johnnymag3 2,647 #1 Posted December 11, 2025 (edited) Well...... I now have a beautiful 308-8 that has been a snow mover for an ORIGINAL owner, It has a nice 48 inch blade and well serviced........ I always plow with my Z-71 1989 Silverado, as it is my 35 year snow mover... I usually don't plow 3 inches or less with the Truck, so....I have started to use the 308. It is an incredible snow mover, never loses grip, always in control . Here is my question...... What have you guys found to be the best pattern to move the snow without constantly changing directions?...whether with the blade or the tractor??? I have been angling left or right , then pushing 50 70 feet ,then swinging a circle and plowing back on the other side, windrowing to the appropriate piles / rows. I have a C-160 I can toss the blade on if you guys think its faster. I am just used to BIG CHEVROLET and being done in 5-10 Minutes. I am now Retired so I want to play a wee bit longer outdoors. I do have a plow route for the 3" and up people, I acquired them in 1985. I just cant justify plowing a driveway for 2 inches and charging them .............This is a picture of the original owner as he now live in NON snow land. The 308 is well cared for JOHN Edited December 11, 2025 by johnnymag3 4 Share this post Link to post Share on other sites
ebinmaine 80,078 #2 Posted December 11, 2025 You go look on the YouTube channels for me or Trina. Over the past three or four years you'll find several videos of either one of us plowing snow. I'm not sure I could honestly say that you're going to find a specific direction that works any better than one another because the wind blow alone is going to change your entire work pattern for that storm. If you want to speed things up a little bit I would suggest maybe building some scoops. Side wings. 4 Share this post Link to post Share on other sites
johnnymag3 2,647 #3 Posted December 11, 2025 47 minutes ago, ebinmaine said: You go look on the YouTube channels for me or Trina. Over the past three or four years you'll find several videos of either one of us plowing snow. I'm not sure I could honestly say that you're going to find a specific direction that works any better than one another because the wind blow alone is going to change your entire work pattern for that storm. If you want to speed things up a little bit I would suggest maybe building some scoops. Side wings. Just looking for patterns to avoid the constant blade change left / right .....turn around.....etc.etc. 2 Share this post Link to post Share on other sites
pfrederi 20,992 #4 Posted December 11, 2025 I plow a large area.. For the main driveway start out down the middle casting to the right turn around out in the road an go back still casting right ..Repeat until you have cleared your driveway. 6 3 Share this post Link to post Share on other sites
ebinmaine 80,078 #5 Posted December 11, 2025 1 minute ago, johnnymag3 said: Just looking for patterns to avoid the constant blade change left / right .....turn around.....etc.etc. That can be a little difficult to determine because of Bunches of variables like snow density and overall Terrain and weight of the tractor front and rear. Is there any way you can sort of draw out where your snow piles need to go? And the overall size? 1 Share this post Link to post Share on other sites
Handy Don 17,189 #6 Posted December 11, 2025 (edited) 1 hour ago, johnnymag3 said: best pattern to move the snow without constantly changing directions? A lot depends on wetness and quantity. More depends on where you want to put the snow. I don’t like having piles near the garage so I tend back up into the open garage for each pass to push away. I mostly cast to the right ‘cause that side has the fewest obstructions to piling snow. If I had a long, open driveway, I’d do it just like @pfrederi Edited December 11, 2025 by Handy Don 1 1 Share this post Link to post Share on other sites
Ed Kennell 46,794 #7 Posted December 11, 2025 1 hour ago, pfrederi said: I plow a large area.. For the main driveway start out down the middle casting to the right turn around out in the road an go back still casting right ..Repeat until you have cleared your driveway. I always make that first full blade pass down hill. Then I can use less blade if necessary to maintain traction on the uphill return pass. 3 2 Share this post Link to post Share on other sites
ri702bill 12,694 #8 Posted December 11, 2025 I do the driveway first; plow angled to the hard right and downhill towards the street, taking the snow away from the house on LH side. Backup with plow raised, move over 3/4 blade width, repeat. Similar with the backyard parking area, but blade angled hard left for the 1st pass closest to the house; then all others at the left mid-position. 3 Share this post Link to post Share on other sites
SylvanLakeWH 31,993 #9 Posted December 11, 2025 1 hour ago, pfrederi said: I plow a large area.. For the main driveway start out down the middle casting to the right turn around out in the road an go back still casting right ..Repeat until you have cleared your driveway. I do two adjacent driveways so I use a modified Zamboni pattern much as described. The third drive gets its own mini pattern in same fashion. Very few blade changes... 4 Share this post Link to post Share on other sites
Handy Don 17,189 #10 Posted December 11, 2025 3 minutes ago, SylvanLakeWH said: Zamboni Yeah! “Cool" and apt. 3 1 Share this post Link to post Share on other sites
Pullstart 70,994 #11 Posted December 11, 2025 I always plow 8’ at a time. That usually works best for me… 3 2 1 Share this post Link to post Share on other sites
ebinmaine 80,078 #12 Posted December 11, 2025 14 minutes ago, Pullstart said: I always plow 8’ at a time. Keep the camper on while plowing?? 2 6 Share this post Link to post Share on other sites
SylvanLakeWH 31,993 #13 Posted December 11, 2025 11 minutes ago, ebinmaine said: Keep the camper on while plowing?? Keeps weight on the rear wheels... 1 1 3 Share this post Link to post Share on other sites
Bar Nuthin 2,927 #14 Posted December 11, 2025 30 minutes ago, Pullstart said: I always plow 8’ at a time. That usually works best for me… Seems like it would hard to maneuver with that camper on the back. 2 4 Share this post Link to post Share on other sites
