wheelhorsejoe 4 #1 Posted January 8 (edited) Hi I am wondering how to set the float level on a Walbro WHG with this type of float . the float seats recessed into the carb when installed? Thank you Joe PS Edited January 9 by wheelhorsejoe not enought correct info Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #3 Posted January 9 Can you place a nut over the center plastic rivet and hold the float with a pair of Channel locks over the nut? It will not take much to bend the float tab but you don't want to stress the plastic rivets. Share this post Link to post Share on other sites
pfrederi 21,046 #4 Posted January 9 What is this carb on? Share this post Link to post Share on other sites
sqrlgtr 3,701 #5 Posted January 9 20 hours ago, wheelhorsejoe said: Hi I am wondering how to set the float level on a Walbro WHG with this type of float . the float seats recessed into the carb when installed? Thank you Joe What makes you think it needs setting? I have found pretty good amount of lee way on floats in these types carbs. If I don't know what to set them at I always just go for level all way round top of carb. Now dual webers on a VW bug different story 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,451 #6 Posted January 10 Section 6 Page 18 covers the float. 1 Share this post Link to post Share on other sites
wheelhorsejoe 4 #7 Posted January 10 On 1/9/2026 at 1:34 PM, gwest_ca said: Can you place a nut over the center plastic rivet and hold the float with a pair of Channel locks over the nut? It will not take much to bend the float tab but you don't want to stress the plastic rivets. Thank You, What I want to know is the proper setting /adjustment specification for the carb. Share this post Link to post Share on other sites
wheelhorsejoe 4 #8 Posted January 10 On 1/9/2026 at 1:52 PM, pfrederi said: What is this carb on? Wheelhorse 414-8 with a Kohler 14hp Magnum engine. Share this post Link to post Share on other sites
wheelhorsejoe 4 #9 Posted January 10 17 hours ago, gwest_ca said: Section 6 Page 18 covers the float. Thank You. Yes those settings are for a kohler carb not for a Walbro carb I can't find any settings for a Walbro carb. Share this post Link to post Share on other sites
wheelhorsejoe 4 #10 Posted January 10 23 hours ago, sqrlgtr said: What makes you think it needs setting? I have found pretty good amount of lee way on floats in these types carbs. If I don't know what to set them at I always just go for level all way round top of carb. Now dual webers on a VW bug different story Thank You. When ever I rebuild a carb I always check and adjust the float settings. I understand that there is lee-way but I try to get as close as possiable to factory settings. Share this post Link to post Share on other sites
pfrederi 21,046 #11 Posted January 10 Page 6-18 Walbro carb Share this post Link to post Share on other sites
