Racinbob 12,350 #1 Posted 6 hours ago It was 3, maybe 4 springs agio when I made a road trip to pick up a tall chute snow thrower from another member here. With the winters we've been having I never really got to test it out. I'm not complaining though. I did throw some snow a couple times but not much and pretty fluffy. Well, it changed Friday and Saturday. We had about 10" of extremely wet and heavy slop come down. I always choose using the blade over the thrower and yesterday was no different. At least until I made or tried to make, a pass. I got about 30' outside the garage and it became a no-go with no place to push it to. Knowing how the wet slop doesn't like snowblowers I figured I'd give it a shot. I was quite surprised. I didn't think to take a picture but I just paced it off and it was easily tossing it 60-70 feet. The chute never even tried to plug up. I will say that it took every bit of poop the Kohler had in it. Even out by the road where the plows had left a hood height solid pile. An added plus was that it was so wet that it didn't want to cover me. Now, the real point of starting this thread. The directional changer dooby works fine. The manual lift is fine. But several times I had to get off the tractor to change the thingy at the top of the chute. I don't like that especially dressed like a mummy. As I was moving the snow I thought of several manual methods to adjust it from the seat. I didn't really like any of them. So I'm thinking how easy it would be to install something like this. Probably about a 6" stroke would do it. I know a lot of you guys have really dolled up their operation with all sorts of goodys so how about posting some of your creations so I can see how the smart guys did it. 3 Share this post Link to post Share on other sites
squonk 44,802 #2 Posted 4 hours ago I always got good performance out of the tall shoot I had. And the wetter stuff doesn't blow all over you! Share this post Link to post Share on other sites
ri702bill 10,398 #3 Posted 4 hours ago What about something similar to the cable actuated mechanism to tip the Cap like on a newer Ariens Classic Snowblower?? (Chinsy piece of pressed tin that it is) 1 Share this post Link to post Share on other sites
Achto 30,069 #4 Posted 3 hours ago 40 minutes ago, ri702bill said: Ariens Classic Snowblower?? (Chinsy piece of pressed tin that it is May seem that way but when compared to other new walk behinds, the Ariens has very little plastic. Really like my Ariens, would buy another one some day, if I ever have to. Share this post Link to post Share on other sites
Achto 30,069 #5 Posted 3 hours ago 2 hours ago, Racinbob said: how about posting some of your creations so I can see how the smart guys did it. I think @WHX?? has all the power toys on the 520 that he bought. 1 Share this post Link to post Share on other sites
ri702bill 10,398 #6 Posted 3 hours ago 30 minutes ago, Achto said: May seem that way but when compared to other new walk behinds, the Ariens has very little plastic. Really like my Ariens, would buy another one some day, if I ever have to. I have almost identical 24" Ariens Sno-Thros at my 2 properties. 1976 units - one still has the H60, the other a newer HH70. Simple rugged machines. Safety features - none! They weigh about 300 lbs. each. 1 Share this post Link to post Share on other sites
wallfish 18,709 #7 Posted 2 hours ago Measure the distance on the chute handle to where you want to mount it in both all the way up and all the way down. That will give you the stroke you need for the actuator. Mine is mounted to the side so it moves quicker 1 Share this post Link to post Share on other sites
Racinbob 12,350 #8 Posted 2 hours ago That's the stuff I was looking for John. Right now I'm only looking to do the little top deflector. I measured from the top of the handle to a mounting point on the chute body and it looks like a 6" stroke would be spot on. But I'm wondering if I want to mount it lower and use a shorter stroke for quicker movement. Share this post Link to post Share on other sites
wallfish 18,709 #9 Posted 34 minutes ago (edited) 1 hour ago, Racinbob said: That's the stuff I was looking for John. Right now I'm only looking to do the little top deflector. I measured from the top of the handle to a mounting point on the chute body and it looks like a 6" stroke would be spot on. But I'm wondering if I want to mount it lower and use a shorter stroke for quicker movement. That is a 4" stroke actuator so I guess it's 33.3% faster than mounting a 6" er on the back. Those small actuators seemed to all have the same travel speed. You could still mount it on the back and add a small brace across that handle to still archive the same thing. Edited 33 minutes ago by wallfish Share this post Link to post Share on other sites
