AlexR 3,083 #1 Posted December 28, 2025 (edited) So I have been working on getting my transmission that has been apart for 6 months together again. Been waiting on parts. So while I was sorting everything out again I noticed I don't have a thrust bushing for the mushroom gear, I don't believe I ever did. So I noticed in the manual it says on the 8 speeds to install thrust bushing if it had one. Meaning some don't? And the second thing I noticed is the 6 speeds don't show any thrust bushing for the mushroom gear shaft. Unless I am mistaken the 5073 has a unique mushroom gear as in it's all one piece but doesn't have the extra length the 6 speeds do for brake drum. It appears the 8 speeds it's a 2 piece unit. Do I worry about getting a bushing or just run it since it doesn't seem it ever had one? I don't see any practical way to measure any play on the mushroom gear with the cases together either. Edited December 28, 2025 by AlexR Share this post Link to post Share on other sites
Handy Don 17,171 #2 Posted December 28, 2025 I can only note that the 5073 was a unicorn transition item. It had what became the “8-speed" case but with a limited slip differential. Since the brake drum had moved to the other shaft, the ‘shroom shaft had to be shorter to stay inside the casing wall and not interfere with the brake! My personal opinion is that the engineers decided the LSD was simply not strong enough to be a real market factor, especially on higher horsepower/heavier tractors and that the extra strength of the shaft-mounted pinion gears was better in the long haul. A further plus to the brake drum move was the faster-spinning brake drum that allowed somewhat better brake modulation! 3 1 Share this post Link to post Share on other sites
AlexR 3,083 #3 Posted December 28, 2025 Well if I had done my due diligence and finished reading the manual It answers my question on Disassembly part 13. "Remove the reduction gear assembly. NOTE: Prior to 1973 models the gear and thrust washer was welded together and was serviced as one part. Starting with the 1973 models the pinion, reduction gear and thrust washer are serviced separately. The thrust washer goes on the stub shaft next to the big gear. The gear and pinion may be pressed in and out of the gear with a suitable arbor press." 2 1 Share this post Link to post Share on other sites
ebinmaine 80,068 #4 Posted December 28, 2025 1 hour ago, AlexR said: 1973 Is also the changeover from Limited Slip Differential to the Open Differential. 3 Share this post Link to post Share on other sites
AlexR 3,083 #5 Posted December 28, 2025 (edited) I do have one more question so one of my axles is fairly worn at the snap ring I will try to make it work with a snap ring. But if not, can I do a roll pin? does the 1.5" long roll pin interfere with the limited slip circle spring? I would probably do a 3/16 or possibly a 1/8 dia roll pin. Edited December 28, 2025 by AlexR Share this post Link to post Share on other sites
ebinmaine 80,068 #6 Posted December 28, 2025 I can't remember if there's enough space inside the Differential for a roll pin.... IMHO you be better off getting a known good axle from one of the Redsquare vendors. 2 Share this post Link to post Share on other sites
pfrederi 20,992 #7 Posted December 28, 2025 Some earlier WH gear trannys 5053 did use a roll pin. you have to get the hole really close the end of the axles. 1/4 1-1/2" is the pin. Share this post Link to post Share on other sites
Handy Don 17,171 #8 Posted December 28, 2025 13 hours ago, AlexR said: I do have one more question so one of my axles is fairly worn at the snap ring I will try to make it work with a snap ring. But if not, can I do a roll pin? does the 1.5" long roll pin interfere with the limited slip circle spring? I would probably do a 3/16 or possibly a 1/8 dia roll pin. I have no direct knowledge on this point, as do the above posters! Be aware, though, that the pinion gears in the LSD “float" within their pockets of the diff bodies. The movement isn’t large but it is real. Factor that into your thinking! Share this post Link to post Share on other sites
AlexR 3,083 #9 Posted January 3 Pulled the trigger on some axles they have like new keyways and snap ring grooves. But unfortunately they had surface rust which for most of it doesn't matter but the bearing and seal areas are what I'm concerned about. This first photo is of one I cleaned up about halfway compared to the way I got it on the other axle. All the way cleaned up sanded and sanded with 2000 grit sandpaper and then Dremel polished the bearing and seal area. What do you think? The extra shiny area on the left axle is were some paint was. 4 Share this post Link to post Share on other sites
