ebinmaine 81,281 #1 Posted November 22, 2025 Is there a home shop made or alternative tool to a small pickle fork? 1 Share this post Link to post Share on other sites
wallfish 20,744 #2 Posted November 22, 2025 (edited) Yeah, here's what they look like Those tie rods don't go in on a locking tapered fit like automotive ball joints do. Loosen the nut to the end of the threads (to protect them) and hit it with a hammer to knock it through the hole if it's rusted together. If the nut is locked on the threads and it's just spinning, try twisting the rod by the locking nut with a wrench which will add friction to the joint. Edited November 22, 2025 by wallfish 6 1 2 1 Share this post Link to post Share on other sites
peter lena 10,125 #3 Posted November 22, 2025 @ebinmaine https://www.google.com/search?q=types+of+tapered+suspension+tie+rod+removal+tools+&sca_esv=326a9b3488e82af6&rlz=1C1CHBF_enUS866US866&sxsrf=AE its a tie rod removal tool , also set things up , so the initial 3 lb impact is solid dead hit , if it does not bounce , usually breaks the rusty hold . of course , some penetrant , pete 1 Share this post Link to post Share on other sites
ineedanother 2,885 #4 Posted November 22, 2025 50 minutes ago, ebinmaine said: Is there a home shop made or alternative tool to a small pickle fork? I subscribe to @wallfish 's solution as well but try this first. This was inexpensive at HF and I use it for more than ball joints. 3 2 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #5 Posted November 22, 2025 23 minutes ago, wallfish said: Yeah, here's what they look like Those tie rods don't go in on a locking tapered fit like automotive ball joints do. Loosen the nut to the end of the threads (to protect them) and hit it with a hammer to knock it through the hole if it's rusted together. If the nut is locked on the threads and it's just spinning, try twisting the rod by the locking nut with a wrench which will add friction to the joint. Turns out in my case the rod itself is freed up but the castle nut is frozen onto the threads... Share this post Link to post Share on other sites
ebinmaine 81,281 #6 Posted November 22, 2025 GOT EM!! I used my induction heater I picked up a few months ago. 5 4 Share this post Link to post Share on other sites
ri702bill 13,393 #7 Posted November 22, 2025 (edited) I concur emphatically with this choice. In the right hands, this ball joint wedge fork is a true timesaver. It has a smaller cousin for tie rods. In the wrong hands, the fork can fly out, go across the room and get imbedded in the water heater... A lot to do with the choice of extractor tool is whether or not the joint is being reused. The fork usually tears up the boot... Sometimes... just wedging it in and pushing down on the opposite end is enough to pop it loose. Edited November 22, 2025 by ri702bill 2 1 1 Share this post Link to post Share on other sites
wallfish 20,744 #8 Posted November 22, 2025 3 hours ago, ineedanother said: and I use it for more than ball joints Yup. I just have a hand and hammer fork but it's great for wedging stuff off like pulleys. It would be nice to have the different sizes too. 3 Share this post Link to post Share on other sites
ri702bill 13,393 #9 Posted November 22, 2025 (edited) 55 minutes ago, wallfish said: It would be nice to have the different sizes too. There is! You can buy either Ball Joint "Pickle Forks" or the smaller Tie Rod version. HFT sells this "Party Pack" Fun for all sizes!! I have actually used two at a time from opposite sides on really stubborn stuff - like using two Wonderbars to remove deck spindle pulleys... Edited November 22, 2025 by ri702bill 2 1 Share this post Link to post Share on other sites
peter lena 10,125 #10 Posted November 22, 2025 @ebinmaine another thing I regularly do weeks out is to get the penetrant going , break the nut loose , get the creping / soaking going, don't retighten as much , often get a liquid rust track started , with normal stress , movement . that really helps out on wheel / axel hubs . dissimilar metals , seam to react easier , the sooner the lubrication stain turns rusty , you are on the way . pete 1 Share this post Link to post Share on other sites
8ntruck 9,420 #11 Posted November 22, 2025 5 hours ago, ebinmaine said: GOT EM!! I used my induction heater I picked up a few months ago. Cool! Details, please? That looks like it could be a real help with rust welded pieces parts. Maybe help with assembly and disassembly of press fit parts, too. 2 Share this post Link to post Share on other sites
stevasaurus 23,892 #12 Posted November 22, 2025 These are very helpful also. Sold at Harbor Freight for a few bucks. 3 1 Share this post Link to post Share on other sites
