adsm08 4,308 #1 Posted December 1, 2025 Is there a difference between the welded and non-welded cylinders, beyond the obvious of one being welded together and the other not? I swapped in a non-welded cylinder today that I picked up at the show (no idea what it was originally off of) and the threads were straight instead of pipe thread, 5/16 instead of 1/4 inch, and I had to add another hole to the lift link for my plow to get it off the ground going up, but I was almost able to lift the front axle off the ground going down, which I had never been able to do before. It dropped right in place, but it's almost like it is operating in a different length range. I'm just curious at this point. The whole point of it was so the tractor wasn't down while I send the welded one out to get resealed. 1 Share this post Link to post Share on other sites
Bar Nuthin 2,257 #2 Posted December 1, 2025 following Share this post Link to post Share on other sites
pfrederi 20,147 #3 Posted December 1, 2025 Older WH cylinders (welded) used SAE #5 ORB fittings later ones used SAE#6 ORB neither cylinder that i have come across used pipe threads... both were straight NF 1/2" #5 9/16" #6 1 Share this post Link to post Share on other sites
adsm08 4,308 #4 Posted December 1, 2025 28 minutes ago, pfrederi said: neither cylinder that i have come across used pipe threads The on that came to me on my 855 100% uses 1/4" NPT at both ends, and the lines I got from Lowell were that threading as well. Share this post Link to post Share on other sites
pfrederi 20,147 #5 Posted December 2, 2025 I guess your 855 gear drive has an HY2/3?? added for lift?? That is older than i am familiar with. Charger/electros and later hydros welded cylinders were SAE5 Share this post Link to post Share on other sites
Bar Nuthin 2,257 #6 Posted December 2, 2025 (edited) When I added an older lift kit to a newer Hydro, I had to find adapters that went from ORB-6 down to ORB-5. Sounds like you need to do just the opposite. Or contact Lowell @wheelhorseman and have him make you a set with ORB-6 fittings at the cylinder. Edited December 2, 2025 by Bar Nuthin Share this post Link to post Share on other sites
adsm08 4,308 #7 Posted December 2, 2025 17 minutes ago, pfrederi said: I guess your 855 gear drive has an HY2/3?? added for lift?? You guess correctly sir. It came to me with an HY-2 already added, I'm guessing it was a DIA setup. Share this post Link to post Share on other sites
