Bar Nuthin 2,012 #1 Posted Tuesday at 07:01 PM (edited) I never thought much about it until I added a couple of tractors to my collection. My original C-120 still has the stock Nelson Muffler (on a K301) - but it's twice as loud as my other two tractors. C-141 K321 w/stock Nelson muffler '73 No Name K321 with aftermarket muffler (surprisingly, the quietest of all 3) I asked ChatGTP about it and it provided some solutions and a drawing. I really want to keep the Nelson muffler on my C-120. Curious if anyone has successfully operated on one with some success. Here's what AI suggests Repair options (from least invasive to most involved) 1. Internal baffle stabilization (best first step) If the muffler rattles when shaken, this is likely your fix. Method Drill a small access hole (⅜"–½") on the underside Use a stiff wire or rod to confirm loose internals Tack-weld or plug-weld the loose baffle through the hole Weld the access hole shut Result Often restores 70–90% of original quietness Keeps original Nelson muffler intact Invisible once done This is the most common successful repair. 2. Internal repack (moderate skill, very effective) Original Nelsons were not fiberglass-packed like modern mufflers, but adding discreet packing helps. Method Cut a small rectangular access window on the underside Add stainless steel wool or basalt exhaust packing Re-secure internal plates if possible Weld panel back in place and grind smooth Result Significantly deeper, softer exhaust note Slightly quieter than factory Still visually original ⚠️ Do not use household steel wool—it burns quickly. 3. Hidden secondary diffuser (period-safe trick) This avoids opening the muffler at all. Method Insert a short perforated tube or cone into the outlet Secure with a hidden tack weld inside the outlet Paint flat black Result Reduces sharp crack without choking the engine Often used by restorers who want no shell modification 4. Full internal rebuild (maximum effort) Only worth it if originality matters greatly. Method Split the muffler along a seam Recreate baffles from stainless sheet Weld back together and refinish Result As quiet as new Labor-intensive but museum-grade What not to do ❌ Don’t drill random holes (makes it louder) ❌ Don’t stuff fiberglass loosely (blows out fast) ❌ Don’t neck down the outlet (hurts K-301 breathing) ❌ Don’t assume “they were always loud” — they weren’t A healthy Nelson on a K-301 should be deep and mellow, not sharp. Edited Tuesday at 07:02 PM by Bar Nuthin 2 Share this post Link to post Share on other sites
squonk 45,043 #2 Posted Tuesday at 07:35 PM Check your timing. 1 1 Share this post Link to post Share on other sites
Bar Nuthin 2,012 #3 Posted Tuesday at 07:43 PM (edited) 11 minutes ago, squonk said: Check your timing. Interesting, as I do have a frequent backfire (through the exhaust) when I shut off the engine. Related possibly Edited Tuesday at 07:47 PM by Bar Nuthin Share this post Link to post Share on other sites
Handy Don 15,542 #4 Posted Tuesday at 08:00 PM 7 minutes ago, Bar Nuthin said: backfire (through the exhaust) Backfire is unburned fuel entering the exhaust system and burning/expanding really fast (kinda explosive). NOT good for mufflers. Interestingly, the 1990 small engine pollution abatement rules caused many engine makers to put solenoid valves on their carburetors to instantly shut off fuel when the engine is switched off. Absent one of these, as long as an engine was spinning it’d draw fuel even with no spark. That fuel would go out the exhaust as a pollutant. To lessen “spinning with no spark” is one reason for bringing an older engine to idle before shutting it down. 1 1 Share this post Link to post Share on other sites
kpinnc 16,474 #5 Posted Tuesday at 08:17 PM (edited) I have a K301 that runs great but is stupid loud even with a new muffler. Much louder than a 14 or even FILs 16hp. Valve adjustment made no difference. Figured I'd have to go into it to figure it out... Edited Tuesday at 08:17 PM by kpinnc 3 Share this post Link to post Share on other sites
squonk 45,043 #6 Posted Tuesday at 08:58 PM I've had a couple of tractors that were stupid loud. Timing was advanced on both. Engine was laboring a little . Setting the timing helped some 2 Share this post Link to post Share on other sites
ebinmaine 76,382 #7 Posted Wednesday at 12:02 AM 3 hours ago, Handy Don said: . To lessen “spinning with no spark” is one reason for bringing an older engine to idle before shutting it down. Idle for a minimum 10 seconds. Turn off engine. IMMEDIATELY bring throttle right to FULL. No more backfires. @wallfish I believe, taught me that gem originally. I do not recall WHY it works. Maybe @Handy Don can elaborate. 1 Share this post Link to post Share on other sites
Handy Don 15,542 #8 Posted Wednesday at 02:07 AM 1 hour ago, ebinmaine said: Idle for a minimum 10 seconds. Turn off engine. IMMEDIATELY bring throttle right to FULL. I can only guess that the suddenly open throttle significantly leans out the fuel in the “last gasps” of the engine. No fuel; no bang. 1 Share this post Link to post Share on other sites
kpinnc 16,474 #9 Posted Wednesday at 04:31 AM 8 hours ago, Handy Don said: To lessen “spinning with no spark” is one reason for bringing an older engine to idle before shutting it down. Agreed. Carbon inside your muffler is glowing hot during operation, and will cause a backfire rather consistently. Idling down works very well to reduce this for sure. 1 Share this post Link to post Share on other sites
oliver2-44 11,133 #10 Posted Wednesday at 04:43 AM Attempting to weld on an old muffler is challenging since everything is rusty and thin. Time for a new muffler. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,253 #11 Posted Wednesday at 11:21 AM I still like those old gravely mufflers style. I know they’re not like the originals, but it’s much quieter than the screw on type from Kohler. Those are really loud. And of course they’re a bit ugly. Definitely no style points there. I have two engines using those. 1 Share this post Link to post Share on other sites
