73noname 1 #1 Posted December 11, 2025 I have a 73 no name with a 12hp k301. I use it to plow snow and then she sits in my garage. Wonderful machine that has been kept nice. I have been having trouble getting it going a it has sat since last winter. I just replaced the ignition coil, condenser, new points set to 20 thousands, cleaned the carb, new fuel lines, new fuel filter, new battery, new battery cables. I have spark, I have fuel going all the way to the carb bowl. The fuel pump seems to work. It only fires briefly on ether. I’m not sure what else I can do other than try cleaning the carb again. The float and needle aren’t stuck but it looks pretty old. If anyone can help out with suggestions that would be much appreciated. 1 Share this post Link to post Share on other sites
Ed Kennell 47,361 #2 Posted December 11, 2025 to the 2 hours ago, 73noname said: It only fires briefly on ether. Please don't use ether. Use regular gasoline to spray into the carb. If it runs OK by hand feeding fuel into the intake, and the fuel pump spurts a good supply of fuel to the carb., there is a problem in the carb. Clean the carb again paying attention to the shut off needle in the bowl. 2 4 Share this post Link to post Share on other sites
953 nut 69,337 #3 Posted December 11, 2025 5 hours ago, 73noname said: cleaning the carb again Proper cleaning should include an overnight emersion in a can of carburetor cleaner. There are lots of small passages that can become plugged up including the main needle valve, 2 1 Share this post Link to post Share on other sites
Pullstart 71,255 #4 Posted December 12, 2025 (edited) If you hold your palm over the air inlet and crank it over, does your palm get wet? Edited December 12, 2025 by Pullstart 3 Share this post Link to post Share on other sites
adsm08 5,149 #5 Posted December 12, 2025 3 hours ago, Ed Kennell said: Use regular gasoline to spray into the carb. Hair dye bottles work well for this. 1 Share this post Link to post Share on other sites
Pullstart 71,255 #6 Posted December 12, 2025 24 minutes ago, adsm08 said: Hair dye bottles work well for this. Next thing you know we got a bunch of blonde bombers running around the Horse barn! 1 6 Share this post Link to post Share on other sites
953 nut 69,337 #7 Posted December 12, 2025 11 hours ago, adsm08 said: Hair dye bottles work well for this. At your young age I'm suppressed you dye your hair. 4 Share this post Link to post Share on other sites
adsm08 5,149 #8 Posted December 12, 2025 9 hours ago, 953 nut said: At your young age I'm suppressed you dye your hair. I don't. I got that idea from my grandfather, who did not dye his hair either, but my grandmother did, and she always seemed to have extra dye bottles around. 1 Share this post Link to post Share on other sites
andrewLL 31 #9 Posted December 14, 2025 Pullstart, can you clarify, ‘does your palm get wet’? I assume your palm should get sucked in as the engine normally sucks in air which them pulls in fuel as it passes through the carburettor. So your palm would not get wet. Unless air was being blown out of the carburettor. i have a similar starting problem, so am interested in this, once I have sorted out the broken head bolt, see my post. Share this post Link to post Share on other sites
