Mike.s 2 #1 Posted January 2 Hi, I am looking for a detailed schematic for my 1972 wheel horse GT – 14. All I seem to find are small simplified schematics that only show the ignition switch and the battery and a few other things. I want to see the ignition coil, points, and condenser and ignition stuff. all of the parts and wires if possible. Thank you very much for any help you can provide! Share this post Link to post Share on other sites
Achto 31,794 #2 Posted January 2 4 hours ago, Mike.s said: I want to see the ignition coil, points, and condenser and ignition stuff. All of this stuff would be in the Kohler manual. did not provide manuals for the engines. They relied on the engine manufacturer to provide this info. https://resources.kohler.com/power/kohler/enginesUS/pdf/tp_2379.pdf Share this post Link to post Share on other sites
953 nut 66,044 #3 Posted January 2 If your GT-14 has battery powered ignition with points and a condenser the wiring has been modified which is no problem, many have been rewired. We would need some information from your present ignition switch unless you plan to replace it. There should be a number on it like 103-990 ore something along those lines. If you can't find a number on it perhaps you could do a drawing of the switch with the letters that are stamped on the tabs the wires are connected to (or on the body next to them). With that information we will be able to present you with a wiring diagram. Your drawing should look somewhat like the ones below. 1 Share this post Link to post Share on other sites
pfrederi 20,532 #4 Posted January 2 If you r GT-14 has a breakerless igniton (look for a triangular shaped coil that feeds the spark plug ) you have to use the magneto wiring above. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,233 #5 Posted January 3 Believe this would have been the original switch. Click on the picture for more. The engine would be K321S-60149A Sorry we do not have an original wiring diagram but other models at the time may be similar. Share this post Link to post Share on other sites
953 nut 66,044 #6 Posted January 3 @Mike.s, some members are asking about the possibility of your ignition system being the original trigger type ignition as apposed to the battery type with a conventional ignition coil. From your first post I think it is a battery system but others are thinking trigger so please look at the pictures below and let us know what ignition system you have. Share this post Link to post Share on other sites
squonk 46,550 #7 Posted January 3 (edited) My 69 GT-14 had the breaker less style ignition. You pretty much need the Kohler manual for that part. The one wire running to the switch is a grounding wire like a Magneto uses. The key turned to off grounds the wire and grounds out the ignition. ( DO NOT APPLY 12 VOLTS TO THE COIL!!) Edited January 3 by squonk Share this post Link to post Share on other sites
Mike.s 2 #8 Posted January 4 Wow, thanks for all the informative replies. That Kohler manual really has al the detail. Awesome. My tractor has the battery ignition. I did find out the points were shot, not closing at all so I am getting some new points in. That will help I am sure! Thanks for all the info! 2 Share this post Link to post Share on other sites
953 nut 66,044 #9 Posted January 5 If your GT-14 has a number 103990 ignition switch the diagram below will give you all the wiring answers you need for charging and lights If you have the electric PTO you can run a second wire from the "A" terminal adding a separate 20 amp fuse for the clutch. Share this post Link to post Share on other sites
