NCSteve 17 #1 Posted 22 hours ago I finally got my box blade assembled and attached to my C120 with my clevis/sleeve hitch. I have hooked up the chain to my clevis hitch,but I cannot raise the box blade using the lift handle. I am not strong enough! Is there a solution for this problem other than the Charles Atlas strength building program? 1 2 Share this post Link to post Share on other sites
ebinmaine 75,389 #2 Posted 21 hours ago 31 minutes ago, NCSteve said: strength building program? Just do that... it'll be good for you. Or... Perhaps a way to utilize a heavy spring? There is an assist spring for snowblowers and rear mounted tillers. 3 Share this post Link to post Share on other sites
JCM 10,388 #3 Posted 21 hours ago 58 minutes ago, NCSteve said: Charles Atlas strength building program? The man who was instrumental in my weight lifting program at the young age of 13. Purchased a Sears & Roebuck Barbell / Dumbell set with money earned mowing lawns. Continued working out for 19 years off and on with a much better weight system. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,691 #4 Posted 20 hours ago This works... atv winch from Harbor Freight. 2 2 Share this post Link to post Share on other sites
953 nut 62,809 #5 Posted 18 hours ago @SylvanLakeWH has your answer, I think he did a thread on the project, perhaps he will post it. 1 Share this post Link to post Share on other sites
SylvanLakeWH 29,691 #6 Posted 17 hours ago (edited) Here ya go - originally on my E-141, transferred to my C-105 when I sold the E-141. Here's the back blade video. I'm actually adding a front winch lift to the same tractor as we speak. Same design as my C-105. Rear lift works great. IMG_3657.mov Edited 17 hours ago by SylvanLakeWH 1 Share this post Link to post Share on other sites
kpinnc 16,093 #7 Posted 14 hours ago (edited) Wondering if you could move the front clevis on the lift cable up one hole at the bellcrank? You'll loose some travel but increase leverage... The diagram below shows using the bottom hole for the rear lift. Maybe try the next one up? Just spit balling. I have no idea if it would work or not. Edited 14 hours ago by kpinnc 2 Share this post Link to post Share on other sites
ineedanother 1,795 #8 Posted 14 hours ago 7 minutes ago, kpinnc said: Wondering if you could move the front clevis on the lift cable up one hole at the bellcrank? You'll loose some travel but increase leverage... Shortening the tongue on the box blade could be significant as well. No idea what you're lifting but the greater the distance from the hinge point, the heavier the lift which is a greater strain on all of the lifting components. 1 Share this post Link to post Share on other sites
ineedanother 1,795 #9 Posted 12 hours ago 1 hour ago, kpinnc said: Wondering if you could move the front clevis on the lift cable up one hole at the bellcrank? You'll loose some travel but increase leverage... The diagram below shows using the bottom hole for the rear lift. Maybe try the next one up? Just spit balling. I have no idea if it would work or not. You might also consider the attachment point on the box blade. Altering connection point on the implement will change the ratio of distance and angles between the levers and pivot point. Essentially like gear reduction to sacrifice output (like slower steering response or less implement movement) in exchange for less energy needed on the lever or steering wheel. Lengthening the lever on the tractor (or installing a larger steering wheel) would be similar but not always practical. 1 Share this post Link to post Share on other sites
NCSteve 17 #10 Posted 4 hours ago Thanks for all the great suggestions. I will consider all of them. I am also considering some easily removable wheels just for transport. Share this post Link to post Share on other sites
wallfish 18,722 #11 Posted 3 hours ago (edited) 1 hour ago, NCSteve said: considering some easily removable wheels just for transport. Maybe consider making the wheels retractable instead of removable????? Probably use large casters so they don't scrape the ground when turning. Wheels would also be useful for moving it around when it's not attached to the tractor There's lots of ways to add a 12v winch as suggested Implementing a trailer jack is another option. To lift it, control the wheels to lift it and retract them, jack it up so the lift lever mechanism can lock to hold it up then retract it, ect ect ect. Something like this, maybe attached to the rear or one on each side? Just spit balling ideas Edited 3 hours ago by wallfish Share this post Link to post Share on other sites
