CRF857 665 #51 Posted July 3 On 7/1/2026 at 5:17 PM, MainelyWheelhorse said: I've had good luck covering holes in seats with patches to fix leather couches. I found a roll of the material in various colors on Amazon for not much if I remember right. On 7/1/2026 at 6:23 PM, SylvanLakeWH said: Gorilla tape will fix that right up and boy does it last... right color too... Thanks for the suggestions. Amazon did a “free” overnight delivery. Got here a few minutes ago. I will still tape it ,but like the cover and its pockets. 6 Share this post Link to post Share on other sites
MainelyWheelhorse 3,071 #52 Posted July 3 @Brockport Bill Well, I need to come up with something different. I caught it on something mowing the fire station lawn and almost ripped it off. I think if I stiffen it around the holes, it would last longer as that was the only spot with issues. 1 Share this post Link to post Share on other sites
MainelyWheelhorse 3,071 #53 Posted July 3 (edited) On 7/2/2026 at 6:58 AM, c-series don said: I can’t tell you how many times that has happened to me. I look at a tractor I haven’t used in a while and think I should sell it. Then I use it for whatever reason and think no, I like this tractor, I don’t want to sell it!! Same here, I’m running out of room but then I grade the driveway with my plow tractor or take a ride on the C-141 I built and think,“Nah, I’ll figure something out to use this for.” Edited July 5 by MainelyWheelhorse 2 Share this post Link to post Share on other sites
c-series don 12,382 #54 Posted July 3 @MainelyWheelhorse How about if you sandwiched that piece with a piece of 1”x1”x1/8” angle iron? Not flat stock, angle iron with give it much greater strength. 1 1 Share this post Link to post Share on other sites
EthanL 69 #55 Posted July 3 Hauling water out of the creek to water the garden. A pump set up would be nice but I haven’t gotten there yet 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,071 #57 Posted July 3 3 hours ago, c-series don said: @MainelyWheelhorse How about if you sandwiched that piece with a piece of 1”x1”x1/8” angle iron? Not flat stock, angle iron with give it much greater strength. @c-series don That’s what I was thinking too. It only ripped out around the holes. 2 Share this post Link to post Share on other sites
MainelyWheelhorse 3,071 #59 Posted July 5 (edited) I had to set this up today. For an idea that popped into my head right before I took the picture, it came out great. Edited July 5 by MainelyWheelhorse 4 Share this post Link to post Share on other sites
ebinmaine 80,456 #60 Posted July 5 Moving more firewood this morning. This second load was a monster. 4 1 Share this post Link to post Share on other sites
sqrlgtr 3,791 #61 Posted July 9 (edited) Had to fix 2 flats on the ol hay wagon and used the C160 to haul them and tools around and out of the barn yard. Edited July 9 by sqrlgtr 4 2 Share this post Link to post Share on other sites
Fj40z 231 #63 Posted July 13 2 hours ago, Blaine said: IMG_2120.mov thats really pretty stinking cool! 1 Share this post Link to post Share on other sites
pfrederi 21,095 #64 Posted July 13 That is a pretty steep angle for splash lube engines do not do that for very long 2 Share this post Link to post Share on other sites
Blaine 268 #65 Posted July 14 10 hours ago, pfrederi said: That is a pretty steep angle for splash lube engines do not do that for very long It’s about a 100ft stretch across the front of my property. My back .40 is far more brutal. The last Predator motor tolerated it for about 12 years. I just put a new Hemi Predator on this spring. The old one still ran, it just got low on compression over the past year or so and was hard to start at times. If i only get half of that out of this one, for $135 it’s no big loss. Share this post Link to post Share on other sites
MainelyWheelhorse 3,071 #66 Posted July 17 Yesterday I mowed the fire station lawn and mine again with the 312. Before I mowed, I took the C-141 out for reconnaissance to check out the conditions of the fire station’s lawn. The new adjustment knob on the 42” deck worked great. There is something off with the deck though as it’s started making horrendous noises like something is stuck in there. It did it before but came out of it so I’ll have to check that out over the next few days. Share this post Link to post Share on other sites
rick 310 #67 Posted July 18 Yesterday I cut the grass, 2.9 hours according to the hour meter, which showed 1001.7 hours when I parked it. My mowing rig is a 1979 314-8 with a 1993 78360 48" deck. I bought it around 2018 with a cracked and rotten 42" deck. It apparently had been parked outside all it's life as the reason the older fellow sold it was that the seat had rusted out and broke off throwing him over the back. It's time for an oil change and maybe some special TLC. 1 Share this post Link to post Share on other sites
