BradKahler 408 #101 Posted January 1 (edited) After much thinking about it I think I've sort out just where I stand with the K341 oil pan situation. When I got the engine it had this oil pan on it. After poking around on the internet I found that other pans might work so I found this one and ordered it. It obviously wouldn't fit my K341 so I started looking again. After looking some more I came up with the oil pan in this picture. Here is a different view of the pan that I bought. The question I have is would this engine fit on a B100 chassis? I think the crank diameter is 1" but I need to verify that number. After more research I found this thread about Wheel Horse Shaker engines. I think the oil pan I have is the same as on the shaker engines. Edited January 1 by BradKahler Share this post Link to post Share on other sites
Handy Don 17,520 #102 Posted January 1 As far as the hubs turning question... WHs (mostly) used an “open” differential. This means that, if both wheels are off the ground, turning one wheel will cause the other wheel to rotate in the opposite direction with little resistance. This is true for hydros and geared transaxles. It’s more complicated if one wheel is on the ground... 2 Share this post Link to post Share on other sites
BradKahler 408 #103 Posted January 1 1 hour ago, Handy Don said: As far as the hubs turning question... WHs (mostly) used an “open” differential. This means that, if both wheels are off the ground, turning one wheel will cause the other wheel to rotate in the opposite direction with little resistance. This is true for hydros and geared transaxles. It’s more complicated if one wheel is on the ground... I checked the hubs this morning and as you described, turning one rotates the other in the opposite direction. If I try to rotate both in the same direction at the same time, they won't rotate (tow valve screwed tight). The grinding and stalling the engine is what really concerns me. I've done a bunch of searching and found some description of the linkages and how they wear, etc. but I don't see any of those issues on mine. So I'm at a loss as to what to look for next. Share this post Link to post Share on other sites
pfrederi 21,212 #104 Posted January 1 Time to look at the manual 1 Share this post Link to post Share on other sites
pfrederi 21,212 #105 Posted January 2 There is a roll pin (#39) in between the brake lever and the shaft that goes inside the tranny, if it shears the parking pawl may not dispense even when the lever is moved. 1 Share this post Link to post Share on other sites
BradKahler 408 #106 Posted January 2 58 minutes ago, pfrederi said: Time to look at the manual Thanks for the link , looks like I've got some reading to do. If the work requires the hydro unit to be removed then this tractor might have to be put on the back burner. With the motor most likely needing internal work and the same for the hydro unit, I don’t have excess room for two tractors to be in pieces (i.e. the 656). It might be time for this tractor to swap places with the B100 8-speed to see what condition it's in. Share this post Link to post Share on other sites
BradKahler 408 #107 Posted January 2 37 minutes ago, pfrederi said: There is a roll pin (#39) in between the brake lever and the shaft that goes inside the tranny, if it shears the parking pawl may not dispense even when the lever is moved. Oops, I missed this reply. I believe these two pictures show the arm #38 from the diagram above. I can confirm that the arm does move when operating the brake handle. However, I can't say that the roll pin isn't broken and the arm may be moving only partially. I will look closer at the arm/roll pin tomorrow to see how it looks. Thanks for the tip! Share this post Link to post Share on other sites
BradKahler 408 #108 Posted January 2 I took a closer look at the linkage for the parking brake and it does have some slop in it. The attached picture shows a little bit of wear in the stud on the parking brake lever. Compared to some pictures I found while searching, this one doesn't look all that bad. I've also included a short video showing the Brake Lever Slop in the parking brake linkage. The video doesn't show it too well but the arm with the pin does move up and down a little bit. Are there ways to tight up the slop or do I live with it? In order to help troubleshoot, would it be beneficial to hold or clamp the brake lever a little lower than where it is currently being pushed to by the brake lever? Or does that make any sense at all? 1 Share this post Link to post Share on other sites
953 nut 69,680 #109 Posted January 3 That oil pan looks much like the one used on the K-241AS that was used on the 1055 and 1066 so it should work though I don't know if it will be a direct bolt-up and the bottom drain could present a problem when changing oil. That appears to from a Cub Cadet and the drain would have been facing forward, not toward the frame. Here is a screen shot of the 1055 oil pan. 1 Share this post Link to post Share on other sites
BradKahler 408 #110 Posted January 3 2 hours ago, 953 nut said: That oil pan looks much like the one used on the K-241AS that was used on the 1055 and 1066 so it should work though I don't know if it will be a direct bolt-up and the bottom drain could present a problem when changing oil. That appears to from a Cub Cadet and the drain would have been facing forward, not toward the frame. Here is a screen shot of the 1055 oil pan. I found this oil pan from a listing on ebay. I think it's B2 in your reference above. Its not a match for mine, although the mounting holes might be the same. I also found this one on ebay that is listed for K241/K301/K341 engines. I believe it looks just like the oil pan on my engine with the exception of where the oil drain hole is located. I could easily tap a new hole for the oil drain so that it's on the bottom. Share this post Link to post Share on other sites
