Raider69 101 #1 Posted December 27, 2025 (edited) Put a new brake pedal return spring on my '75 B100 Auto a couple weeks ago and when I was done the engine wouldn't crank with the ignition switch. No click, nothing, but I could turn the key to the run position, jump the solenoid and it would start right up and keep running. Switch tested good and I tried another known good one, same for the solenoid. The seat saftey switch was long gone when i got it. I replaced a sketchy looking splice in the lead to the solenoid and also put a new terminal on it. I did find that somewhere in all this the terminal for the battery negative cable had snapped off where it was fastened to the frame so I put a whole new cable on, still nothing. I had continuity across the switch but when I checked from the switch to the solenoid nada. I pulled the rectifier/ammeter mounting plate to take a look at the wiring to the switch from there. Ammeter had been bypassed years ago. I had juice from the switch to the rectifier but nothing to the feed running to the solenoid. I started to suspect the PTO safety switch...... That's when it hit me, I gave the PTO lever a pull and it moved backward, it had gotten bumped forward just enough to break the circuit..... put it all the way back, hit the key and it spun right over. Realizing I'm a moron never felt quite so good LOL. I did however take care of at least 3 future wiring problems so it wasn't a total loss. Thought I'd share that, always make sure everything is in the off position even if you "know" it is. All it took in this case was a few degrees of rotation and my total confidence it was an actual electrical issue.. Edited December 27, 2025 by Raider69 10 3 1 1 Share this post Link to post Share on other sites
squonk 45,379 #2 Posted December 27, 2025 Technically you didn't really have a problem and found 2 that you didn't know you had! 1 3 Share this post Link to post Share on other sites
Bar Nuthin 2,167 #3 Posted December 27, 2025 Sounds like a good post for Note to Self thread 2 3 Share this post Link to post Share on other sites
Raider69 101 #4 Posted December 27, 2025 30 minutes ago, squonk said: Technically you didn't really have a problem and found 2 that you didn't know you had! Yep, and those problems probably would have popped up when I had 12 inches of snow to move in 10 degree weather and 25MPH wind gusts. I never gave the PTO a thought before today because I haven't used it in 10 years, I only use the tractor to plow snow. Now I hope the transmission problem on the Raider 12 I bought last week is something that simple. When we got it off the trailer and I was pushing it to the shed the left rear hub fell off and there was no sign of the key. The PO had rebuilt the trans and the 2nd time he plowed snow with it it quit moving. He thought he snapped the input shaft, I'm more inclined to think it is a key but I was thinking a key inside the trans not he axles. I would think it would have kept moving though as it's a 6 speed with limited slip and unless that key is sheared or missing too it should have transmitted power to that wheel. Assuming the LSD is working properly that nis. Share this post Link to post Share on other sites
Handy Don 15,756 #5 Posted December 27, 2025 31 minutes ago, Raider69 said: I would think it would have kept moving though as it's a 6 speed with limited slip and unless that key is sheared or missing too it should have transmitted power to that wheel. Assuming the LSD is working properly that nis. The LSD is not really strong enough to overcome a missing key--“limited” being the operative word. In my experience, it is best thought of as a nice assist in “iffy” traction situations by giving some power to the low traction wheel. Worth noting is that the heavier duty JDs of the era (e.g the 318) featured dual braking or an actual differential lock. 2 Share this post Link to post Share on other sites
Ed Kennell 44,667 #6 Posted December 27, 2025 Some have told me that this same no crank problem occurs when they run out of fuel while mowing. 1 1 5 Share this post Link to post Share on other sites
Wishin4a416 2,467 #7 Posted December 27, 2025 Dont be so hard on yourself. We all have senior moments. At least I do. 3 Share this post Link to post Share on other sites
Blasterdad 3,163 #8 Posted December 27, 2025 1 hour ago, Ed Kennell said: Some have told me that this same no crank problem occurs when they run out of fuel while mowing. Guilty 1 Share this post Link to post Share on other sites
Raider69 101 #9 Posted December 28, 2025 2 hours ago, Handy Don said: The LSD is not really strong enough to overcome a missing key--“limited” being the operative word. In my experience, it is best thought of as a nice assist in “iffy” traction situations by giving some power to the low traction wheel. Worth noting is that the heavier duty JDs of the era (e.g the 318) featured dual braking or an actual differential lock. I wondered about that, I haven't had a functioning WH with limited slip in a long time. I vaguely recall my old Raider 9 didn't work all that great. 1 Share this post Link to post Share on other sites
953 nut 63,984 #10 Posted December 28, 2025 1 hour ago, Ed Kennell said: they run out of fuel while mowing. and then go to the shed bringing back some gas but not moving the PTO to off and deciding the battery or starter system must be the problem. @Ed Kennell, isn't that the rest of the story as you told it a few years ago? 3 2 Share this post Link to post Share on other sites
Ed Kennell 44,667 #11 Posted December 28, 2025 20 minutes ago, 953 nut said: @Ed Kennell, isn't that the rest of the story as you told it a few years ago? "And now you know the rest of the story" PH 2 1 1 Share this post Link to post Share on other sites
kpinnc 17,031 #12 Posted December 29, 2025 On 12/27/2025 at 3:13 PM, Raider69 said: Realizing I'm a moron never felt quite so good LOL. Added to the long list of personal T-shirt slogans... If I had just a nickel for every time I felt this way, I would have alot of nickels! 2 Share this post Link to post Share on other sites