adsm08 5,059 #68 Posted July 18 I ran myself over with the 1076 this morning. Looks like I still have to do some adjusting on the motion-control tension. I was trying to investigate the loss of power with the blades engaged and the vibration of the tractor while running is enough to knock it into gear. 1 Share this post Link to post Share on other sites
pfrederi 21,095 #69 Posted July 18 41 minutes ago, adsm08 said: I ran myself over with the 1076 this morning. Looks like I still have to do some adjusting on the motion-control tension. I was trying to investigate the loss of power with the blades engaged and the vibration of the tractor while running is enough to knock it into gear. The motion control on Wheelamatics is anemic at best relying on two little springs to hold tension on the placstic plate. Here is something I am setting up to put on my neighbors 1075 or my 875. You need to get the motion control with the big cross spring from any later hydro gear or piston to piston sunstrand. It will fit right in the only glitch is the later one had different bend in the control lever. So I cut off the one from the late model and am grafting on a cut off from the older style. Shaft collars and set screws are temp until I check the alignment . 3 2 Share this post Link to post Share on other sites
adsm08 5,059 #70 Posted July 18 25 minutes ago, pfrederi said: The motion control on Wheelamatics is anemic at best relying on two little springs to hold tension on the placstic plate. Here is something I am setting up to put on my neighbors 1075 or my 875. You need to get the motion control with the big cross spring from any later hydro gear or piston to piston sunstrand. It will fit right in the only glitch is the later one had different bend in the control lever. So I cut off the one from the late model and am grafting on a cut off from the older style. Shaft collars and set screws are temp until I check the alignment . Paul, I do believe I have one of those sitting around, courtesy of some feller I met at the Show. My eventual plan is to attempt to rebuild the one I got from you and put it in this tractor. They look very similar externally. 1 Share this post Link to post Share on other sites
sqrlgtr 3,791 #71 Posted July 23 (edited) Little tree trimming/brush hauling with the C-160. At least I can get under tree with Truck and load of hay now . It dont take long to have a yard full of brush when u get to cutting with the pole saw. Edited July 23 by sqrlgtr 1 Share this post Link to post Share on other sites
cafoose 3,822 #72 Posted July 24 @sqrlgtr How do you get under trees with that tall flag on the 160? 7 Share this post Link to post Share on other sites
ebinmaine 80,456 #73 Posted July 24 7 hours ago, cafoose said: @sqrlgtr How do you get under trees with that tall flag on the 160? Cut the trees 1 1 Share this post Link to post Share on other sites
squonk 47,987 #74 Posted July 24 (edited) On 7/18/2026 at 1:46 PM, pfrederi said: The motion control on Wheelamatics is anemic at best relying on two little springs to hold tension on the placstic plate. Here is something I am setting up to put on my neighbors 1075 or my 875. You need to get the motion control with the big cross spring from any later hydro gear or piston to piston sunstrand. It will fit right in the only glitch is the later one had different bend in the control lever. So I cut off the one from the late model and am grafting on a cut off from the older style. Shaft collars and set screws are temp until I check the alignment . You can get more tension on the std Wheel a Matics by replacing the 2 slot head screws with longer allen head screws with a couple of washers. You can it tighter with an allen wrench as opposed to a slot head screw . I did this a year ago and it's still tight. Edited July 24 by squonk 5 Share this post Link to post Share on other sites
Bar Nuthin 3,114 #75 Posted July 24 On 7/18/2026 at 1:46 PM, pfrederi said: The motion control on Wheelamatics is anemic at best relying on two little springs to hold tension on the placstic plate. Here is something I am setting up to put on my neighbors 1075 or my 875. You need to get the motion control with the big cross spring from any later hydro gear or piston to piston sunstrand. It will fit right in the only glitch is the later one had different bend in the control lever. So I cut off the one from the late model and am grafting on a cut off from the older style. Shaft collars and set screws are temp until I check the alignment . Thank you for posting this photo! I found a small e-clip on the garage floor and have spent the last week trying to figure out where it belonged. I've done so many different projects over the past few weeks, I forgot about having my motion control apart on my C-120. Share this post Link to post Share on other sites
