Richard’s 314-8
Electric conversion
Sparky
That’s pretty cool!
SylvanLakeWH
Very cool!
Please post details. Motor, controller etc.
And :text-welcomeconfetti:
Edited by SylvanLakeWH
ri702bill
Nice welding. Planning on doing a brake upgrade too?? Weight of batteries?? (or a really long extension cord)?? :rolleyes:
Achto
:WRS:
Please post details & picture of your progress.
Richard’s 314-8
1 hour ago, SylvanLakeWH said:
Very cool!
Thank You!  I’m using a Motenergy ME1118 motor and Alltrax AC2 controller. I don’t have a battery yet, that will be next months purchase
Richard’s 314-8
Thank You!  No brake upgrade. I’m using lithium battery so should weigh less than original kohler
Richard’s 314-8
32 minutes ago, Achto said:
:WRS:
Thank you. I will
Richard’s 314-8
2 hours ago, Sparky said:
That’s pretty cool!
Thank You!
kpinnc
Very interesting project! I like what you're doing! :thumbs:
Jusy looking at your tractor- did it have the Command or Magnum 14?
Richard’s 314-8
Magnum
kpinnc
55 minutes ago, Richard’s 314-8 said:
Magnum
Not many Wheel Horses in the Wilmington area I would imagine. Did the Magnum give out?
Not trying to pry. I'm also in NC and I know how these old machines have become much more scarce over the last 10 years. I'm closer to Charlotte and Wheel Horses were all over the place not too long ago. I'm somewhat surprised to see someone with one at the coast.
Richard’s 314-8
I had to travel 2 hours away to get this one. Not much for tractors in Wilmington, I would have a yard full of them if there was.  The engine is still good and I put it against the wall in my garage. The whole tractor is a little rough and mower deck has been patched.  I bought it specifically for this project.
WHX??
:WRS:
Richard’s 314-8
2 hours ago, WHX?? said:
:WRS:
Thank You
oliver2-44
@Richard’s 314-8 Whatsthe equivalent HP or kw of that motor
squonk
Please become a supporter. You will run out of the capability to post pics soon with the limited space allowed. When you are a supporter you have unlimited space.
  • Excellent 2
Richard’s 314-8
It’s a 7-8 HP motor
Richard’s 314-8
I made the belt tensioner last week. Originally was using the existing v-pulley from the factory belt tensioner but then decided to use the flat pulley from the mower deck tensioner to get a better wrap around the drive pulley to prevent slipping. I have 3 different drive pulleys to try, 4” that matches original engine, 3-1/2 that I have installed, and a 3” pulley.
  • Like 5
  • Excellent 3
wallfish
Nice project!
I like that flat idler pinching the belt idea much better for that application.
wallfish
Once had an idea to try building a hybrid tractor but I just don't have the electrical knowledge needed to pull it off. Maybe I'll have the time to research and learn once retired. Basically all self contained so it could charge and also run off the small gas engine.
Did an electric one a long time ago but used a starter generator motor. Definitely not as efficient or powerful as that motor. But it could cruise around for about an hour off one 12v deep cycle battery. It was built for a friend's daughter so it was also a fish tank "powered" tractor.
post-9-0-06835900-1398472135_thumb.jpg.55a91bf67904a140fe96d5f5977d0df2.jpg.0c250920cb2d8f93de5e34a3698f4ca3.jpg
Edited by wallfish
  • Like 4
  • Heart 1
Richard’s 314-8
That is pretty neat. I think you can build the hybrid with research, it would be a fun rewarding project
peter lena
@Richard,s 314-8, nice idea , thought I would tell you about that flat idler belt pulley / tiny bearing , known for failure / noise , would recommend  getting a similar replacement  , with a larger bearing  that could possibly  get better lubricant  , they regularly fail , if that belt  starts to fray from incremental lubrication failure , it will show itself . pete
Richard’s 314-8
Thank you for that advice!  I’m leaning as I go with everyone’s help.
kpinnc
I'm really looking forward to seeing this build unfold. The idea of a super quiet tractor is pretty awesome!
I'm curious- what will you use to replace the clutching function?
