sqrlgtr 3,871 #1 Posted January 6 What are you Wheel Horse pullers using for a clutch spring? Factory #1014, #5714 or sumin else? Share this post Link to post Share on other sites
sqrlgtr 3,871 #2 Posted January 6 I guess I should have listed tractor models 12hp no name-6 and a C160-8 1 Share this post Link to post Share on other sites
ebinmaine 80,660 #3 Posted January 6 For the sake of future record here. On my 1974 C160-8 Cinnamon Horse I have double springs. That tractor pulls some HEAVY trailers. I do use a stock Toro 108035 AND I also wrapped that spring with a larger heavier duty one. 1 Share this post Link to post Share on other sites
Achto 32,650 #4 Posted January 6 (edited) 42 minutes ago, sqrlgtr said: What are you Wheel Horse pullers using for a clutch spring? Factory #1014, #5714 or sumin else? I'm using an off the shelf spring from Ace Hardware on mine. Choose it by the length of my old one but with a heavier gauge wire. Have drug my motor down to it's very last pop several times without slipping the 5/8" wide belt. Edited January 6 by Achto 3 Share this post Link to post Share on other sites
sqrlgtr 3,871 #5 Posted January 6 1 minute ago, Achto said: I'm using an off the shelf spring from Ace Hardware on mine. Choose it by the length of my old one but with a heavier gauge wire. Have drug my motor down to it's last pop several times without slipping the 5/8" wide belt. Good deal I was thinking of taking mine with me to compare. All I here around here is that the belt drive WH cant compete with the Cub clutch drive line but I'm going to try and prove them wrong at least in the factory style classes 1 Share this post Link to post Share on other sites
ebinmaine 80,660 #6 Posted January 7 IMHO in the stock classes a belt drive does just fine. I don't pull for competition. Seen it a couple times. I do pull for livelihood. We tug some trailers full o' wood or logs up the hill outta the forest that are on nasty terrain and well over 1000 lbs. Belt slip is NEVER an issue. 2 Share this post Link to post Share on other sites
Achto 32,650 #7 Posted January 7 1 minute ago, sqrlgtr said: All I here around here is that the belt drive WH cant compete with the Cub clutch drive line but I'm going to try and prove them wrong at least in the factory style classes 3rd place in the points in our club was won by a SimpleCity last year. Running a belt off from a right angle gear box. I.E. SimpleCity stock factory legit. Like I stated, I've drug my stock-ish 14hp down to it's last pop many times. I plan on building a new engine this year. A stock-ish 16hp with a bit more $$ thrown at it. Hopefully I get get a few more pops out of it before it gives up. 3 Share this post Link to post Share on other sites
ebinmaine 80,660 #8 Posted January 7 Just now, Achto said: stock-ish 16hp Keep us posted!! I figure with a head shave and maybe freeing up the valve area the 16 HP should knock out 22 plus easy. 1 2 Share this post Link to post Share on other sites
Achto 32,650 #9 Posted January 7 7 minutes ago, ebinmaine said: Keep us posted!! Will do. I have to get it torn down soon so that parts can get sent out for machining. 1 1 Share this post Link to post Share on other sites
Spareparts 92 #10 Posted January 12 On my pullers I have very good luck with the green Kyvlar belts from Tractor Supply and a little heavier spring, 3 Share this post Link to post Share on other sites
