RoubaixRider
Disassembly continues on the C160…
Handy Don
55 minutes ago, RoubaixRider said:
hat black adhesive that looks almost like sandpaper.
Great work.
Sold as grip for skateboards! A HUGE variety of colors and patterns available.
RoubaixRider
3 hours ago, Handy Don said:
Great work.
I found the rubber online for the Wheel Horse…$40. Think I’ll cut some 1/8 inch rubber and fasten it in place with 3M two sided tape and lag bolts through those holes.
Handy Don
The risk you might have is water getting between the mat and the foot rest during use or when washed.
If the mat is your decision, I’d consider rubber cement.
I went with the skateboard stuff (in boring black) and am pleased.
Edited by Handy Don
RoubaixRider
For the moment, I had some rubber in my shop, and just put that down so that I could occasionally sit on the tractor and make engine noises, dreaming of doing laps in the yard😂.
Edited by RoubaixRider
Added image
Handy Don
Vroom Vroom Putt Putt
  • Haha 1
RoubaixRider
Steering column “upgrade”.
well, as I had mentioned before, it was impossible to get the old pin out of the steering wheel to be able to pull the column apart… So I found a nice shaft collar, painted it to match and it does a nice job. I slightly drilled a detent into the shaft so that the Alan key bolts would seat into it for a good positive contact.
Got the decals on and turning my attention now to electrical and engine tear down. That may take a little while, with those pesky work requirements stealing my time away from the shop.🤓
  • Excellent 3
