower and shaft 2 parts welded into one?? Looks repairable if you cannot find a good used one. Share this post Link to post Share on other sites
702854boy 1,072 #3 Posted January 13 The top part that the steering box hooks up to is roll pinned onto the spindle but the part that goes through the axle and the part on the wheel is supposed to be one piece and from the looks of it, its going to be a pain in the butt to weld if we have to because the bottom part needs to be flat since it goes right against the axle. Share this post Link to post Share on other sites
PWL216 1,262 #4 Posted January 13 @702854boy I have a CC 122. If there are pics you need I can send them along. Mine is a 1966 but I assume they are similar. Share this post Link to post Share on other sites
702854boy 1,072 #5 Posted January 13 @PWL216, do you know how to get the steering wheel shaft out of the steering box? as my steering wheel is stuck on it and already cracked from age and I don't want to break it. Share this post Link to post Share on other sites
702854boy 1,072 #6 Posted January 13 Progress so far for today 1 Share this post Link to post Share on other sites
702854boy 1,072 #7 Posted January 14 Well with some observing how everything went together I was able to loosen the part that goes through the steering box and connects to the wheels and take the bottom cap of the steering box off and hammer on the metal part that went through the steering wheel and the shift popped right out. It is most likely going back together with a nice coating of the silver cancer. I also noticed that there is a chip missing out of the head so now I need a k301 head. After I got the steering wheel out of the way I was able to take the hood stand off so that I can redo the wiring and weld up the fatigue cracks when I get to that point. Share this post Link to post Share on other sites
702854boy 1,072 #8 Posted January 14 Here's the photos of the progress so far 1 Share this post Link to post Share on other sites
702854boy 1,072 #9 Posted January 14 Would the head off of a 14 horse Kohler work on the 12 horse? Share this post Link to post Share on other sites
Gasaholic 388 #10 Posted January 14 9 hours ago, 702854boy said: Would the head off of a 14 horse Kohler work on the 12 horse? Yep. as far as parts go, K301 and K321 are identical in all respects except bore size (piston & rings) Share this post Link to post Share on other sites
702854boy 1,072 #11 Posted January 14 (edited) Got the steering box torn apart and degreased and realized that one of the bearing things in it exploded so if anyone knows where to get a bearing thing like shown in one of the pictures below that be helpful. I also took the head off of a froze up 14 horse engine that we have laying around and shot some kroil in the bore to see if I cant get it freed up in the future. Edit: I'll post the photos later when I can use my Chromebook as my phone isn't allowing me to post photos right now. Edited January 14 by 702854boy Share this post Link to post Share on other sites
702854boy 1,072 #12 Posted January 15 This is the type of bearing i need Share this post Link to post Share on other sites
oliver2-44 11,656 #13 Posted January 15 I rebuilt a similar steering box on a 1965 case. On the Case forums I was told I didn’t have to have the plastic spacer that hold the balls. Just go to ace and get any missing balls. Arrange them on the race with heavy grease to hold them. It’s a little harder to reassemble without the plastic piece, but it’s doable. My Case is just a show tractor but it has worked for several years without the plastic spacer. Share this post Link to post Share on other sites
702854boy 1,072 #14 Posted February 1 @PWL216, would you be able to post some pictures of all of the wire clips/brackets that hook up to the engine and around there, my monkey brain forgot to take photos before tearing apart. Share this post Link to post Share on other sites
702854boy 1,072 #15 Posted February 21 Would anyone happen to know how much gear oil the tranny holds? Share this post Link to post Share on other sites
Easton Rich 1,260 #16 Posted February 21 Google tells me 7 pints? Share this post Link to post Share on other sites
8ntruck 9,172 #17 Posted February 22 On 1/15/2026 at 1:07 AM, oliver2-44 said: I rebuilt a similar steering box on a 1965 case. On the Case forums I was told I didn’t have to have the plastic spacer that hold the balls. Just go to ace and get any missing balls. Arrange them on the race with heavy grease to hold them. It’s a little harder to reassemble without the plastic piece, but it’s doable. My Case is just a show tractor but it has worked for several years without the plastic spacer. I wonder if a 3d printed ball spacer would work? Since @oliver2-44 has been running without one, I'll bet the printed part would work. Share this post Link to post Share on other sites
702854boy 1,072 #18 Posted February 23 We did end up finding somewhere to get some new ones and they are a lot heavier duty than the ones I took out. I tried running just the balls but the kept popping out and making me get annoyed. Share this post Link to post Share on other sites
T-Mo-(Moderator) 4,912 #19 Posted February 23 I had several Cub Cadets, most of them were narrow frame Cubs, like your 122. In fact, I had a couple of 122s, a couple of 123s, three 104s, and a 100. I used one of the 123s to push snow one winter and I also had a back blade attached to it at one point. I only had one wide frame, and it was a quiet line, a 1650. I also had some newer MTD made Cubs, from the mid 1990s, and one lawn tractor from the mid 1980s. I have a fondness for the IH made Cubs, they were great machines, especially the late 1970s, early 1980s red 82 series Cub Cadets that were still IH made. Unfortunately, like a lot of lawn and garden tractors today, the last 20 years or so, the Cub Cadets just aren't as good as the IH made and the early MTD ones. They don't really have a true garden tractor, in my opinion. Sad. Share this post Link to post Share on other sites