Brockport Bill 2,448 #15 Posted December 11, 2025 obviously, no right or wrong way -- everyone learns with experimenting for their driveway design and nature of storm -- biggest variable is always the depth ( 3 inch versus 12 inches makes huge difference which technique is best ) or snow if fluffy or wet -- one strategy works one storm but maybe not the next - starting down the middle of 12 inch storm then trying to push the next row combined with the middle is 24 inches of snow -- likely not the best approach 3 Share this post Link to post Share on other sites
ri702bill 12,694 #16 Posted December 11, 2025 24 minutes ago, Brockport Bill said: obviously, no right or wrong way -- everyone learns with experimenting for their driveway design and nature of storm -- biggest variable is always the depth ( 3 inch versus 12 inches makes huge difference which technique is best ) The depth and moisture content also determines which tractor I use. Light fluffy stuff - generally the snow thrower first followed by the plow. Heavy wet stuff - only the plow. Long duration storm - need to go out at least twice... 2 Share this post Link to post Share on other sites
Pullstart 70,994 #17 Posted December 12, 2025 2 hours ago, Bar Nuthin said: Seems like it would hard to maneuver with that camper on the back. bahh, I’m used to it! 2 5 Share this post Link to post Share on other sites
JoeM 10,120 #18 Posted December 12, 2025 3 hours ago, ebinmaine said: Keep the camper on while plowing?? If you get stuck, someone will ask "are you stuck?" Nope, just camp n! 2 1 5 Share this post Link to post Share on other sites
Retired Wrencher 6,901 #19 Posted December 12, 2025 10 hours ago, Pullstart said: bahh, I’m used to it! Kevin I would say more rear and traction with the camper. Do what you do best.. 1 Share this post Link to post Share on other sites
johnnymag3 2,647 #20 Posted December 12, 2025 I always plow 8’ at a time I do the same....but when its 2 inches or so , Its a waste to get the truck involved for myself Share this post Link to post Share on other sites
peter lena 9,992 #21 Posted December 12, 2025 @johnnymag3 we all have a different , yet same issue of clearing snow , personally , like to BACK PLOW FIRST , if possible , that will enhance / help your snow slide edge , also have my blade well lubed with , mineral oil or PAM food lube , that slide is like magic on a fresh area , also PLOW WITH THE SUN ? you know where the sun lays across your set up , regularly move it to the warmer sun zone , for melting and drainage . also , snow chains , weights , absolutely , watch for how its settling , a movement opportunity ? do a lot of road edge , dusk / night , well lit up tractor front / rear , reflective vest , just marvel at someone attempting , snow removal , and watch every stage , as the wrong move , THAT BACK PLOWING , SHOULD BE YOUR FIRST STAGE ,THEN REFILL THAT FROM WHARE YOU STARTED THAT , think about what you are doing , realise as usual , what I say / do is not in the book , blade slide off is effortless , swing quadrant works with total ease , pete Share this post Link to post Share on other sites
Brockport Bill 2,448 #22 Posted December 12, 2025 4 hours ago, peter lena said: @johnnymag3 we all have a different , yet same issue of clearing snow , personally , like to BACK PLOW FIRST , if possible , that will enhance / help your snow slide edge , also have my blade well lubed with , mineral oil or PAM food lube , that slide is like magic on a fresh area , also PLOW WITH THE SUN ? you know where the sun lays across your set up , regularly move it to the warmer sun zone , for melting and drainage . also , snow chains , weights , absolutely , watch for how its settling , a movement opportunity ? do a lot of road edge , dusk / night , well lit up tractor front / rear , reflective vest , just marvel at someone attempting , snow removal , and watch every stage , as the wrong move , THAT BACK PLOWING , SHOULD BE YOUR FIRST STAGE ,THEN REFILL THAT FROM WHARE YOU STARTED THAT , think about what you are doing , realise as usual , what I say / do is not in the book , blade slide off is effortless , swing quadrant works with total ease , pete Pete: I ALWAYS lube my blade - - i find it entertaining to see photos of tractor plow blades with huge chunks of snow stuck to the blade -- which obviously prevents snow from smoothly flowing off blade - i also suggest to clean rust which adds friction slowing the snow from gliding off the blade 2 Share this post Link to post Share on other sites
Handy Don 17,189 #23 Posted December 12, 2025 4 minutes ago, Brockport Bill said: Pete: I ALWAYS lube my blade - - i find it entertaining to see photos of tractor plow blades with huge chunks of snow stuck to the blade -- which obviously prevents snow from smoothly flowing off blade - i also suggest to clean rust which adds friction slowing the snow from gliding off the blade Last year the front of the new-to-me blade got stripped to bare metal and refinished. The rest stayed patina! This year the front will get PAMed. 1 Share this post Link to post Share on other sites
peter lena 9,992 #24 Posted December 12, 2025 @Brockport Bill @Handy Don , agree on the blade slickening , another thing about plowing is you can see the immediate effects of what you are doing , that made me change any problem that I was creating . like not back plowing first , if you establish that , you will quickly revert to it , because your end is already there , making an angular slide off easier , used to plow onto my , neighbors land , that first angular cut on the road was always easy , and long . that also made me add a heavy bolt on eye bolt , left hand lower corner , of frame to hood corner , heavy spring added for initial lift , made for much easier lift start , you can also add a turnbuckle to that ? dial in the perfect lift assist . repetitive issues , let you figure in a fix . thanks for the shout . pete Share this post Link to post Share on other sites
SylvanLakeWH 31,993 #25 Posted December 12, 2025 41 minutes ago, Handy Don said: This year the front will get PAMed I use old motor oil... return it to whence it came... Now regarding PAM - Mrs Sylvan won't have any of it in the house... So, does this clog the 's arteries like ours? 3 Share this post Link to post Share on other sites