Handy Don 17,171 #10 Posted January 3 The surface isn’t as critical as the diameter and roundness. Both bearing surfaces must ride snugly n the inner rings of their respectve ball bearings where looseness can cause trouble. Get out your calipers! 3 Share this post Link to post Share on other sites
stevasaurus 23,781 #11 Posted January 3 I think you will be fine with those axles. While the spider gears do float, there is not as much free space as you would expect. When you put it back together, you will see what I mean. Those pinions actually support the axle gear. 2 1 Share this post Link to post Share on other sites
AlexR 3,083 #12 Posted January 10 (edited) I'm ready to get my bearings installed, on the outer axle bearings how far in do those get installed? Just far enough in to get the seal in, or to the end of the machined surface? My understanding on the rest of the bearings they should be just barely flush with the inside of the transmission. And the second question is do you guys install seals after the shafts are on or before? Edited January 10 by AlexR Share this post Link to post Share on other sites
pfrederi 20,992 #13 Posted January 10 Enough for the seal and a bit extra. Seals after assembly...make sure yo cover the key way with some electrical tape to protect the seal 1 2 Share this post Link to post Share on other sites
kpinnc 18,851 #14 Posted January 10 On 12/27/2025 at 10:53 PM, AlexR said: I do have one more question so one of my axles is fairly worn at the snap ring I will try to make it work with a snap ring. If you know someone with a lathe, you're better off just having the snap ring groove squared back off. I've had this done a couple times because a PO pulled on the hubs without knowing how the axles were retained. Mine have never given any trouble since, and I never have to worry about a pin moving around. 1 1 Share this post Link to post Share on other sites
AlexR 3,083 #15 Posted January 10 Thanks for the help guys transmission is back together and everything is working great. 1 2 Share this post Link to post Share on other sites
AlexR 3,083 #16 Posted January 12 Seals are all in, used electrical tape on the shafts and it worked good! Inspected the hub keyways again and they are all not good I have 2 sets. I am considering getting a broaching set and try that out. So my understanding of that is I need a 1-1/8" collar and a 1/4" broach of those of you who have done that, any tips or tricks or recommendations? 1 Share this post Link to post Share on other sites
ebinmaine 80,068 #17 Posted January 13 28 minutes ago, AlexR said: Seals are all in, used electrical tape on the shafts and it worked good! Inspected the hub keyways again and they are all not good I have 2 sets. I am considering getting a broaching set and try that out. So my understanding of that is I need a 1-1/8" collar and a 1/4" broach of those of you who have done that, any tips or tricks or recommendations? @Achto or @WHX?? 1 1 Share this post Link to post Share on other sites
Achto 32,246 #18 Posted January 13 46 minutes ago, AlexR said: 1-1/8" collar and a 1/4" broach of those of you who have done that, any tips or tricks or recommendations? Cut the new keyway 90 degrees to the old one. Drill & tap a 3/8-24 hole that goes through the new keyway. Use set screws in the old as well as the new hole. 2 Share this post Link to post Share on other sites
WHX?? 57,629 #19 Posted January 13 (edited) 30 minutes ago, ebinmaine said: you who have done that, any tips or tricks or recommendations? Yep bring them to Pullstarts's plow day and Dan will do them for you. If you can catch him before he uncorks at 7 AM that is ... If you don't wanna wait yah a 1 1/8 bushing & 1/4 broach & the 2nd stage spacer. I could send ya the stuff to do it if you wanna pay the mailman. Edited January 13 by WHX?? 1 2 Share this post Link to post Share on other sites
AlexR 3,083 #20 Posted January 13 22 hours ago, WHX?? said: I could send ya the stuff to do it if you wanna pay the mailman. Since I want to get this done for Pullstarts plow day I might have to take you up on this especially if you or Dan have the spindle I need as well. But before we do that, let me check with my neighbor first make sure he doesn't have a broaching set. 1 Share this post Link to post Share on other sites
