rjg854
What have you done "WITH" your Wheel Horse
CRF857
On 7/1/2026 at 5:17 PM, MainelyWheelhorse said:
I've had good luck covering holes in seats with patches to fix leather couches. I found a roll of the material in various colors on Amazon for not much if I remember right.
On 7/1/2026 at 6:23 PM, SylvanLakeWH said:
Gorilla tape will fix that right up and boy does it last... right color too... :handgestures-thumbupright:
Thanks for the suggestions.
Amazon did a “free” overnight delivery. Got here a few minutes ago.
I will still tape it ,but like the cover and its pockets.
  • Like 5
MainelyWheelhorse
@Brockport Bill Well, I need to come up with something different. I caught it on something mowing the fire station lawn and almost ripped it off. I think if I stiffen it around the holes, it would last longer as that was the only spot with issues.
MainelyWheelhorse
Posted (edited)
On 7/2/2026 at 6:58 AM, c-series don said:
I can’t tell you how many times that has happened to me. I look at a tractor I haven’t used in a while and think I should sell it. Then I use it for whatever reason and think no, I like this tractor, I don’t want to sell it!!
Same here, I’m running out of room but then I grade the driveway with my plow tractor or take a ride on the C-141 I built and think,“Nah, I’ll figure something out to use this for.”
Edited by MainelyWheelhorse
c-series don
@MainelyWheelhorse How about if you sandwiched that piece with a piece of 1”x1”x1/8” angle iron? Not flat stock, angle iron with give it much greater strength.
EthanL
Hauling water out of the creek to water the garden. A pump set up would be nice but I haven’t gotten there yet
EthanL
  • Excellent 2
MainelyWheelhorse
@c-series don That’s what I was thinking too. It only ripped out around the holes.
ebinmaine
  • Excellent 3
MainelyWheelhorse
Posted (edited)
I had to set this up today. For an idea that popped into my head right before I took the picture, it came out great.
  • Excellent 4
ebinmaine
Moving more firewood this morning.
This second load was a monster.
sqrlgtr
Posted (edited)
Had to fix 2 flats on the ol hay wagon and used the C160 to haul them and tools around and out of the barn yard.
Edited by sqrlgtr
  • Excellent 2
Blaine
Fj40z
2 hours ago, Blaine said:
thats really pretty stinking cool!
pfrederi
That is a pretty steep angle for splash lube engines do not do that for very long
Blaine
 It’s about a 100ft stretch across the front of my property. My back .40 is far more brutal.
The last Predator motor tolerated it for about 12 years. I just put a new Hemi Predator on this spring. The old one still ran, it just got low on compression over the past year or so and was hard to start at times.
 If i only get half of that out of this one, for $135 it’s no big loss.
MainelyWheelhorse
Yesterday I mowed the fire station lawn and mine again with the 312. Before I mowed, I took the C-141 out for reconnaissance to check out the conditions of the fire station’s lawn. The new adjustment knob on the 42” deck worked great. There is something off with the deck though as it’s started making horrendous noises like something is stuck in there. It did it before but came out of it so I’ll have to check that out over the next few days.
rick
Yesterday I cut the grass, 2.9 hours according to the hour meter, which showed 1001.7 hours when I parked it.
My mowing rig is a 1979 314-8 with a 1993 78360 48" deck.  I bought it around 2018 with a cracked and rotten 42" deck.  It apparently had been parked outside all it's life as the reason the older fellow sold it was that the seat had rusted out and broke off throwing him over the back.
It's time for an oil change and maybe some special TLC.
adsm08
I ran myself over with the 1076 this morning.
Looks like I still have to do some adjusting on the motion-control tension. I was trying to investigate the loss of power with the blades engaged and the vibration of the tractor while running is enough to knock it into gear.
pfrederi
The motion control on Wheelamatics is anemic at best relying on two little springs to hold tension on the placstic plate.  Here is something I am setting up to put on my neighbors 1075 or my 875.  You need to get the motion control with the big cross spring from any later hydro gear or piston to piston sunstrand. It will fit right in the only glitch is the later one had different bend in the control lever.  So I cut off the one from the late model and am grafting on a cut off from the older style.  Shaft collars and set screws are temp until I check the alignment .
adsm08
Paul, I do believe I have one of those sitting around, courtesy of some feller I met at the Show.
My eventual plan is to attempt to rebuild the one I got from you and put it in this tractor. They look very similar externally.
