markseven 93 #1 Posted December 13, 2025 I just got a brand new set of piston and rings from Little Barn problem is I don't see the directions that should have came with it my question is on one ring there's like a 45° taper on the inside and the other ring has a squared off notch on the outer edge of the Ring can anyone tell me the correct orientation Share this post Link to post Share on other sites
953 nut 67,451 #2 Posted December 13, 2025 Do you remember how they were on the old piston? Check out this video. https://www.google.com/search?q=piston+ring+notch+on+outer+edge&rlz=1C1JZAP_enUS981US981&oq=piston+ring+notch+on+outer+edge&gs_lcrp=EgZjaHJvbWUyCQgAEEUYORigATIHCAEQIRigATIHCAIQIRigATIHCAMQIRigATIHCAQQIRirAjIHCAUQIRirAjIHCAYQIRiPAtIBCTM1MzI4ajBqN6gCALACAA&sourceid=chrome&ie=UTF-8#fpstate=ive&vld=cid:45376790,vid:67djRZSHUkM,st:0 Share this post Link to post Share on other sites
markseven 93 #3 Posted December 13, 2025 Yep I did some use tube diagrams and Found what I was looking for. Top ring compression (ring inside ring bevel up.) Middle ring (outside little notch down) Hope this is correct. 2 Share this post Link to post Share on other sites
RED-Z06 2,718 #4 Posted December 14, 2025 Usually if there's only one ring in the pack that's chrome faced, its the top ring, typically have a bevel on the inside that will face up..this helps combustion pressure get behind the ring and force it out. The middle ring is use black, and will have a bevel on the outside, bevel faces down. Oil control rings, if its a 2pc with a thick ring with 2 thin contact points, it will have an expander that goes inside. 3pc rings have an expander; the ends must butt up, not overlap. The thin rings go above and below it. Share this post Link to post Share on other sites
