sqrlgtr 2,300 #1 Posted January 6 The #1014 clutch spring was replaced with #5714 which is a1/2' shorter. My question is which spring would be the stouter of the two. I would think the shorter in length but don't know if they are the same diameter, stiffness, etc. I might should have posted in the puller forum . 1 Share this post Link to post Share on other sites
ebinmaine 77,763 #2 Posted January 6 What model tractor? Share this post Link to post Share on other sites
sqrlgtr 2,300 #3 Posted January 6 73 12hp-6 No name and 74 C160-8. Share this post Link to post Share on other sites
ebinmaine 77,763 #4 Posted January 6 I use a 108035 Available from many online sources. Shop CAREFULLY because price varies a LOT. 1 Share this post Link to post Share on other sites
sqrlgtr 2,300 #5 Posted January 6 @ebinmaine is that a wheel horse part # or?? Those #"s I posted is what I found on Wheel Horse Parts and More., but I don't have to have a Wheel Horse spring if they will work. Share this post Link to post Share on other sites
sqrlgtr 2,300 #6 Posted January 6 Nevr mind I looked it up and it is a WH part # 1 Share this post Link to post Share on other sites
ebinmaine 77,763 #7 Posted January 6 Billsplaceshop.com. has those at $11.99 shipped to your door. Definitely check with Brian Badman. Share this post Link to post Share on other sites
peter lena 9,796 #8 Posted January 7 @sqrlgtr dare I say it ? how bout every related movement point ? penetrating oil first , make the rust run out , then red aerosol spray grease extension tube , total set up smooth / easy . pete 1 1 Share this post Link to post Share on other sites
ebinmaine 77,763 #9 Posted January 7 4 minutes ago, peter lena said: @sqrlgtr dare I say it ? how bout every related movement point ? penetrating oil first , make the rust run out , then red aerosol spray grease extension tube , total set up smooth / easy . pete @sqrlgtr now that Pete's reminded me... Do check your bushings at the pivoterization points. 2 Share this post Link to post Share on other sites
peter lena 9,796 #10 Posted January 7 @sqrlgtr have no clutch jumping at all , and it lasts , my 3 are set up with proven experiments , pete 1 Share this post Link to post Share on other sites
