nylyon-(Admin) 8,964 #1 Posted December 26, 2025 I went all out this year, put the snow plow on the 310 and the blower on the 416-8 (Onan). Weather man says up to 8” of the fluffy stuff, thought it would make sense to get the snow blowing tractor to the driveway and it’s a no-start. Cranks fine, have 12v to the coil but no fire. Haven’t checked spark, might just swap the blower onto the 416-H for the storm. 5 Share this post Link to post Share on other sites
Bar Nuthin 2,519 #2 Posted December 26, 2025 2 minutes ago, nylyon said: I went all out this year, put the snow plow on the 310 and the blower on the 416-8 (Onan). Weather man says up to 8” of the fluffy stuff, thought it would make sense to get the snow blowing tractor to the driveway and it’s a no-start. Cranks fine, have 12v to the coil but no fire. Haven’t checked spark, might just swap the blower onto the 416-H for the storm. Fuel shutoff? 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,964 #3 Posted December 26, 2025 No, won’t fire with brake cleaner either. 2 Share this post Link to post Share on other sites
953 nut 66,542 #4 Posted December 26, 2025 6 minutes ago, nylyon said: have 12v to the coil but no fire. Time to check the ignition module. Share this post Link to post Share on other sites
nylyon-(Admin) 8,964 #5 Posted December 26, 2025 That’s my concern 1 Share this post Link to post Share on other sites
Bill D 2,877 #6 Posted December 26, 2025 Take a jumper and connect from the positive terminal on the coil to the positive terminal on the battery. If it starts your problem is probably the 9 pin connector. If you need to do the ignition module its not that hard. Tip: It can be changed without removing the stator. Share this post Link to post Share on other sites
nylyon-(Admin) 8,964 #7 Posted December 26, 2025 Checked for spark, and it had spark so decided to try ether and it fired right up, we’re in business. 2 Share this post Link to post Share on other sites
WHX?? 56,842 #8 Posted December 26, 2025 22 minutes ago, nylyon said: decided to try ether I was just going to suggest that Coach at the risk of forty lashes from the boys. Mine won't fire on brake cleaner either after a sit so out come the hi test salts. Often thought of a small hole in the air cleaner cover for a straw so one doesn't have to take the cover off. Or hand feeding gas right down the pipe. Electric fuel pump would be the best option tho. 2 2 Share this post Link to post Share on other sites
lynnmor 8,839 #9 Posted December 26, 2025 37 minutes ago, nylyon said: Checked for spark, and it had spark so decided to try ether and it fired right up, we’re in business. An Onan that sits for a while takes a lot of cranking till it starts, for some reason the carburetor goes dry in about a week depending on temperatures. A weak fuel pump or slightly leaking fuel lines add to the problem. A full gas tank will help a bit. The best answer is an electric fuel pump or a marine primer bulb to fill the carburetor before cranking. If you use too much starting fluid you can break the ring lands on a piston. 3 Share this post Link to post Share on other sites
nylyon-(Admin) 8,964 #10 Posted December 26, 2025 True, the Hydro has an electric fuel pump, the 8-speed has always started much faster, today was the exception but it has sat for a little bit. I think that adding an electric fuel pump will certainly help though. 4 1 Share this post Link to post Share on other sites
Ed Kennell 46,197 #11 Posted December 26, 2025 1 hour ago, WHX?? said: Often thought of a small hole in the air cleaner cover for a straw so one doesn't have to take the cover off Did this on the lil B&S on the trac vac. I permanently installed a small fuel line as a primer. 3 Share this post Link to post Share on other sites
squonk 46,834 #12 Posted December 26, 2025 Here in NY we call ether "Cosby Sauce" and I have no idea why! My tractors won't start on Brake Cleaner either. mostly because I only get the non flammable type. Almost burned a Lincoln town Car to the ground in my front yard with the flammable variety! 1 7 Share this post Link to post Share on other sites
pfrederi 20,654 #13 Posted December 26, 2025 I use carb cleaner from wally world 4 2 Share this post Link to post Share on other sites
oldlineman 1,734 #14 Posted December 26, 2025 that's what I use if needed, carb cleaner. only needed on 1979 c-101 when sitting a while weak fuel pump, need to get a electric one installed. 1 Share this post Link to post Share on other sites
Ed Kennell 46,197 #15 Posted December 26, 2025 5 hours ago, pfrederi said: I use carb cleaner from wally world X3 2 1 Share this post Link to post Share on other sites
Lagersolut 802 #16 Posted December 27, 2025 This is what I've always used for the hard starts - ether makes me nervous losing a an engine 2 1 Share this post Link to post Share on other sites
SylvanLakeWH 31,521 #17 Posted December 27, 2025 I use gas in a spray bottle. I've never understood using carb cleaner, as it kills my engines when I use it for routine cleaning... 1 Share this post Link to post Share on other sites
pfrederi 20,654 #18 Posted December 27, 2025 2 minutes ago, SylvanLakeWH said: I use gas in a spray bottle. I've never understood using carb cleaner, as it kills my engines when I use it for routine cleaning... Only if you spray in a large amount quickly. All you need for testing is a quick spurt 2 1 1 Share this post Link to post Share on other sites
c-series don 11,963 #19 Posted December 27, 2025 I’m with @SylvanLakeWH on this one. I use gas in a spray bottle with some two cycle oil in it. I only use either on diesel engines. 1 Share this post Link to post Share on other sites
RED-Z06 2,718 #20 Posted December 28, 2025 On 12/26/2025 at 11:25 AM, squonk said: Here in NY we call ether "Cosby Sauce" and I have no idea why! My tractors won't start on Brake Cleaner either. mostly because I only get the non flammable type. Almost burned a Lincoln town Car to the ground in my front yard with the flammable variety! Liquid Summer Canned Head Gasket Remover Canned Rod Bender Cosby Sauce...because the engine goes 3 Share this post Link to post Share on other sites
Retired Wrencher 6,723 #21 Posted December 28, 2025 On 12/26/2025 at 11:18 AM, nylyon said: True, the Hydro has an electric fuel pump, the 8-speed has always started much faster, today was the exception but it has sat for a little bit. I think that adding an electric fuel pump will certainly help though. Karl those fuel E-pumps like this one I have are they to go. Fast start up. 2 Share this post Link to post Share on other sites
nylyon-(Admin) 8,964 #22 Posted December 28, 2025 5 hours ago, Retired Wrencher said: Karl those fuel E-pumps like this one I have are they to go. Fast start up. I have an electric pump on my hydro, absolutely the way to go. I think I have a spare pump in the garage, just have to find it. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,723 #23 Posted December 29, 2025 17 hours ago, nylyon said: I have an electric pump on my hydro, absolutely the way to go. I think I have a spare pump in the garage, just have to find it. Ben there done that. I put all parts in an old furniture cabinet. Saves time and effort. Share this post Link to post Share on other sites
