Richard’s 314-8
Electric conversion
8ntruck
41 minutes ago, kpinnc said:
I'm curious- what will you use to replace the clutching function?
It is electric and looks like it is brushless.  Seems like some sort of soft start/stop function would be possible.  Possibly through a 'gas' pedal?
kpinnc
Exactly why I was asking. Paired with the right controller, you could have a "hybrid" foot controller that works similar to a hydro but with different gear box speeds.
Or just stop and go like those electric cars we had when we were little. Either way will be pretty cool!
Racinbob
Just my :twocents-twocents: worth. I see no reason for a 'clutch' as such. You don't need to disconnect the motor drive to come to a stop. I'm thinking a soft start might not be best. You want full torque to get her rolling. A variable speed control....yup. Think electric golf cart. :)
  • Like 5
Richard’s 314-8
8 hours ago, kpinnc said:
I'm really looking forward to seeing this build unfold. The idea of a super quiet tractor is pretty awesome!
No clutch. Going to be like an electric golf cart, motor only runs when you depress the throttle and I’m going to have a forward/reverse switch so no need to shift gears often
Richard’s 314-8
You are correct, throttle pedal will control the start and stop function
953 nut
:angry-tappingfoot:             Houston,  we have a problem!       With the shaft sticking out there won't be room for then gas tank.  :hide:   Oh never mind, it is :scared-shocked:.
:ROTF:
  • Haha 5
8ntruck
An electric shuttle shift conversion.  Looks like you will end up with a 16 speed tractor.
kpinnc
Awesome. That's sorta what I figured. Thanks!
Handy Don
Posted (edited)
So pop quiz: With the electric switch in reverse and transmission in low reverse, how fast will Johnny go? For extra credit, in what direction?
Answer: He won’t go at all until he presses the pedal. Extra credit: standstill
:unsure: :lol: ;)
Edited by Handy Don
  • Haha 2
Richard’s 314-8
Battery showed up today
  • Excellent 3
kpinnc
Yeah, that is a bleeping battery! :D
51V, 65AH... That's a big fella!
Edited by kpinnc
Richard’s 314-8
I originally was going to use a 105AH and still might in the future but this 65AH was easier to fit and mount
kpinnc
Well you certainly have my attention on this build. I'd love to have a quiet machine!
SylvanLakeWH
Nice!
What did it cost if you don't mind?
sqrlgtr
:text-yeahthat:and what does that dude weigh?
WHX??
:text-yeahthat:
Does that controller charge too?
You might have it covered already Richard but a thread going  on making battery cables.
Richard’s 314-8
3 hours ago, SylvanLakeWH said:
Nice!
Too much $ Lol
Handy Don
I’ve been reading that EVs heat/cool their batteries to maintain optimal charge/discharge performance. Will heat or cold affect your design?
Richard’s 314-8
I forgot what the weight was and can’t seem to find it online at the moment. It’s heavy but nowhere near the weight of the original kohler
Richard’s 314-8
Temperature is a factor. This battery has a heat function for cold weather operation but I need to be mindful during the hot summer months. I’m using this tractor for my garden so not much use during middle of summer when crops are growing.
WHX??
4 hours ago, SylvanLakeWH said:
Nice!
Yah you don't wanna know Sylvia. Curiosity got the best of me and apparently they are used for high end performance golf carts and other apps probably including EVs. When I was told $$$$$.$$ for replacement batteries for her Prius I know why now.
  • Haha 1
Richard’s 314-8
2 hours ago, WHX?? said:
:text-yeahthat:
Thank you for the battery cable link. The controller charges when off the throttle coasting which won’t be much on a tractor. The battery came with a charger you can mount onboard or offboard.