Bar Nuthin 2,012 #12 Posted Wednesday at 01:47 PM 2 hours ago, Retired Wrencher said: I still like those old gravely mufflers If you get a chance, post a picture of how you have them installed. Thanks! Share this post Link to post Share on other sites
Kenneth R Cluley 654 #13 Posted Wednesday at 02:12 PM Definitely don't care for the "steel wool" suggestion in the drawing. That won't last long. We used to use fiberglass, hence the term "Glasspack Muffler" That didn't last very long either. Maybe stainless or copper gauze? 1 Share this post Link to post Share on other sites
ebinmaine 76,382 #14 Posted Wednesday at 02:15 PM 26 minutes ago, Bar Nuthin said: If you get a chance, post a picture of how you have them installed. Thanks! You could do a quick search for a couple of mine. My 1975 C160 Automatic & The Ugly Bruce tractor both have one of those Gravely mufflers. I leave them on the outside because I don't like having the heat next to the fuel pump and carburetor. But you could definitely use one in the stock location if you were handy with a welder. 1 Share this post Link to post Share on other sites
Bar Nuthin 2,012 #15 Posted Wednesday at 03:19 PM 1 hour ago, Kenneth R Cluley said: Definitely don't care for the "steel wool" suggestion in the drawing. That won't last long. We used to use fiberglass, hence the term "Glasspack Muffler" That didn't last very long either. Maybe stainless or copper gauze? In the text, it cautions against regular steel wool and suggests stainless steel wool or basalt exhaust packing. Not sure what basalt exhaust packing is. Looks similar to insulation. Basalt Silencer and Exhaust packing sound insulation from Merlin Motorsport 1 Share this post Link to post Share on other sites
Bar Nuthin 2,012 #16 Posted Wednesday at 03:36 PM 1 hour ago, ebinmaine said: The Ugly Bruce tractor Looks like Ugly Bruce is a stack setup. I wouldn't be opposed to that! I'm most likely going to take the following steps in order Check/adjust timing Slightly richen the low idle mixture If no improvement... (both of these things I did when I got the tractor) Pull the head for inspection and cleaning Check valve adjustment If still excessively loud... Pull the muffler and decide if it can be reworked or gets replaced 1 Share this post Link to post Share on other sites
ebinmaine 76,382 #17 Posted Wednesday at 03:39 PM 2 minutes ago, Bar Nuthin said: Ugly Bruce is a stack setup Cinnamon is a stack. The Ugly Bruce is a red tractor. 1 Share this post Link to post Share on other sites
Bar Nuthin 2,012 #18 Posted Wednesday at 03:49 PM 8 minutes ago, ebinmaine said: Cinnamon is a stack. The Ugly Bruce is a red tractor. You must use a database to keep track of all your stuff 1 Share this post Link to post Share on other sites
ebinmaine 76,382 #19 Posted Wednesday at 03:58 PM 8 minutes ago, Bar Nuthin said: You must use a database to keep track of all your stuff In fact, yes. This is just a small part of the list. 1 Share this post Link to post Share on other sites
adsm08 3,966 #20 Posted yesterday at 12:31 AM On 1/6/2026 at 3:00 PM, Handy Don said: Interestingly, the 1990 small engine pollution abatement rules caused many engine makers to put solenoid valves on their carburetors to instantly shut off fuel when the engine is switched off. Equally interesting is that these solenoids, at least the OE version, can frequently only be bought with a whole carb, and are easily and cheaply replaced with a regular bowl bolt. 2 1 Share this post Link to post Share on other sites
ebinmaine 76,382 #21 Posted yesterday at 12:36 AM 5 minutes ago, adsm08 said: Equally interesting is that these solenoids, at least the OE version, can frequently only be bought with a whole carb, and are easily and cheaply replaced with a regular bowl bolt. Interesting info there. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,253 #22 Posted 14 hours ago 21 hours ago, Bar Nuthin said: If you get a chance, post a picture of how you have them installed. Thanks! 1 Share this post Link to post Share on other sites
Retired Wrencher 6,253 #23 Posted 14 hours ago Just now, Retired Wrencher said: Here you go Bar Nutin 1 Share this post Link to post Share on other sites
adsm08 3,966 #24 Posted 2 hours ago 22 hours ago, ebinmaine said: Interesting info there. A few years back my neighbor inherited a Cub with a twin cylinder Briggs (I think, it may have been a vertical shaft Kholer). It had sat for a number of years while the previous owner was in poor health and it wouldn't run. After some screwing around I determined that the fuel shutoff solenoid was bad and wouldn't retract. We went to the local mower service shop, a real family-owned place that actually fixes them and were told that the OE only serviced it with a whole carb that was $120, and the alternative was a solenoid from another brand of engine that might work, had a two-week lead time on ordering it, and might not work. We went home, and I started pondering, and digging, and found a Briggs carb kit that I had, which had a bowl bolt in it that was the correct length and thread. Tractor ran just fine with that in it until he hooked the battery up backwards and fried the control board for the safeties. 2 Share this post Link to post Share on other sites
Handy Don 15,542 #25 Posted 1 hour ago (edited) So the bolt replaced the solenoid valve? I’m thinking a spring-loaded needle pulled open when powered so with the bolt it was “always open”? It amazes me that a couple of $1 diodes could completely protect the electronics from reversing the battery cables but they aren’t there. Edited 1 hour ago by Handy Don 1 Share this post Link to post Share on other sites