ri702bill 13,393 #13 Posted November 22, 2025 Yup - I've had my Snap-on set since 1973.. The tool in your hand and the one at the other end are affectionately known as the "Gazinta and the Gazover" exhaust pipe cutters. Great for cutting a muffler off the pipe you want to save or cutting out the pipe inside the muffler you want to save. One goes into, the other goes over... as in "Hang on, I need to grab the Gazinta to cut that pipe..." 1 3 Share this post Link to post Share on other sites
ebinmaine 81,281 #14 Posted November 22, 2025 1 hour ago, 8ntruck said: Cool! Details, please? That looks like it could be a real help with rust welded pieces parts. Maybe help with assembly and disassembly of press fit parts, too. See the loops? That's a copper (?) coil wrapped in heat resistant cloth. I have only 3 coils. There are many versions. You find the coil of rhe smallest diameter that doesn't make contact with the heated item. Press the button on the tool. Wait 60 to 80 seconds and the heated item is a nice cherry red. Attempt removal. Lather. Rinse. Repeat. I had to heat each side twice. 4 1 Share this post Link to post Share on other sites
adsm08 5,247 #15 Posted November 23, 2025 9 hours ago, ebinmaine said: GOT EM!! I used my induction heater I picked up a few months ago. I bought one of those a few years ago specifically for working around fuel tanks, where a torch might be too dangerous. One of the best tools I ever bought. 2 1 Share this post Link to post Share on other sites
adsm08 5,247 #16 Posted November 23, 2025 8 hours ago, ri702bill said: the fork can fly out Look into getting a quick-release chuck instead of that spring retainer chuck. Makes them a lot less dangerous. 3 Share this post Link to post Share on other sites
JoeM 10,318 #17 Posted November 23, 2025 (edited) Here you go EB added the dimensions 2 inch pipe 3 inches long the washer is 3/4 Edited November 23, 2025 by JoeM 2 3 Share this post Link to post Share on other sites
Retired Wrencher 7,043 #18 Posted November 23, 2025 Looks like you have a lot of choices here, Eric to use. A hammer at wallfish said would be the cheapest way to go. Did you ever get them out? 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #19 Posted November 23, 2025 2 hours ago, Retired Wrencher said: Looks like you have a lot of choices here, Eric to use. A hammer at wallfish said would be the cheapest way to go. Did you ever get them out? 21 hours ago, ebinmaine said: GOT EM!! I used my induction heater I picked up a few months ago. Yep. Share this post Link to post Share on other sites
ebinmaine 81,281 #20 Posted November 23, 2025 11 hours ago, adsm08 said: One of the best tools I ever bought. I can see that. I'm my case there's no availability of a decent torch set and using the small bottles is VERY expensive. This heater has been extremely handy for the couple occasions I've remembered to use it. @Joe M niiiiice. 1 1 Share this post Link to post Share on other sites
cleat 9,450 #21 Posted November 23, 2025 I have never had one put up too big a fight (yet). A lot of time the cotter key is the hardest to get out. I just use an impact to remove the nut then flip it over and screw it back on most of the way until the tie rod stud is flush to the end of the nut. Then one or two good nice even (so as not to bend anything) whacks with a hammer (I use a brass hammer for this) and the tie rod should pop free. Hopefully at this time you can just unscrew the nut. Holding the tie rod in as tight as possible while spinning the nut off with an impact should do it. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,281 #22 Posted November 23, 2025 1 minute ago, cleat said: Holding the tie rod in as tight as possible while spinning the nut off with an impact should do it. This is where our issue was. This particular tractor was living outside. Some areas were rusted. Others spotless. On this task the rusted part was the nut & thread. The spotless part was the plain stud. The stud popped right out leaving us with no way to hold the rest from spinning. After a soak with penetrant and a super heating it decided to free up. Share this post Link to post Share on other sites
wallfish 20,744 #23 Posted November 23, 2025 23 hours ago, wallfish said: If the nut is locked on the threads and it's just spinning, try twisting the rod by the locking nut with a wrench which will add friction to the joint. Share this post Link to post Share on other sites
ebinmaine 81,281 #24 Posted November 23, 2025 4 minutes ago, wallfish said: try twisting the rod by the locking nut with a wrench which will add friction to the joint. I saw that post earlier but I don't see any way to grab anything on these other than the nut that is already frozen on the threads. The thread shaft is round from top to bottom. Share this post Link to post Share on other sites
wallfish 20,744 #25 Posted November 23, 2025 (edited) Twist this nut with a wrench to crate friction in the joint so the stud has resistance and the nut will come off Edited November 23, 2025 by wallfish 2 1 Share this post Link to post Share on other sites
