Wayne0
Has anyone seen one of these?
Wayne0
Found this browsing CL. Never seen one.
ebinmaine
Spindle wrench. I've read about them here. But I don't want to call ever seeing one in person. No need either. We don't mow with tractors.
ri702bill
Yup - some of the newer ones for sale are cast. Nope...
I have not had an issue with the 1-1/8" nut; the difficult one is the 15/16 flats on the spindle. I bought a "yard sale" one and thinned the width to fit. That works.
stevasaurus
If you search "Wheel Horse wrench" a number of threads will come up.  Here is a good one...  :occasion-xmas:
JoeM
That wrench is used to hold the spindle hex between the blade and spindle. It is long enough to catch the side of the deck so the nut can be loosened that holds the blade.
Some have tried to use it to tighten the nut and doesn't work good for that application, just to hold the shaft from turning.
JCM
 I have had one of these for many years, works great.
953 nut
Much like @ri702bill I took one of my 1 1/8' combination wrenches and cut it down with a port-a-band just enough to slip into the space above the blade.
lynnmor
I bought one when I purchased my 1991, only to find out it was made of peanut butter.
  • Sad 2
Racinbob
I've had a few of those through the years. Actually they are more of a wall hanger. I have a Reese saved from our RV'ing years and milled down another one to get to the top nut. :)
kpinnc
Buy a 20V impact driver. Never busted my knuckles since! Cheapo Horror Freight has lasted almost 10 years. Wheels and deck blades are stupid easy now.
Just be sure and keep the direction correct. It'll wring off the shaft before you know it. :unsure:
Lee1977
I have a air impack that I got about 35 years ago right after getting the 60 gallon air compressor.
Easton Rich
Ive only seen one. A friend has it. They are pretty flimsy:wacko:
