Sparky-(Admin) 24,026 #1 Posted yesterday at 06:18 PM Starting on the 857’s starter gen repair. The rebuild video on YouTube never mentions the pulley…and tips or tricks to get it off without destroying it? 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,026 #2 Posted yesterday at 06:48 PM Alright…PB Blaster and some screwdriver/hammer work and she is coming loose! 2 Share this post Link to post Share on other sites
Sparky-(Admin) 24,026 #3 Posted yesterday at 07:00 PM Watched a video…why does my project not go the same way the one in the video goes . My end cap is off but the pulley that I should be driving outa the end cap stayed on the shaft. Share this post Link to post Share on other sites
WHX?? 53,381 #4 Posted 21 hours ago (edited) 4 hours ago, Sparky said: Watched a video…why does my project not go the same way the one in the video goes . Because your watching stupid videos instead of insulting the guys here. Bearing collar or wood wedges behind the pulley hub. Put the screwdrivers down and slowly step away. The pulley and woodruff MUST come off first. Don't worry about mangling the woodruff ... common but guard the nut like it is your wedding ring. It puts the rear end back on until the front end is off. Too much wobble can mar the armature. SG rookies like you make idiots like me wonder why I never did that SG instructional. Edited 21 hours ago by WHX?? 3 Share this post Link to post Share on other sites
sqrlgtr 1,357 #5 Posted 21 hours ago (edited) 30 minutes ago, WHX?? said: make idiots like me wonder why I never did that SG instructional. It's never too late to make video! I for one would like to see that done. Shucks @WHX?? its wintertime and would be a good time to do it. Besides dat the days are going to be getting longer from here on out for a little while anyhows.Icant speak for other things but KNow fur sure u no idiot when it comes to Wheel Horses' Edited 21 hours ago by sqrlgtr Share this post Link to post Share on other sites
Sparky-(Admin) 24,026 #6 Posted 20 hours ago 1 hour ago, WHX?? said: The pulley and woodruff MUST come off first. Don't worry about mangling the woodruff ... common but guard the nut like it is your wedding ring. It puts the rear end back on until the front end is off. Too much wobble can mar the armature. Hmm…good info. Tomorrow I’ll reassemble and try to get the woodruff out before moving forward 2 Share this post Link to post Share on other sites
clueless 3,334 #7 Posted 6 hours ago 15 hours ago, WHX?? said: Because your watching stupid videos instead of insulting the guys here. Bearing collar or wood wedges behind the pulley hub. Put the screwdrivers down and slowly step away. The pulley and woodruff MUST come off first. Don't worry about mangling the woodruff ... common but guard the nut like it is your wedding ring. It puts the rear end back on until the front end is off. Too much wobble can mar the armature. SG rookies like you make idiots like me wonder why I never did that SG instructional. Makes idiots like me wonder why you haven't. "Just Do It" 1 Share this post Link to post Share on other sites
WHX?? 53,381 #8 Posted 6 hours ago What's the matter with it Sparky just bearings? 14 hours ago, sqrlgtr said: fur sure u no idiot when it comes to Wheel Horses' I'd beg to differ on that! I've done quite a few of them tho since I am a mid sixties freak with tractors that have them. Mostly just cleaning, replacing bearings & brushes. I'll start putting together pictures. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,026 #9 Posted 5 hours ago 50 minutes ago, WHX?? said: What's the matter with it Sparky just bearings? Yeah, one of the bearings is crazy loud. Now that I’ve messed with it I’m sure it’s the one behind the pulley. But I have both so it’ll get both replaced. It has always started the 857 just fine and charges perfectly, but it’s loud. Share this post Link to post Share on other sites
peter lena 9,571 #10 Posted 2 hours ago @ sparky solid vertical mount for gen , maybe a couple f WONDER BARS , if they can remove mower deck spindle pulleys , that equal double leverage pull point might just do it , don't forget lucas green chassis grease has a 550 degree drop point also polyurea , anti sling rated , not had a failure or related bearing whine noise , in all my pto driven attachments. pete Share this post Link to post Share on other sites
