Ryan61 0 #1 Posted January 4 I have a c160 with chopped wiring and it has a 12 horse kholer with a starter generator any pictures for how to rewire it i would appreciate it Share this post Link to post Share on other sites
ebinmaine 81,281 #2 Posted January 5 What's the model number of the C160? You'd need to know if it was originally a Kohler engine or a Tecumseh. Share this post Link to post Share on other sites
Ryan61 0 #3 Posted January 5 1016291or 103809 these are the 2 numbers that I can read on the frame tag Share this post Link to post Share on other sites
ebinmaine 81,281 #4 Posted January 5 15 minutes ago, Ryan61 said: 1016291or 103809 these are the 2 numbers that I can read on the frame tag 103809 would be separated out a little to: 1 0380 9. Possibly with - in between. Either way that codes to a 1974 C160-8 with a Kohler engine. If you have a starter/generator in there then the engine is 1967 or older. Rare early 68s has them. If you follow the wiring harness for a 1967 model 1067 or 1267 it should work. 1 Share this post Link to post Share on other sites
Bar Nuthin 3,645 #5 Posted January 5 Closest I can find with your numbers is 74 C-160 8 Speed. Not sure if the wiring diagrams will help you since it obviously doesn't have the original engine. Tractor 1974 C-160 OM Wiring Revised.pdf - 1973-1977 - RedSquare Wheel Horse Forum Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #6 Posted January 5 Hope you have a starter solenoid and battery ignition. If you do not know we can explain. This diagram does not have a solenoid. What ignition switch do you have? Describe Share this post Link to post Share on other sites
953 nut 70,653 #8 Posted January 5 (edited) The most effective way out of your dilemma in my opinion would be to buy a 103-990 ignition switch and a solenoid and follow the diagram below. Hope this is what you need, let us know if you have other questions. Edited January 5 by 953 nut fat finger 3 Share this post Link to post Share on other sites
