ANTPER 215 #1 Posted December 26, 2025 Hello. Mounted a plow to a Hydro 518. It will only angle with the lever to my right. It wont angle to left as the angle lever hits foot peg without enough room yo travel. What am I missing? Foot pegs longer on 518 on right? This plow is not original to this 518.TIA Anthony Share this post Link to post Share on other sites
edgcooper 18 #2 Posted December 26, 2025 Heat and bend control lever to increase distance to foot rest. 3 Share this post Link to post Share on other sites
8ntruck 8,575 #3 Posted December 26, 2025 Or maybe plow from the other direction. 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,981 #4 Posted December 26, 2025 The lever is symmetrical so you can turn it around. Would that help? 3 Share this post Link to post Share on other sites
SylvanLakeWH 30,485 #5 Posted December 26, 2025 I have had to bend a couple handles over the years depending on the plow, handle and tractor... 4 Share this post Link to post Share on other sites
ANTPER 215 #6 Posted December 26, 2025 2 hours ago, edgcooper said: Heat and bend control lever to increase distance to foot rest. Was considering cutting a small slot end of foot peg for extra arm swing. Share this post Link to post Share on other sites
Ed Kennell 44,667 #7 Posted December 26, 2025 I have had to turn some levers around, bend some, and put spacers in some to clear foot rests and foot pedals. 2 1 Share this post Link to post Share on other sites
peter lena 9,715 #8 Posted December 26, 2025 @ANTPER have to se your set up , but plows require a detailed set up , makes me wonder about your plow quadrant set up , agree with @Ed Kennell on possibilities , amazing difference when set up correctly , pete 2 Share this post Link to post Share on other sites
953 nut 63,981 #9 Posted December 26, 2025 I do about 90% of my snow plowing to the right, go down, turn around and come back up, repeat, repeat, then turn it back to the mid position to tidy up the turn around area. 1 Share this post Link to post Share on other sites
ANTPER 215 #10 Posted December 26, 2025 5 hours ago, gwest_ca said: The lever is symmetrical so you can turn it around. Would that help? My Man you were right on the money. Yea I flipped handle 180 and works perfect. Thanks very much. 2 3 Share this post Link to post Share on other sites
ANTPER 215 #11 Posted December 26, 2025 Thanks everyone for your input! Anthony 2 Share this post Link to post Share on other sites
