benMA 3 #1 Posted December 10, 2025 Hello All, I recently bought a 416-H with an Onan P216 and I had some trouble starting it all along but recently it wouldn't start at all. I sent it off to the local repair shop and did a compression test and leak down test and he's recommending replacing both intake valves. He said he thought it had been running lean for a while and it burned up the valves. Two questions, does this diagnosis make sense and also, are there any good sources for engine parts like gaskets and valves? I see some online but I don't know if they're quality or not. Thanks for any help! 1 Share this post Link to post Share on other sites
ri702bill 12,808 #2 Posted December 10, 2025 Welcome! 1 hour ago, benMA said: but recently it wouldn't start at all. As in it would not turn over or it turns over but has no spark?? Both are common issues with well used Onans. How many hours on it?? There is a 9-pin wiring connector that corrodes internally; that creates high resistance and melts the terminals / shell.... Find it, separate the halves, and clean / replace it if it looks bad. Second - Onan's with 1000+ hours tend to develop a valve seat issue. The seat becomes loose in its place and there is usually no permanent fix except engine replacement.  A loose seat can mimic the bad compression or leak-down symptom diagnosis. All said & done, you need to address the running lean issue before using it once fixed. Intake manifold leaks are rather common on Onans.... and are fairly easy to identify. Bill 1 Share this post Link to post Share on other sites
benMA 3 #3 Posted December 10, 2025 Thanks Bill, I believe it is not an electrical issue since he said the compression on both cylinders was really low and the leakdown test showed a leak. It previously would crank and crank and eventually catch but it got worse and worse until it wouldn't catch at all. The reason I'm skeptical about his diagnosis is the tractor only has 400 hours on it. He is quoting me about $900 to do a full engine service (repair the valves and seats, flatten the head, new gaskets, etc.) but he is suggesting a swap with a new Vanguard 23hp for $2500 parts and labor. Obviously a big difference in price and I'm not sure what to do 1 Share this post Link to post Share on other sites
lynnmor 9,010 #4 Posted December 10, 2025 If the testing showed the intake valve(s) leaking, pull the head and try to determine if the valve seat is loose. Sometimes a simple valve adjustment will fix it or go ahead and reseat the valves. To do that valve service you would pull the valve and grind the surface that meets the seat. You would also refinish the seat surface. Download the Onan Service Manual to help you with that. Once we know that the valves are correctly adjusted and seating properly we can go after other things if needed. 2 Share this post Link to post Share on other sites
ri702bill 12,808 #5 Posted December 10, 2025 1 hour ago, benMA said: he is suggesting a swap with a new Vanguard 23hp for $2500 parts and labor. Obviously a big difference in price and I'm not sure what to do The Vanguard swap is a rather popular one - but you've really got to have a tractor in otherwise excellent condition to justify the coin involved.... 1 Share this post Link to post Share on other sites
953 nut 68,500 #6 Posted December 11, 2025 14 hours ago, benMA said: He is quoting me about $900 to do a full engine service (repair the valves and seats, flatten the head, new gaskets, etc.) but he is suggesting a swap with a new Vanguard 23hp for $2500 parts and labor. Obviously a big difference in price and I'm not sure what to do The majority of the $ 900 quoted is labor and there may be some unforeseen internal problems found once the teardown is done so the price could go up from there. If you have the space, skills and inclination to do the job yourself the Vanguard swap would be he way to go. The price you were quoted includes about $ 1,000 of labor cost that you could put back in your pocket by doing a little DIY. 1 Share this post Link to post Share on other sites
benMA 3 #7 Posted December 11, 2025 Thanks for the help all. I think since it only has 400 hours on it I'm going to do the repairs and cross my fingers 2 Share this post Link to post Share on other sites
Bill D 3,099 #8 Posted December 13, 2025 (edited) On 12/11/2025 at 3:13 PM, benMA said: Thanks for the help all. I think since it only has 400 hours on it I'm going to do the repairs and cross my fingers Please ask questions if needed. I have three Onans and like them all. Great engines if properly cared for, but they do need some TLC at times. Edited December 13, 2025 by Bill D Share this post Link to post Share on other sites
RED-Z06 2,720 #9 Posted December 14, 2025 Id be wary of that diagnosis, onan 20hp models had valve seat issues but Onans in general were very robust, these were designed off a commercial generator engine platform. Id check valve lash, recheck compression, if it still is low (below say 100psi) then id pull the front head and look at the valves there 1 Share this post Link to post Share on other sites
