chiefsb30 59 #1 Posted November 30, 2025 (edited) I've looked around and I know its been done. I have a 1973 no-name Automatic 16 with an electric PTO that is failing. Seems that converting to manual is probably the cheaper and more reliable way to go. Does anyone have like a good parts list, and/or source for what I would need? Thanks Edited November 30, 2025 by chiefsb30 1 Share this post Link to post Share on other sites
ebinmaine 80,714 #2 Posted November 30, 2025 I'd have a fair amount of the hard parts you need. All used decent shape. I do NOT have a good clutch disc. @76c12091520h Brian Badman likely does. There will be engine brackets, PTO pulley, crankshaft spacer, handle through the steering tower, rod connecting the two. You'll want to procure new bushings. Others will be along to help..... 1 Share this post Link to post Share on other sites
8ntruck 9,301 #3 Posted November 30, 2025 I'm thinking that this should be pretty much a bolt on conversion 'cause the electric PTO clutch was an option. 2 Share this post Link to post Share on other sites
chiefsb30 59 #4 Posted November 30, 2025 2 minutes ago, 8ntruck said: I'm thinking that this should be pretty much a bolt on conversion 'cause the electric PTO clutch was an option. That is kind of what I was thinking. I'm just trying to sort out the details and give myself options. 1 Share this post Link to post Share on other sites
Ed Kennell 47,356 #5 Posted November 30, 2025 Don't rule out the older Raider style PTO engagement design. It is much simpler, fewer parts, and IMO the better design. 3 Share this post Link to post Share on other sites
ebinmaine 80,714 #6 Posted December 1, 2025 26 minutes ago, Ed Kennell said: Don't rule out the older Raider style PTO engagement design. It is much simpler, fewer parts, and IMO the better design. Definitely more simple 1 Share this post Link to post Share on other sites
ri702bill 13,068 #7 Posted December 1, 2025 10 minutes ago, ebinmaine said: Definitely more simple But would lack the PTO Safety Switch. And may interfere with a plow angling lever - may require a "Z" bend to clear.... Share this post Link to post Share on other sites
Ed Kennell 47,356 #8 Posted December 1, 2025 6 minutes ago, ri702bill said: But would lack the PTO Safety Switch. This brings up a question. When the electric PTO switch is on, does it prevent startup and does it kill the engine if the seat is vacated? Share this post Link to post Share on other sites
ri702bill 13,068 #9 Posted December 1, 2025 2 minutes ago, Ed Kennell said: if the seat is vacated? Ed... I believe the phrase is "if the seat is vacated unintentionally"! Share this post Link to post Share on other sites
ebinmaine 80,714 #10 Posted December 1, 2025 38 minutes ago, ri702bill said: But would lack the PTO Safety Switch. And may interfere with a plow angling lever - may require a "Z" bend to clear.... Not sure if a 1973 had a PTO safety or not. The angle lever would be an issue to be addressed for sure. I've had a plow from a 1974 on a 1967 so it can be done. 1 Share this post Link to post Share on other sites
Ed Kennell 47,356 #11 Posted December 1, 2025 Found the answer. The electric PTO switch is part of the safety switch wiring circuit. Tractor 1973 Auto 10hp 12hp 14hp 16hp Automatic OM Wiring Revised SN.pdf - 1973-1977 - RedSquare Wheel Horse Forum 2 Share this post Link to post Share on other sites
Handy Don 17,474 #12 Posted December 1, 2025 1 hour ago, Ed Kennell said: Found the answer. The electric PTO switch is part of the safety switch wiring circuit. Tractor 1973 Auto 10hp 12hp 14hp 16hp Automatic OM Wiring Revised SN.pdf - 1973-1977 - RedSquare Wheel Horse Forum Ed beat me to it! 1 Share this post Link to post Share on other sites
lynnmor 9,040 #13 Posted December 1, 2025 You need to be sure that the engine can stand the side pressure of the manual PTO. An electric clutch doesn't put thrust on the crankshaft, a manual does which requires a thrust bearing in the engine. 1 Share this post Link to post Share on other sites
mrc 1,119 #14 Posted December 1, 2025 i have a spare electric pto. i was saving it for my bronco14 but, i recently sold the bronco and no longer need it. plug and play. if interested contact me via pm regards mike 1 1 Share this post Link to post Share on other sites
Racinbob 13,192 #15 Posted December 1, 2025 A conversion I've been considering forever on my 05 because I don't like electric clutches. But you need to be sure your engine will be OK with it. Check out service bulletin #1961 addressing this. Share this post Link to post Share on other sites
ri702bill 13,068 #16 Posted December 1, 2025 7 hours ago, lynnmor said: An electric clutch doesn't put thrust on the crankshaft, a manual does Please clarify. Both are inline radial devices. The side load, to me, comes from the device being driven at a right angle by the PTO via the tight belt, not the PTO itself. Share this post Link to post Share on other sites
ebinmaine 80,714 #17 Posted December 1, 2025 7 hours ago, lynnmor said: You need to be sure that the engine can stand the side pressure of the manual PTO. An electric clutch doesn't put thrust on the crankshaft, a manual does which requires a thrust bearing in the engine. A '73 16 Auto should have a Kohler. ... unless it's been swapped that'll hold the horizontal load ok. 11 minutes ago, ri702bill said: Please clarify. Both are inline radial devices. The side load, to me, comes from the device being driven at a right angle by the PTO via the tight belt, not the PTO itself. He's referring to the horizontal load made when the PTO is engaged. Not the radial load from the belt(s). The horizontal load is caused by the PTO putting pressure against the outside of the engine thereby attempting to pull the crankshaft in the outward direction. 2 Share this post Link to post Share on other sites
Racinbob 13,192 #18 Posted December 1, 2025 I've always figured that an electric clutch 'clamps' tight to the crankshaft. A manual push/pulls on the crankshaft as it engages. 1 Share this post Link to post Share on other sites
Ed Kennell 47,356 #19 Posted December 1, 2025 Radial (side) load from the belt tension is the same for manual and electric PTOs. Axial (horizontal) load for electric PTO is zero. The manual PTO pushes the crankshaft inward exerting an axial load on the thrust bearing. 2 1 Share this post Link to post Share on other sites
