Sparky-(Admin) 24,071 #1 Posted Sunday at 06:18 PM Starting on the 857’s starter gen repair. The rebuild video on YouTube never mentions the pulley…and tips or tricks to get it off without destroying it? 2 Share this post Link to post Share on other sites
Sparky-(Admin) 24,071 #2 Posted Sunday at 06:48 PM Alright…PB Blaster and some screwdriver/hammer work and she is coming loose! 2 Share this post Link to post Share on other sites
Sparky-(Admin) 24,071 #3 Posted Sunday at 07:00 PM Watched a video…why does my project not go the same way the one in the video goes . My end cap is off but the pulley that I should be driving outa the end cap stayed on the shaft. Share this post Link to post Share on other sites
WHX?? 53,434 #4 Posted Sunday at 10:51 PM (edited) 4 hours ago, Sparky said: Watched a video…why does my project not go the same way the one in the video goes . Because your watching stupid videos instead of insulting the guys here. Bearing collar or wood wedges behind the pulley hub. Put the screwdrivers down and slowly step away. The pulley and woodruff MUST come off first. Don't worry about mangling the woodruff ... common but guard the nut like it is your wedding ring. It puts the rear end back on until the front end is off. Too much wobble can mar the armature. SG rookies like you make idiots like me wonder why I never did that SG instructional. Edited Sunday at 11:07 PM by WHX?? 1 5 Share this post Link to post Share on other sites
sqrlgtr 1,481 #5 Posted Sunday at 11:20 PM (edited) 30 minutes ago, WHX?? said: make idiots like me wonder why I never did that SG instructional. It's never too late to make video! I for one would like to see that done. Shucks @WHX?? its wintertime and would be a good time to do it. Besides dat the days are going to be getting longer from here on out for a little while anyhows.Icant speak for other things but KNow fur sure u no idiot when it comes to Wheel Horses' Edited Sunday at 11:22 PM by sqrlgtr Share this post Link to post Share on other sites
Sparky-(Admin) 24,071 #6 Posted Monday at 12:45 AM 1 hour ago, WHX?? said: The pulley and woodruff MUST come off first. Don't worry about mangling the woodruff ... common but guard the nut like it is your wedding ring. It puts the rear end back on until the front end is off. Too much wobble can mar the armature. Hmm…good info. Tomorrow I’ll reassemble and try to get the woodruff out before moving forward 2 Share this post Link to post Share on other sites
clueless 3,334 #7 Posted Monday at 02:09 PM 15 hours ago, WHX?? said: Because your watching stupid videos instead of insulting the guys here. Bearing collar or wood wedges behind the pulley hub. Put the screwdrivers down and slowly step away. The pulley and woodruff MUST come off first. Don't worry about mangling the woodruff ... common but guard the nut like it is your wedding ring. It puts the rear end back on until the front end is off. Too much wobble can mar the armature. SG rookies like you make idiots like me wonder why I never did that SG instructional. Makes idiots like me wonder why you haven't. "Just Do It" 1 Share this post Link to post Share on other sites
WHX?? 53,434 #8 Posted Monday at 02:18 PM What's the matter with it Sparky just bearings? 14 hours ago, sqrlgtr said: fur sure u no idiot when it comes to Wheel Horses' I'd beg to differ on that! I've done quite a few of them tho since I am a mid sixties freak with tractors that have them. Mostly just cleaning, replacing bearings & brushes. I'll start putting together pictures. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,071 #9 Posted Monday at 03:11 PM 50 minutes ago, WHX?? said: What's the matter with it Sparky just bearings? Yeah, one of the bearings is crazy loud. Now that I’ve messed with it I’m sure it’s the one behind the pulley. But I have both so it’ll get both replaced. It has always started the 857 just fine and charges perfectly, but it’s loud. 1 Share this post Link to post Share on other sites
peter lena 9,583 #10 Posted Monday at 05:58 PM @ sparky solid vertical mount for gen , maybe a couple f WONDER BARS , if they can remove mower deck spindle pulleys , that equal double leverage pull point might just do it , don't forget lucas green chassis grease has a 550 degree drop point also polyurea , anti sling rated , not had a failure or related bearing whine noise , in all my pto driven attachments. pete Share this post Link to post Share on other sites
WHX?? 53,434 #11 Posted Tuesday at 12:34 AM 9 hours ago, Sparky said: but it’s loud. Mostly a whining noise I bet. Funny thing I put tractors away for the winter and they are quiet. Get them out in the spring and there're noisy. Sometimes goes away after run time sometimes not. Bearings are a real common 6203-2RS. lemme know you need them I buy them in bulk. Greasy Pete will tell you to pick a seal out, clean & repack with red tacky. Really not the worst idea. Stock up on brake cleaner you will go through a full can cleaning the body. End bells can go in a parts cleaner but NOT the body. Same with the armature use the blowgun and brake cleaner. Wear gloves the carbon will NOT come off hands. Put up a pic of the commutator will school ya on servicing that. 1 1 Share this post Link to post Share on other sites
sqrlgtr 1,481 #12 Posted Tuesday at 12:43 AM Just curious. Is there any reason not use a 3 jaw puller on pulley? Share this post Link to post Share on other sites
WHX?? 53,434 #13 Posted Tuesday at 12:51 AM (edited) 7 minutes ago, sqrlgtr said: Just curious. Is there any reason not use a 3 jaw puller on pulley? No that's fine .. it would have to be a smaller puller the shaft is only 5/8" . Some pullies are thin stamped metal so don't use a jaw puller on those they bend real easy... I haven't seen many of those on a Horse most of are stout steel. Edited Tuesday at 12:51 AM by WHX?? 1 Share this post Link to post Share on other sites
peter lena 9,583 #14 Posted Tuesday at 12:55 AM @WHX?? those 6203-2rs , are what I have in my mule drive set up , also have them in deck spindles , also lucas grease in my pto needle bearings , no whyining noise at all , years in , looks like a lubrication failure . probably , that lucas green is bombproof in a heat / stress situation . 550 deg heat rating , and polyurea rated , anti sling . also have a no effort pto lever start , with no bearing resistance . lucas X-TRA HEAVY DUTY GREASE . $ 7 WALMART, worth a look , pete 1 Share this post Link to post Share on other sites
squonk 44,947 #15 Posted Tuesday at 11:01 AM I just replaced the bearings in one that I didn't even remove the jenny from the engine. Hate lining up those bottom bolts. I just did one end at a time. Darn electricians using Klein screwdrivers as prybars! Don't you know only Snap-On screwdrivers are suitable for prying? and don't forget to test everything with your U.E. I. meter! 3 Share this post Link to post Share on other sites
Sparky-(Admin) 24,071 #16 Posted 10 hours ago Done! She starts the tractor, charges once running AND it’s quiet! But every step was a fight! Woodruff key stuck, one bearing stuck on the shaft, one of the three little bearing cover screws had to be drilled out etc. But I won, so there’s that! Will be nice to putt around shows and not hear that whiney bearing. 2 2 Share this post Link to post Share on other sites
953 nut 63,222 #17 Posted 9 hours ago 1 hour ago, Sparky said: Woodruff key stuck, one bearing stuck on the shaft, one of the three little bearing cover screws had to be drilled out etc. Sounds about average, nobody said a sixty + year old mechanical device was going to be a piece of cake. Glad you won and all is well. 1 1 Share this post Link to post Share on other sites