BradKahler 408 #111 Posted September 25 I may have found a way to resurrect this tractor project. The original motor needs a complete rebuild and the transaxle is locked up. This weekend I will be picking up a transaxle and a motor from a 1973 16 Automatic. I did a compare of the parts lists between the B100 and the 73 16 Automatic and as near as I can tell the transaxle will be a direct bolt in replacement. I didn't find much about the motor swap from a 10 hp to a 16 hp, but based on some pictures it appears that the 16 hp will bolt into place. The parts list comparison did indicate that the throttle cable and the belt guard are different but I should be able to obtain those items from the donor tractor. The other thing I noted was most of the speed/direction control mechanism was the same with the exception of the control lever itself. The 16 Automatic has the speed/direction control on the floor between the operators legs while the B100 has a lever on the right side. Are there any other hidden gotchas that I need be aware of? 1 Share this post Link to post Share on other sites
953 nut 69,680 #112 Posted September 26 That is the beauty of Wheel Horses, consistency. They were built where parts from late models can be interchanged to earlier models with little or no modification. 1 1 Share this post Link to post Share on other sites
BradKahler 408 #113 Posted October 1 On 9/26/2026 at 8:40 AM, 953 nut said: That is the beauty of Wheel Horses, consistency. They were built where parts from late models can be interchanged to earlier models with little or no modification. Well, if all goes to plan, today I'll be picking up the motor, transaxle, belt guard and a few other odds and ends. 3 1 Share this post Link to post Share on other sites
BradKahler 408 #114 Posted Thursday at 03:05 PM I did pick up the parts as planned, got them unloaded then got busy dealing with some unexpected issues elsewhere. I did look things over and the engine looks good, has good compression so I have high hopes it will be a good useable motor. The transaxle probably isn't useable as is, when you turn the rear hubs I can feel a crunching feeling. The crunchiness is there through out the rotation and is the same on both sides. I'm guessing there is something broken inside, like maybe the parking pawl The price was right so I went ahead and bought it. I also got all of the misc. parts associated with the transaxle so if it turns out I can use it in the future then I'm all set as far as supporting components. So I guess as it stands right now, the B100 Automatic is closer to being a viable tractor but it's not there yet. Share this post Link to post Share on other sites
Bar Nuthin 3,330 #115 Posted Thursday at 03:35 PM (edited) 30 minutes ago, BradKahler said: I did pick up the parts as planned, got them unloaded then got busy dealing with some unexpected issues elsewhere. I did look things over and the engine looks good, has good compression so I have high hopes it will be a good useable motor. The transaxle probably isn't useable as is, when you turn the rear hubs I can feel a crunching feeling. The crunchiness is there through out the rotation and is the same on both sides. I'm guessing there is something broken inside, like maybe the parking pawl The price was right so I went ahead and bought it. I also got all of the misc. parts associated with the transaxle so if it turns out I can use it in the future then I'm all set as far as supporting components. So I guess as it stands right now, the B100 Automatic is closer to being a viable tractor but it's not there yet. If you hold the brake lever all the way down, and you still have grinding - your issue goes beyond the parking pawl. I have a unit from a C-120 that may meet your needs. I'm about 4 hours north of you. Edited Thursday at 03:50 PM by Bar Nuthin 1 1 Share this post Link to post Share on other sites
BradKahler 408 #116 Posted 6 hours ago On 10/22/2026 at 11:35 AM, Bar Nuthin said: If you hold the brake lever all the way down, and you still have grinding - your issue goes beyond the parking pawl. I have a unit from a C-120 that may meet your needs. I'm about 4 hours north of you. On the transaxle that I just picked up, the parking pawl lever just flops all over. I can feel crunchiness just from rotating the axles. At a minimum the axle bearings are probably shot and based on the parking pawl movement I'd say there's also a bunch of metal chips floating around. At best this transaxle will be a parts unit. The original transaxle in the B100 feels good and everything is tight, the oil was clear when I drained it, the problem is when the engine is running (and smoking!) as soon as I move the motion lever the engine immediately dies. No sputtering, it just stops. My best guess is the parking pawl is engaged. I have not yet taken time to play with the parking pawl while the engine is running, mainly because I borrowed parts from the engine to get my B100 8-speed running. If your C-120 transaxle works and doesn't need to be split, the drive might be worth it 1 Share this post Link to post Share on other sites
Bar Nuthin 3,330 #117 Posted 5 hours ago 55 minutes ago, BradKahler said: If your C-120 transaxle works and doesn't need to be split, the drive might be worth it I would say it does need split - or at least it would if it saw much more use as the whining noise has slowly increased over the summer. My plan is to put new bearings throughout. 1 Share this post Link to post Share on other sites
