Krice58 165 #1 Posted December 26, 2025 ‘75 C160 Auto 71128a spec K341. Throttle cable opens the throttle fine, but does not return to low idle on its own. I’ll include a video below. Am I missing something? Cable just worn out? Governor settings wrong? It’s been like this for as long as I can remember and I’m trying to fix it. Carb has been changed to one of the copies from IST a few years ago. Cable is original. IMG_9186.mov Share this post Link to post Share on other sites
Krice58 165 #2 Posted December 26, 2025 IMG_9186.mov Share this post Link to post Share on other sites
ebinmaine 79,716 #3 Posted December 26, 2025 I made this a few years ago for this same type of question. Just realized the video has 875 views so obviously it's a common enough issue. 3 Share this post Link to post Share on other sites
Krice58 165 #4 Posted December 26, 2025 11 minutes ago, ebinmaine said: I made this a few years ago for this same type of question. Just realized the video has 875 views so obviously it's a common enough issue. Looks like my bell crank might be positioned wrong. It doesn’t move the same way yours does. The cable on mine is pretty nasty too. I know I have one from a ‘77. I would imagine it would be the same. Thanks! 1 Share this post Link to post Share on other sites
Bar Nuthin 2,636 #5 Posted December 26, 2025 @Krice58 It looks like you need to loosen the cable where it attaches to the bell crank and give a 1/4" more of relief. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,363 #6 Posted December 26, 2025 Suspect there is no casing support near the end of the cable. When you pull on the core the casing can't move because the coils are wound tight. When you push on the core the casing stretches like a spring losing the corer's effectiveness. 1 Share this post Link to post Share on other sites
peter lena 9,949 #7 Posted December 26, 2025 @Krice58 have pull return springs on every cable , on 3 tractors , also have SUBER LUBE inside every cable , have it so cable assist to close is what you want , that way , any related movement is cable assisted , TO CLOSE , STOP . another thing I added was perforated metal tabs in easy pull points , that eliminates a lot of confusion , those metal tabs clear things up . https://www.metalsdepot.com/steel-products/steel-perforated-sheet can often get a small strip at big box stores , whit this you can bolt to any larger bolt , with bigger hole trim . done a lot of it, makes things quickly in sight , pete 1 Share this post Link to post Share on other sites
Ed Kennell 46,607 #8 Posted December 26, 2025 I don't see where the throttle cable sheath is fastened. It needs to be clamped near the end. 1 Share this post Link to post Share on other sites
Krice58 165 #9 Posted December 26, 2025 1 hour ago, gwest_ca said: Suspect there is no casing support near the end of the cable. When you pull on the core the casing can't move because the coils are wound tight. When you push on the core the casing stretches like a spring losing the corer's effectiveness. Toward the end of the cable the casing is definitely pretty nasty looking. 1 Share this post Link to post Share on other sites
Krice58 165 #10 Posted December 26, 2025 2 hours ago, Bar Nuthin said: @Krice58 It looks like you need to loosen the cable where it attaches to the bell crank and give a 1/4" more of relief. So more slack on the cable? Or pull it tighter? Share this post Link to post Share on other sites
Krice58 165 #11 Posted December 26, 2025 33 minutes ago, Ed Kennell said: I don't see where the throttle cable sheath is fastened. It needs to be clamped near the end. It’s hard to see but it is clamped to the valve cover under the fuel bowl. 1 Share this post Link to post Share on other sites
sqrlgtr 3,293 #12 Posted December 27, 2025 Hope this might help. Here is a pic of my c160 throttle cable, and governor set up, works great. 2 Share this post Link to post Share on other sites
Bar Nuthin 2,636 #13 Posted December 27, 2025 1 hour ago, Krice58 said: So more slack on the cable? Or pull it tighter? More slack Share this post Link to post Share on other sites
sqrlgtr 3,293 #14 Posted December 27, 2025 The one pic looks like the throttle cable may be rubbing governor arm, might be holding it not letting it idle down? 2 Share this post Link to post Share on other sites
Krice58 165 #15 Posted December 27, 2025 3 hours ago, Bar Nuthin said: More slack That helped considerably. Still not perfect but better than it was. I just think the cable is corroded pretty bad inside. 1 Share this post Link to post Share on other sites
