jsp_333 306 #1 Posted November 27, 2025 For the past 5 years or so my blower does not sit flush to the ground. I thought this is the year I'm going to ask for help. • the skids are both fully retracted. • the blower mounts as it should to the front mount (attach-a-matic) • the blower is on level ground • the left side is a good 1" to 1.5" off the ground (as I'm standing in front looking at the blower). Short of the frame being twisted I got nothing else. What Have I missed? It was fine the first couple of years I owned it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #2 Posted November 27, 2025 Left and right is always from the operator's position in the seat so this is the right side. Assuming this is a single stage blower it may be the drive belt tension that is holding it up. Try removing the belt from the idlers and see what happens. Uses a 5/8" x 69" belt. 3 Share this post Link to post Share on other sites
lynnmor 9,050 #4 Posted November 27, 2025 Check the tire pressure in all 4 tires. Check for a twist in the mounting by removing the blower and checking the height of the mounting bar on both sides with the blower sitting in operating position. 2 Share this post Link to post Share on other sites
jsp_333 306 #5 Posted November 27, 2025 "Left and right is always from the operator's position in the seat so this is the right side" Thanks for that gwest So I undid the drive belt. No change. Raised the blower and it still wasn't "level". Some pics Share this post Link to post Share on other sites
jsp_333 306 #6 Posted November 27, 2025 A twist in the mounting kinda makes sense. The blower has been on two different tractors with the same issue. Share this post Link to post Share on other sites
jsp_333 306 #7 Posted November 27, 2025 Next is to remove the hand cut coupling nut I used as a spacer on the flag and lift bar and replace them with big washers 1 Share this post Link to post Share on other sites
8ntruck 9,334 #8 Posted November 27, 2025 (edited) Take the flag off, and see if it sits on the ground level? Either way, this would give you something to investigate. Edited November 27, 2025 by 8ntruck 1 Share this post Link to post Share on other sites
Wayne0 1,643 #9 Posted November 27, 2025 Rear tire pressure was my problem. 3 Share this post Link to post Share on other sites
ri702bill 13,189 #10 Posted November 27, 2025 "No more calls folks. We have a winner!!". Seriously. two more things, related to the lift flag. If the lift rod is too long, the blower will not hit the ground as it should. If you are using an assist spring and it is adjusted too short, same thing happens. 1 Share this post Link to post Share on other sites
Ed Kennell 47,587 #11 Posted November 27, 2025 (edited) 2 hours ago, ri702bill said: lift rod is too long, Yeah, now that the blower is completely lowered, maybe we should change those side wings that are not installed correctly. Edited November 28, 2025 by Ed Kennell 3 Share this post Link to post Share on other sites
c-series don 12,519 #12 Posted November 28, 2025 @Ed Kennell Good eye Ed! Side wings on backwards is something I usually look for and missed it this time! When I first read this I was thinking about rear tire pressure. I’m glad to hear that’s all it was! 👍🏻 2 Share this post Link to post Share on other sites
jsp_333 306 #13 Posted November 28, 2025 The side wings are on Backwards?!?!? Who knew there was a side. So it sits flush to the ground when not attached to the lift flag. I added the spacer because without it the blower was barely raised off the ground. So how high should I be able to lift the blower - 1 inch, 2 inch 3 inch. The rear tires are loaded so I don't worry about tire pressure too much. However I let air out to keep the tire chains from getting caught on the seat pan. Share this post Link to post Share on other sites
Ed Kennell 47,587 #15 Posted November 28, 2025 59 minutes ago, jsp_333 said: So how high should I be able to lift the blower - 1 inch, 2 inch 3 inch. It should lift 3 inches. Which hole do you have the flag in? If it is in the top or middle hole, try moving it down a hole. 1 Share this post Link to post Share on other sites
jsp_333 306 #16 Posted November 28, 2025 Fixed the side wings. It should lift 3 inches. So a long time ago I got hung up on how high I could lift the blower. For some reason I modified the lift arm and flag (with spacers) so the blower unit would raise about 6 inches. Which hole do you have the flag in? The flag is in the top hole Attaching the flag to the tractor became such a chore every year I bought a dedicated tractor. I'll try moving it down to at least the middle and take all the spacers off the lift arm. 1 1 Share this post Link to post Share on other sites
peter lena 10,087 #17 Posted November 28, 2025 @jsp_333 , @ri702billhiding in plane site , is a regular part of repetitive , problems , emphasise that often , had issues that drove me nuts, till I got a better view of it , now its a regular thing , to roller stool around it on a flat floor . if you can, having a helper , to operate issue while you are sitting there , looking at it , lets you see the ENTIRE START , of issue , usually a hand off phase of function . levers / linkages are known for that . glad you got it , pete 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #18 Posted November 29, 2025 An old service bulletin that describes how the lift tube washers affect lift height. 1 1 Share this post Link to post Share on other sites
Racinbob 13,213 #19 Posted November 29, 2025 Good to hear that you found the problem. If the tire pressure wasn't it here's another thing to try that has worked for me a couple times. Remove the belt tension. On a level surface lower the blower so it sits on the ground. Loosen the bolts holding the mounting bracket to the blower body. Place a small spacer under the left side of the blower body (about 3/8"-1/2"). Tighten the mounting bolts securely. Reattach the belt. It does often work. Raising the left side a little compensates for the belt tension pulling on the other slop areas. There's always some slop even if it an itsy-bitsy amount. 1 1 Share this post Link to post Share on other sites
jsp_333 306 #20 Posted November 29, 2025 So I've removed all the spacers from the flag. I lowered the flag position to the middle hole. I can't lock the snowblower in the raised position. Tried altering the lift adjust mechanism to see if that would help. Screwed it All the way in and out. I even removed the spacer. So it looks like the flag is going back in the top hole. AAAAARG. Share this post Link to post Share on other sites
Ed Kennell 47,587 #21 Posted November 29, 2025 (edited) 6 minutes ago, jsp_333 said: Tried altering the lift adjust mechanism That does nothing but set a minimum low position. Usually used for a grader blade or snow plow. What hit and prevented the blower from going high enough to lock the lift lever? Edited November 29, 2025 by Ed Kennell Share this post Link to post Share on other sites
Ed Kennell 47,587 #22 Posted November 29, 2025 May be this will help. When I set up a new blower, I park the tractor on a flat surface. With the blower down and the flag installed in the top hole and the lift lever or hdro lift lowered. Hook the lift pipe to the blower lug and hold it beside the lift flag rod. Then you can determine the amount you must remove or add to the lift pipe. If I need to shorten the pipe, I always cut it 1/8" short and plan to add two 1/16" washers so I have some adjustment. Note, it is not necessary to remove the flag when making the adjustment by adding or removing washers. You can disconnect the pipe at the blower and install the pipe on the flag while it is in place. 1 Share this post Link to post Share on other sites
jsp_333 306 #23 Posted December 10, 2025 UPDATE; Got about 6 inches of heavy wet snow today and so far blower is scraping the driveway down to the asphalt. So thanks all 3 Share this post Link to post Share on other sites
