sqrlgtr 3,598 #1 Posted January 9 I'm on the trail of a 520HC. I know (I think I know) that the C stands for Commercial and was hoping some on here could tell me what are if there is any advantages are there over the 520H. I seem to remember maybe a faster trans are sumin along the lines of that and swept forward front axle, heavier brgs. It supposedly ran strong when parked but I can already tell the wiring is fubar so would be purchasing not running so cant tell anything about the hydro. either. Share this post Link to post Share on other sites
Sparky-(Admin) 26,185 #2 Posted January 9 Yep, it’s supposed to be geared for faster ground speeds over a regular 520-H. Not sure what the other differences are. Hope ya score it!! 2 Share this post Link to post Share on other sites
ebinmaine 80,083 #3 Posted January 10 I'd look at any non runner as a Parts pile unless it can be proven to run... IF it's original and complete it has value in the Rear wheels. $150 + Splayed forward front axle. $300 + Gear reduction steering system. $125 - $150 + The Eaton 1100 transmission is known to be the HD of the Wheelhorse world. Add to that being an HC with the higher top speed. Gotta be a $150+ transmission alone. Then all the other various other things..... I'd say with confidence any price below $700 is a win. That gives you fair recovery of investment. Share this post Link to post Share on other sites
pfrederi 20,992 #4 Posted January 10 HC Commercial...was it used by a pro landscaper??? How many hours. Ran strong when parked ...Ok why was it parked. A Sounds like ran the last time we used it...and other auctioneer BS 2 Share this post Link to post Share on other sites
cafoose 3,785 #5 Posted January 10 1 hour ago, sqrlgtr said: I'm on the trail of a 520HC. I know (I think I know) that the C stands for Commercial and was hoping some on here could tell me what are if there is any advantages are there over the 520H. I seem to remember maybe a faster trans are sumin along the lines of that and swept forward front axle, heavier brgs. It supposedly ran strong when parked but I can already tell the wiring is fubar so would be purchasing not running so cant tell anything about the hydro. either. Don't come get mine If you need any help with it or info I got mine several years ago with a twin bagger, 48 inch deck, and a Ber Vac snow thrower for $800 running @Ed Kennell got the Ber Vac from me and sold it recently. Don't need that here 1 Share this post Link to post Share on other sites
c-series don 12,309 #6 Posted January 10 (edited) I have a 418-C, it has the same transmission as the 520-HC. It is noticeably faster than my other hydros. I really noticed this a few weeks ago while plowing snow. Edited January 10 by c-series don 3 1 Share this post Link to post Share on other sites
ebinmaine 80,083 #8 Posted January 10 So, given that the above listing shows 1990 last. What percentage of 520HC had the splayed forward front axle? 1 Share this post Link to post Share on other sites
lynnmor 8,970 #9 Posted January 10 They had a larger air filter and the seat mount went up under the console plate to catch a second screw. The later 520H had the same seat mount. The HC models weren't as fancy using less chrome. 2 1 Share this post Link to post Share on other sites
kpinnc 18,853 #10 Posted January 10 3 hours ago, ebinmaine said: What percentage of 520HC had the splayed forward front axle? I think they all had it. That was the first model to use the swept axle, heavy duty front end. The 520-H came with it after 1990. 1 1 Share this post Link to post Share on other sites
mrc 1,108 #11 Posted January 10 everything said above. plus, the 520HC has a couple less dash guages i believe 1 1 Share this post Link to post Share on other sites
Handy Don 17,192 #12 Posted January 10 (edited) 13 hours ago, kpinnc said: I think they all had it. That was the first model to use the swept axle, heavy duty front end. The 520-H came with it after 1990. “HCs” all had swept axles, but not reduction steering. The faster speed came from a slightly higher final gear ratio in the transaxle--the Eaton was the usual 1100. Edited January 10 by Handy Don 2 Share this post Link to post Share on other sites
PWL216 1,262 #13 Posted January 10 The 520HC’s are 1988 and 1989 models. They had swept axle and std steering. To my knowledge no HC’s had gear reduction steering. 1991 was the first year gear reduction steering was offered. Share this post Link to post Share on other sites
Brockport Bill 2,448 #14 Posted January 10 the 520 hc is either 88-89 model -- has various features different than the H -- we located 2 a few years ago - one we sold, the other went to my grandson after we did some cleanup, rehab, fresh paint some places, plus maintenance on it - carb, manifold gasket, fuel pump etc - he uses to mow and plow snow plus decided to drive to school one day - typical of onans they need some TLC but it is an impressivce machine. Tractordata.com or toro online has some info - i have also attached some photos of the WH brochure from 1989 that includes the HC model - eg: the HC was 1.1 mph faster top speed than the H -- enjoy, Bill 4 1 Share this post Link to post Share on other sites
Lee1977 7,744 #15 Posted January 10 (edited) 16 hours ago, c-series don said: I have to 418-C, it has the same transmission as the 520-HC. It is noticeably faster than my other hydros. I really noticed this a few weeks ago while plowing snow. The hydro gearing on a HC is 22 to 44 reduction is 2 to 1. The 520-H is 20 to 46 reduction is 2.3 to 1. Edited January 10 by Lee1977 3 Share this post Link to post Share on other sites