ebinmaine 79,716 #16 Posted December 27, 2025 7 hours ago, Krice58 said: cable is corroded If the cable has no kinks in it and a little extra length you could probably save it if you remove the sheath and sand the inside cable followed by an oil soaking. Remove the engine end and all the holding points. You might be able to leave it attached to the dash depending on how you need to detach the sheath on that end. On the big block Kohler engines the cable should be straight. No Z bend or any sharp bends anywhere. 2 Share this post Link to post Share on other sites
sqrlgtr 3,293 #17 Posted December 27, 2025 @Krice58 I forgot that I had a governor arm and bushing that was sticking a while back and had to take governor arm and bushing off and clean them up good. Just a thought.. 1 Share this post Link to post Share on other sites
peter lena 9,949 #18 Posted December 27, 2025 @Krice58 another vital I do in every / any set up , is to verify each stage , you definitely have a COLLECTIVE AMOUNT OF ISSUES , there is just so much thats wrong in your set up , do you have any cable that works / slides easily ? that would be my start point on every spot . have nothing that hangs up or works with issues , everything SEPEREATLY MOVES WITH EASE , and a spring to close / idle setting , hope you get some help , pete 1 Share this post Link to post Share on other sites
WHX?? 57,456 #19 Posted December 27, 2025 (edited) There is supposed to be a cable clamp on the nut that holds the breather cover on. A 1/4-20 coupling nut on the breather stud with a machine screw holding the clamp on works well and spaces the cable out a bit. Got a pic of it in here ... somewhere ... Here it is on @Achto 's 1076 Never mind looks like you have it but check the bell cranks for binding. Maybe try resetting the governor. That should be done once in awhile anyway. Edited December 27, 2025 by WHX?? 2 Share this post Link to post Share on other sites
peter lena 9,949 #20 Posted December 27, 2025 @Krice58 https://www.walmart.com/ip/Super-Lube-Multi-Use-Synthetic-Oil-with-Syncolon-PTFE-ISO-100/51777142? use this in all my cables , verify oil in / oil out , incredible temp range , also have a light / medium extension spring to related lever connection ? that constant spring pull to close , is what you want ? spring always assists your movement , quickly went over to this decades ago , with REPEDITIVE ISSUE , personally like those ? they leave a track of HOW ITS FAILING , step by step , then go back and ELIMINATE EVERY hang up point , once cured , go back and see if there is any other issue areas . shop around on the oil , for pricing , walmart usually has it . stay oily , pete 1 Share this post Link to post Share on other sites
Krice58 165 #21 Posted December 28, 2025 Now I have a runaway governor problem. Pretty sure the gear or tab on the cross shaft is broken because when doing the adjustment per the manual the cross shaft spins indefinitely, as I believe it was supposed to stop when the tab would make contact with gear. Looks like it might be time for that engine rebuild as I’m pretty sure most of it’s gotta come apart to change the gear and shaft anyways. Got a K301 I might swap in temporarily so I can still use the tractor. 3 Share this post Link to post Share on other sites
wallfish 20,225 #22 Posted December 28, 2025 8 minutes ago, Krice58 said: Pretty sure the gear or tab on the cross shaft is broken because when doing the adjustment per the manual the cross shaft spins indefinitely Most likely the tab has broken off of the shaft 1 Share this post Link to post Share on other sites
Krice58 165 #23 Posted December 28, 2025 Pulled this sucker out of a 312-8 parts tractor I had. 47812 spec number K301. Tag on the 312 was gone I’m guessing this is mid 80s. Mounting seemed identical to K341, base plate is the same. Should just plug and play correct? Could I use the existing electrical things on my C160? Starter Solenoid? Key switch? It’s old school points like the K341. 1 Share this post Link to post Share on other sites
ebinmaine 79,716 #24 Posted December 28, 2025 Points ignition to Points ignition you should be fine there. What's the wiring connection coming outta the alternator? Same? 1 Share this post Link to post Share on other sites
Krice58 165 #25 Posted December 28, 2025 15 minutes ago, ebinmaine said: Points ignition to Points ignition you should be fine there. What's the wiring connection coming outta the alternator? Same? I don’t see a regulator on the parts tractor? Would it be unregulated? 1 Share this post Link to post Share on other sites
